查看: 5526|回复: 1
电机转同时点阵显示
ID:81203 发表于 2015-5-26 19:16 | 显示全部楼层 |阅读模式
            电机转同时点阵显示
#include <reg52.h>
sbit da  =P2^7;
sbit shcp=P2^5;
sbit stcp=P2^6;
uint led_array_count,anode_next;
bit motor_flag=0,led_array_flag;
uchar anode,negative;
uchar a,b;
void delays(uchar ms)
        uint a;
        while(ms--)  for(a=0;a<100;a++);
////////////////////////////////////////初始化定时器
void initial_timer0()
          TMOD=0X02;
          TH0=0x38;      //100us
          TL0=0x38;
          TR0=1;
          EA=1;
          ET0=1;
uchar code motor_run[]={0x08,0x0c,0x04,0x06,0x02,0x03,0x01,0x09};              //最高频率250us
uchar code led_array_anode[]={ 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,
                                     0xC1,0x01,0x00,0x00,0x00,0x00,0x80,0x83,
                               0x60,0x01,0x01,0x00,0x00,0x80,0x80,0x06,
                                     0x30,0x00,0x01,0x01,0x80,0x80,0x00,0x0C,
                                     0x18,0x00,0x00,0x81,0x81,0x00,0x00,0x18,
                                     0x0C,0x00,0x80,0x80,0x01,0x01,0x00,0x30,
                                     0x06,0x80,0x80,0x00,0x01,0x01,0x01,0x60,
                                     0x83,0x80,0x00,0x00,0x00,0x00,0x01,0xC1,
                                     0xE1,0x01,0x01,0x00,0x00,0x80,0x80,0x87,
                                     0x62,0xC3,0x01,0x00,0x00,0x80,0xC3,0x46,
                                     0x30,0x62,0x03,0x01,0x80,0xC0,0x46,0x0C,
                                     0x08,0x14,0x22,0x41,0x82,0x44,0x28,0x10,
                               0x00,0x08,0x14,0x22,0x44,0x28,0x10,0x00,
                                     0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,
                                     0x00,0x00,0x00,0x00,0x00,0x00,0x80,0xC0,
                                     0x00,0x00,0x00,0x00,0x00,0x80,0xC0,0xE0,  //16
                                     0x00,0x00,0x00,0x00,0x80,0xC0,0xE0,0xF0,
                               0x00,0x00,0x00,0x80,0xC0,0xE0,0xF0,0xF8,
                                     0x00,0x00,0x80,0xC0,0xE0,0xF0,0xF8,0xFC,
                                     0x00,0x80,0xC0,0xE0,0xF0,0xF8,0xFC,0xFE,
                                     0x80,0xC0,0xE0,0xF0,0xF8,0xFC,0xFE,0xFF,
                                     0xC0,0xE0,0xF0,0xF8,0xFC,0xFE,0xFF,0xFF,
                                  0xE0,0xF0,0xF8,0xFC,0xFE,0xFF,0xFF,0xFF,
                                  0xF0,0xF8,0xFC,0xFE,0xFF,0xFF,0xFF,0xFF,
                                 0xF8,0xFC,0xFE,0xFF,0xFF,0xFF,0xFF,0xFF,
                                0xFC,0xFE,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
                                 0xFE,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
                                0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
                               0x00,0x7E,0x7E,0x7E,0x7E,0x7E,0x7E,0x00,
                                0x00,0x00,0x3C,0x3C,0x3C,0x3C,0x00,0x00,
                               0x00,0x00,0x00,0x18,0x18,0x00,0x00,0x00,   //31
uchar led_array_negative[]={0x7f,0xbf,0xdf,0xef,0xf7,0xfb,0xfd,0xfe};          //负极
//////////////////////////////////////                                         //595送数据
void input595(uchar dat)
        uchar b;
        shcp=0;
        for(b=0;b<8;b++)
                        da=dat&0x80;
                        dat=dat<<1;
                        shcp=1;
                        shcp=0;
////////////////////////////////////                                          //595输出数据
void output595()
        stcp=0;
        stcp=1;
void motor_foreward()
        uint motor_time;
                        if(!led_array_flag)
                         motor_time++;
                         if(motor_time==5)
                                 motor_time=0;
                                                P3=motor_run[a];
                                                a++;
                                                if(a>=8)
                                                         a=0;
void refresh_led_array()                                                     //刷新点阵
  if(!led_array_flag)
                anode_next++;
                if(anode_next==100)   //1s
                        anode_next=0;
                        anode=anode+8;
                        if(anode>240)
                                anode=0;
                 for(negative=0;negative<8;negative++)
                                 input595(led_array_anode[anode+negative]);
                                 input595(led_array_negative[negative]);
                                 output595();
        initial_timer0();
//        initial_timer1();
                refresh_led_array();
                motor_foreward();
void timer0_interrupt()interrupt 1
    led_array_count++;
         if(led_array_count==10)   //1ms
                led_array_count=0;
                !led_array_flag;
ID:896220 发表于 2021-3-24 21:39 来自触屏版 | 显示全部楼层
我想问一下 这能显示88的  还是1616的
