查看: 4185|回复: 0
__builtin_expect详解
ID:72519 发表于 2015-1-23 19:25 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
在GTK+2.0源码中有很多这样的宏:G_LIKELY和G_UNLIKELY。比如下面这段代码:
if (G_LIKELY (acat == 1))       /* allocate through magazine layer */
        ThreadMemory *tmem = thread_memory_from_self();
        guint ix = SLAB_INDEX (allocator, chunk_size);
        if (G_UNLIKELY (thread_memory_magazine1_is_empty (tmem, ix)))
            thread_memory_swap_magazines (tmem, ix);
              thread_memory_magazine1_reload (tmem, ix);
        mem = thread_memory_magazine1_alloc (tmem, ix);
      }在源码中,宏G_LIKELY和G_UNLIKELY 是这么定义的:
#define G_LIKELY(expr) (__builtin_expect (_G_BOOLEAN_EXPR(expr), 1))
  #define G_UNLIKELY(expr) (__builtin_expect (_G_BOOLEAN_EXPR(expr), 0))宏_G_BOOLEAN_EXPR的作用是把expr转换为0和1,即真假两种。要理解宏G_LIKELY和G_UNLIKELY ,很明显必须理解__builtin_expect。__builtin_expect是GCC(version>=2.9)引进的宏,其作用就是帮助编译器判断条件跳转的预期值,避免跳转造成时间乱费。拿上面的代码来说:
if (G_LIKELY (acat == 1))      //表示大多数情况下if里面是真,程序大多数直接执行if里面的程序
而
if (G_UNLIKELY (thread_memory_magazine1_is_empty (tmem, ix)))//表示大多数情况if里面为假,程序大多数直接执行else里面的程序
可能大家看到还是一头雾水,看下面一段就会明白其中的乐趣啦;
//test_builtin_expect.c
#define LIKELY(x) __builtin_expect(!!(x), 1)
#define UNLIKELY(x) __builtin_expect(!!(x), 0)
int test_likely(int x)
if(LIKELY(x))
    x = 5;
    x = 6;
return x;
int test_unlikely(int x)
if(UNLIKELY(x))
    x = 5;
    x = 6;
return x;
}[lammy@localhost test_builtin_expect]$ gcc -fprofile-arcs -O2 -c test_builtin_expect.c
[lammy@localhost test_builtin_expect]$ objdump -d test_builtin_expect.otest_builtin_expect.o:       file format elf32-i386
Disassembly of section .text:00000000 <test_likely>:
     0: 55                      push     %ebp
     1: 89 e5                   mov      %esp,%ebp
     3: 8b 45 08                mov      0x8(%ebp),%eax
     6: 83 05 38 00 00 00 01  addl     $0x1,0x38
     d: 83 15 3c 00 00 00 00  adcl     $0x0,0x3c
  14: 85 c0                   test     %eax,%eax
  16: 74 15                   je       2d <test_likely+0x2d>//主要看这里
  18: 83 05 40 00 00 00 01  addl     $0x1,0x40
  1f: b8 05 00 00 00          mov      $0x5,%eax
  24: 83 15 44 00 00 00 00  adcl     $0x0,0x44
  2b: 5d                      pop      %ebp
  2c: c3                      ret
  2d: 83 05 48 00 00 00 01  addl     $0x1,0x48
  34: b8 06 00 00 00          mov      $0x6,%eax
  39: 83 15 4c 00 00 00 00  adcl     $0x0,0x4c
  40: 5d                      pop      %ebp
  41: c3                      ret
  42: 8d b4 26 00 00 00 00  lea      0x0(%esi,%eiz,1),%esi
  49: 8d bc 27 00 00 00 00  lea      0x0(%edi,%eiz,1),%edi00000050 <test_unlikely>:
  50: 55                      push     %ebp
  51: 89 e5                   mov      %esp,%ebp
  53: 8b 55 08                mov      0x8(%ebp),%edx
  56: 83 05 20 00 00 00 01  addl     $0x1,0x20
  5d: 83 15 24 00 00 00 00  adcl     $0x0,0x24
  64: 85 d2                   test     %edx,%edx
  66: 75 15                   jne      7d <test_unlikely+0x2d>//主要看这里
  68: 83 05 30 00 00 00 01  addl     $0x1,0x30
  6f: b8 06 00 00 00          mov      $0x6,%eax
  74: 83 15 34 00 00 00 00  adcl     $0x0,0x34
  7b: 5d                      pop      %ebp
  7c: c3                      ret
  7d: 83 05 28 00 00 00 01  addl     $0x1,0x28
  84: b8 05 00 00 00          mov      $0x5,%eax
  89: 83 15 2c 00 00 00 00  adcl     $0x0,0x2c
  90: 5d                      pop      %ebp
  91: c3                      ret
  92: 8d b4 26 00 00 00 00  lea      0x0(%esi,%eiz,1),%esi
  99: 8d bc 27 00 00 00 00  lea      0x0(%edi,%eiz,1),%edi000000a0 <_GLOBAL__I_65535_0_test_likely>:
  a0: 55                      push     %ebp
  a1: 89 e5                   mov      %esp,%ebp
  a3: 83 ec 08                sub      $0x8,%esp
  a6: c7 04 24 00 00 00 00  movl     $0x0,(%esp)
  ad: e8 fc ff ff ff          call     ae <_GLOBAL__I_65535_0_test_likely+0xe>
  b2: c9                      leave
  b3: c3                      ret
[lammy@localhost test_builtin_expect]$两个函数编译生成的汇编语句所使用到的跳转指令不一样,仔细分析下会发现__builtin_expect实际上是为了满足在大多数情况不执行跳转指令,所以__builtin_expect仅仅是告诉编译器优化,并没有改变其对真值的判断。
这种用法在linux内核中也经常用到,国外也有一篇相关的文章,大家不妨看看:http://kernelnewbies.org/FAQ/LikelyUnlikely
不知大家注意到没有,我在生产汇编时用的是gcc -fprofile-arcs -O2 -c test_builtin_expect.c,而不是gcc -O2 -c test_builtin_expect.c,具体可以参考http://gcc.gnu.org/onlinedocs/gcc/Other-Builtins.html。
