查看: 5960|回复: 0
[讨论]基于合作式时间触发的问题
ID:20356 发表于 2009-12-22 17:17 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
用合作式时间触发的方法对C51进行编程,模拟调试的时候可以通过,在线编译就出错。编译器用的是星研的star51ph。请高手指点问题出在哪里?
1ms时标的合作式调度器(多个合作式任务)
作者:shadow.hu
时间:2008-4-23
#include<reg52.h>
#define uchar  unsigned char
#define ushort unsigned short
#define SCH_MAX_TASKS 5
#define SCHTASKS  (1)
#define INTERRPT_Timer_2_Overflow 5
#define ERROR_SCH_TOO_MANY_TASKS  6
#define ERROR_SCH_CANOT_DELETE_TASK 1
#define RETURN_ERROR 0
#define RETURN_NORMAL 1
#define SCH_REPORT_ERRORS
#ifdef SCH_REPORT_ERRORS
#define Error_Port P1
#endif
typedef data struct
    void (code *pTask)(void);
 ushort Delay;
 ushort Period;
 ushort RunMe;
}sTask;
sTask SCH_tasks_G[SCH_MAX_TASKS];
void SCH_Init_T2(void);
uchar SCH_Add_Task(void (code * pFunction)(),const ushort Delay, ushort PERIOD);
void SCH_Dispatch_Tasks(void);
void SCH_Start(void);
bit SCH_Delete_Task(const ushort TASK_INDEX);
void SCH_Go_To_Sleep(void);
void SCH_Report_Status(void);//报告系统状况
void LED_Flash_Init(void);
void LED_Flash_Update(void);
uchar Error_code_G = 0;
uchar  LED_State_G = 0;
sbit LED_pin = P1^7;
//Error_code_G = ERROR_SCH_TOO_MANY_TASKS;
//Error_code_G = ERROR_SCH_WAITING_FOR_SLAVE_TO_ACK;
//Error_code_G = ERROR_SCH_WAITING_FOR_START_COMAND_FROM_MASTER;
//Error_code_G = ERROR_SCH_ONE_OR_MORE_SLAVES_DID_NOT_START;
//Error_code_G = ERROR_SCH_LOST_SLAVE;
//Error_code_G = ERROR_SCH_CAN_BUS_ERROR;
//Error_code_G = ERROR_I2C_WRITE_BYTE_AT24C64;
void main(void)
 SCH_Init_T2();
 LED_Flash_Init();
 SCH_Add_Task(LED_Flash_Update,0,1000);
 SCH_Start();
  SCH_Dispatch_Tasks();
void SCH_Update(void) interrupt INTERRPT_Timer_2_Overflow
 //刷新任务队列
 uchar Index;
 TF2 = 0;
 for(Index = 0;Index < SCH_MAX_TASKS;Index++)
  if(SCH_tasks_G[Index].pTask)
   if(SCH_tasks_G[Index].Delay == 0)
    //任务需要运行
    SCH_tasks_G[Index].RunMe += 1;
    if(SCH_tasks_G[Index].Period)
     //调度周期性的任务再次运行
     SCH_tasks_G[Index].Delay = SCH_tasks_G[Index].Period;
    //还没有准备好运行,延迟减1
    SCH_tasks_G[Index].Delay -= 1;
    uchar i;
 for(i=0;i<SCH_MAX_TASKS;i++)
  SCH_Delete_Task(i);
 Error_code_G = 0;
 T2CON = 0x04;
 TMOD = 0x00;
 TH2   = 0xfc;
 RCAP2H = 0xfc;
 TL2   = 0x18;
 RCAP2L = 0x18;
 ET2   = 1;
 TR2   = 1;
uchar SCH_Add_Task(void (code * pFunction)(),const ushort DELAY, ushort PERIOD)
 uchar Index = 0;
 while((SCH_tasks_G[Index].pTask != 0)&&(Index < SCH_MAX_TASKS))
  Index++;
 if(Index == SCH_MAX_TASKS)
  return SCH_MAX_TASKS;
 SCH_tasks_G[Index].pTask = pFunction;
 SCH_tasks_G[Index].Delay = DELAY;
 SCH_tasks_G[Index].Period = PERIOD;
 SCH_tasks_G[Index].RunMe  = 0;
 return Index;//返回任务的位置
 uchar Index;
  if(SCH_tasks_G[Index].RunMe > 0)
   (*SCH_tasks_G[Index].pTask)() ;//执行任务
   SCH_tasks_G[Index].RunMe -= 1;
  if(SCH_tasks_G[Index].Period == 0)
   SCH_Delete_Task(Index);
 SCH_Report_Status();//报告系统状况
 SCH_Go_To_Sleep();
 EA = 1;
 bit Return_code;
 if(SCH_tasks_G[TASK_INDEX].pTask == 0)
  Error_code_G = ERROR_SCH_CANOT_DELETE_TASK;
  Return_code = RETURN_ERROR;
  Return_code = RETURN_NORMAL;
 SCH_tasks_G[TASK_INDEX].pTask = 0x0000;
 SCH_tasks_G[TASK_INDEX].Delay = 0;
 SCH_tasks_G[TASK_INDEX].Period = 0;
 SCH_tasks_G[TASK_INDEX].RunMe = 0;
 return Return_code;
void SCH_Go_To_Sleep()
 PCON |= 0x01;
/* #ifdef SCH_REPORT_ERRORS
 if(Error_code_G != Last_error_code_G)
  Error_Port = 255 - Error_code_G;
  Last_error_code_G = Error_code_G;
  if(Error_code_G != 0)
   Error_tick_count_G = 60000;
   Error_tick_count_G = 0;
  if(Error_tick_count_G != 0)
   if(--Error_count_G == 0)
    Error_code_G = 0;
 #endif    */
 if(LED_State_G == 1)
  LED_State_G = 0;
  LED_pin = 0;
  LED_State_G = 1;
  LED_pin = 1;
 LED_State_G= 0;
