查看: 3068|回复: 0
独立键盘程序
ID:82008 发表于 2015-6-5 00:30 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include <reg52.h>
sbit duxu=P2^6;
sbit wexu=P2^7;
sbit key=P3^4;
uchar num;
uchar code table[]={
0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71};
void delay(uint z)
        uint x,y;
        for(x=z;x>0;x--)
                for(y=110;y>0;y--);
        wexu=1;
        P0=0xfd;
        wexu=0;
        P3=0xff;
                if(key==0)
                        delay(5);
                        if(key==0)
                                num++;
                                if(num==16)
                                        num=0;
                                while(!key);
                                delay(5);
                                while(!key);
                duxu=1;
                P0=table[num];
                duxu=0;
