查看: 2325|回复: 0
怎么在时钟中断的时候向DS1302中写入数据,实现调时功能
ID:75108 发表于 2015-3-23 14:49 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
main中代码如下:
*    ³ÌÐòÉè¼Æ¹¦ÄÜ£º1¡¢»ùÓÚDS1302µÄʵʱʱÖÓÏÔʾ£¬²¢¾ß±¸       *
*                    ¿ÉÒÔµ÷½Úʱ¼ä¡¢ÈÕÆÚµÄ¹¦ÄÜ£¨À©Õ¹ÄÖÖӵȣ© *
*   2¡¢¿ÉÒÔÏÔʾζȣ¬Í¨¹ý°´¼ü½øÐÐÏÔʾÇл»£¬Î¶ȱ¨¾¯        *
*   3¡¢À©Õ¹ÏÔÊ¾ÆøÑ¹¡¢¾ß±¸ÓïÒô²¥±¨¹¦ÄÜ£¨´ýÀ©Õ¹£©            *
*   ×÷ÕߣºZ B T                         ʱ¼ä£º   2015.03   *
#include<reg51.h>
#include"DS1302.h"
/* º¯ÊýÔ­ÐÍÉùÃ÷ */
void timer_init();          /* Öжϳõʼ»¯ */
void key_scan();            /* ¼üÅÌɨÃ躯Êý */
void display_time();        /* ÏÔʾʱ¼ä */
void delayms(uint xms);     /* xmsΪ¶àÉÙ ÑÓʱ¶àÉÙºÁÃë */
/* ¶Ë¿Ú¶¨Òå */
sbit led = P2^2;        /* LED¶Ë¿Ú */
sbit buzzer = P2^1;        /* ·äÃùÆ÷¶Ë¿Ú */
sbit key0 = P1^0;        /* ½øÈëʱÖÓÉèÖÃģʽ */
sbit key1 = P1^1;        /* Ñ¡ÔñÒªµ÷µÄ²¿·Ö */
sbit key2 = P1^2;        /* Ôö¼Ó°´¼ü */
sbit key3 = P1^3;        /* ¼õС°´¼ü */
sbit dula = P2^6;       /* 74HC573N¿ØÖƵĶÎÑ¡¶Ë  */
sbit wela = P2^7;       /* 74HC573N¿ØÖƵÄλѡ¶Ë */
//extern unsigned char TIME[7];    //¼ÓÈëÈ«¾Ö±äÁ¿
uchar code w[] = {0xfe, 0xfd,0xfb, 0xf7, 0xef, 0xdf};        /* ÊýÂë¹Üλѡ */
uchar code tab[17]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,
                            0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};    /* 0----FµÄÏÔʾÂë ¹²Òõ */
uchar display_data[8];    /* ÓÃÀ´´æ·ÅÒªÏÔʾµÄ8λÊýµÄÖµ (±¾³ÌÐòÔÝʱÓÃ6¸öÊýÂë¹Ü) */
uchar state,set_place; /* state£º ÊÇ·ñÑ¡Ôñµ÷ʱµÄ±êÖ¾   set_place £ºÑ¡Ôñµ÷½ÚÄIJ¿·Ö */
    //ds1302_init();   /*  Ê±ÖÓ³õʼ»¯ */
        if(state == 0)
            ds1302_read_time();
            key_scan();
        display_time();
void key_scan()
   if(key1 == 0)
     delayms(5);
     if(key1 == 0)
        set_place++;
        if(set_place == 7)
          set_place = 0;
         while(!key1);
   if(set_place != 0)
       if(key2 == 0)
           delayms(5);
           if(key2 == 0)
               while(!key1);   // °´¼üÊÍ·Å
               if(set_place == 1)
                   TIME[1]++;   ds1302_read_time();
/* ÊýÂë¹ÜÏÔʾʱ¼äº¯Êý */
void display_time()
    uchar i;
    uint j;
    display_data[0] = tab[TIME[2]/16];                /* ½«Ð¡Ê±µÄBCDÂë·Ö³ÉÁ½Î»Êý */
    display_data[1] = tab[TIME[2]&0x0f];
    //display_data[2] = 0x40;        /* ÏÔʾ-- ±¾Éè¼ÆÔÝʱ²»ÏÔʾ */
    display_data[2] = tab[TIME[1]/16];                /* ½«´ú±í·ÖµÄBCDÂë·Ö³ÉÁ½Î»Êý */
    display_data[3] = tab[TIME[1]&0x0f];
    //display_data[5] = 0x40;
    display_data[4] = tab[TIME[0]/16];                /* ½«´ú±íСʱµÄBCDÂë·Ö³ÉÁ½Î»Êý */
    display_data[5] = tab[TIME[0]&0x0f];
    for(i = 0; i < 6; i++)
        wela = 1;
        P0 = w[i];    /* ËÍÈëλѡ */
        wela = 0;
        dula = 1;
        P0 = display_data[i];    /* ËÍÈë¶ÎÑ¡ */
        dula = 0;
        P0 = 0x00;    /* ÏûÒþ */
        if(i == 5)    /* ledÉÁ˸ */
            led = ~led;
        j=70;             /* ɨÃè¼ä¸ôʱ¼äÉ趨 */
        while(j--);
void timer_init()
    TMOD = 0x01;
    TH0 = (65536 - 45872) / 256;
    TL0 = (65536 - 45872) % 256;
    EA = 1;
    ET0 = 1;
    TR0 = 1;
void t0() interrupt 1
    if(key0 == 0)
        delayms(5);
        if(key0 == 0)
            state = ~state;
            set_place++;
            ds1302_init();  /* ´ò¿ª¹Ø±Õд±£»¤ */
            while(!key0);
/* ÑÓʱº¯Êý */
    uint i, j;
    for(i = xms; i > 0; i--)
    for(j = 110; j > 0; j--);    /* ÑÓʱԼxms */
希望能有人解答一下key_scan中的函数是不是哪里写错了,
这个想了好久都没弄好,希望得到大家帮助
