查看: 3253|回复: 1
单片机呼吸灯程序
ID:81203 发表于 2015-5-26 19:18 | 显示全部楼层 |阅读模式
#include<reg52.h>
sbit LED=P0^0;
void delay(unsigned int ms)
        unsigned int i=0,j=0;
        for(i=ms;i>0;i--)
                for(j=20;j>0;j--);
        unsigned int t = 50;
        unsigned int d = 1;
        while(t =t+ d)
                LED = t%2;
                delay(t*(LED==1)+(100-t)*(LED==0));
                if(t>=95||t<=5)
                     d =-d;
这个可以实现一个呼吸灯
哥-深圳:
首先,把 delay(t*(LED==1)+(100-t)*(LED==0));看做是:
(1)当LED亮的时候(LED==1)等于1,(LED==0)等于0,此时
delay(t*(LED==1)+(100-t)*(LED==0))相当于delay(t);
(2)当LED灭的时候(LED==1)等于0,(LED==0)等于1,此时
delay(t*(LED==1)+(100-t)*(LED==0))相当于delay((100-t));
        unsigned int d = 1;
        while(t =t+ d)
                LED = t%2;
                if(LED==1)
                   delay(t);
                    delay(100-t);
                if(t>=95||t<=5)
                     d =-d;
admin + 50 共享资料的积分奖励!
ID:81237 发表于 2015-5-27 01:51 | 显示全部楼层
