查看: 6134|回复: 0
NXP_LPC1114延时函数集合
ID:73735 发表于 2015-2-18 23:19 | 只看该作者 回帖奖励 |正序浏览 |阅读模式
#include "LPC11XX.h"
#include "gpio.h"
#include "timer16.h"
/*系统时钟配置为48MHz,AHB不分频,一次定时器时钟为48Mhz,因此得出以下分频值,匹配值*/
void Delay_Us(unsigned int DelayTimes)
/* * setup timer #1 for delay */
//LPC_SYSCON->SYSAHBCLKCTRL |= (1<<8);     /*开启定时器Timer16_1时钟--时钟配置中开启该时钟*/
  LPC_TMR16B1->TCR = 0x02;                 /* reset timer */
  LPC_TMR16B1->PR  = 48;                   /* set prescaler to zero 根据AHB时钟确定分频值*/
  LPC_TMR16B1->MR0 = DelayTimes;             /* 所需的延时时间 */
  LPC_TMR16B1->IR  = 0xff;                 /* reset all interrrupts 复位所有的中断*/
  LPC_TMR16B1->MCR = 0x04;                 /* stop timer on match --达到匹配停止*/
  LPC_TMR16B1->TCR = 0x01;                 /* start timer 启动定时器*/
while (LPC_TMR16B1->TCR & 0x01);           /*等待直到时间到*/
LPC_TMR16B1->TCR = 0x00;                 /* Close timer --关闭定时器*/
void Delay_Ms(unsigned int DelayTimes)
//LPC_SYSCON->SYSAHBCLKCTRL |= (1<<8);       //开启定时器Timer16_1时钟
  LPC_TMR16B1->PR  = 48000;                 /* set prescaler to zero */
  LPC_TMR16B1->IR  = 0xff;                 /* reset all interrrupts */
  LPC_TMR16B1->MCR = 0x04;                 /* stop timer on match */
  LPC_TMR16B1->TCR = 0x01;                 /* start timer */
LPC_TMR16B1->TCR = 0x00;                 /* Close timer */
void Delay_Sec(unsigned char DelayTimes)
  LPC_TMR16B1->PR  = 48000000;             /* set prescaler to zero */
