查看: 8105|回复: 0
字节数组(BYTE [])与整数(int/DWORD)转换
ID:77367 发表于 2015-4-18 20:48 | 显示全部楼层 |阅读模式
// int2byte.cpp : 定义控制台应用程序的入口点。
#include "stdafx.h"
#include <Windows.h>
#define MAKEWORD(a, b)        ((WORD)(((BYTE)(((DWORD_PTR)(a)) & 0xff)) | ((WORD)((BYTE)(((DWORD_PTR)(b)) & 0xff))) << 8))
#define MAKELONG(a, b)        ((LONG)(((WORD)(((DWORD_PTR)(a)) & 0xffff)) | ((DWORD)((WORD)(((DWORD_PTR)(b)) & 0xffff))) << 16))
#define LOWORD(l)                ((WORD)(((DWORD_PTR)(l)) & 0xffff))
#define HIWORD(l)                ((WORD)((((DWORD_PTR)(l)) >> 16) & 0xffff))
#define LOBYTE(w)                ((BYTE)(((DWORD_PTR)(w)) & 0xff))
#define HIBYTE(w)                ((BYTE)((((DWORD_PTR)(w)) >> 8) & 0xff))
//   Big Endian / Small Endian utility functions
BOOL IsSmallEndian()
        DWORD wd = 0x22;
        if( *((BYTE *)&wd) == 0x22 )  // Small Endian
                return TRUE;
                return FALSE;
void SwapShort(WORD *sp) {
                BYTE *cp = (BYTE *)sp, t = cp[0]; cp[0] = cp[1]; cp[1] = t;
void SwapLong(DWORD *lp) {
                BYTE *cp = (BYTE *)lp, t = cp[0]; cp[0] = cp[3]; cp[3] = t;
                t = cp[1]; cp[1] = cp[2]; cp[2] = t;
// int 2 byte
BYTE *Int2Byte(int nVal)
        BYTE *pByte = new BYTE[4];
        for (int i = 0; i<4;i++)
                pByte[i] = (BYTE)(nVal >> 8*(3-i) & 0xff);
        return pByte;
// byte 2 int
int Byte2Int(BYTE *pb)
        // assume the length of pb is 4
        int nValue=0;
        for(int i=0;i < 4; i++)
                nValue += ( pb[i] & 0xFF)<<(8*(3-i));
        return nValue;
int _tmain(int argc, _TCHAR* argv[])
        //PC, 小端字节
        BYTE *byte = Int2Byte(0x12345678);
        printf("byte[0]=0x%xh,byte[1]=0x%xh,byte[2]=0x%xh, byte[3]=0x%xh\n", byte[0], byte[1], byte[2],byte[3]);
        int nVal = Byte2Int(byte);
        printf("nVal=0x%xh\n\n",nVal);
        // 小端字节应该是得到 0xefcdab89, 大端得到0x89abcdef
        WORD wLow, wHigh;
        DWORD dwData;
        BYTE b[4] = {0x89, 0xab, 0xcd, 0xef};
        DWORD dwVal = 0xefcdab89;
        // DWORD分解成BYTE数组
        WORD lo = LOWORD(dwVal),
                hi = HIWORD(dwVal);
        printf("lo=0x%xh,hi=0x%xh\n", lo, hi);
        //BYTE数组组合成DWORD
        wLow = MAKEWORD(b[0],b[1]);
        wHigh = MAKEWORD(b[2], b[3]);
        dwData = MAKELONG(wLow, wHigh);
        printf("wLow=0x%xh,wHigh=0x%xh,dwData=0x%xh\n", wLow, wHigh, dwData);
        getchar();
        return 0;
