查看: 2677|回复: 0
三个通道载波转发板的驱动程序
ID:82781 发表于 2015-6-13 15:55 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include <PL3201_Addr_Map.h>
#include "pl3201.h"
#include "usart.h"
#include "Protocol_layer.h"
#include"app.h"
   sbit USART_SEND=P2^2;
extern struct Device_PL3201 xdata *P_Drvier;//PL3201设备指针
extern        bit    bdata   PLC_Rxd_OK;                 // 载波接收完成标志
extern  bit    bdata   PLC_sending;
extern  bit    data    PLC_TX_EN;
void main ( void )
init_PLC3201();
init_pl3201_device();
initsys ();
for(;;)
        //        printf_usart("你好啊!\n");
           Check_sys_plc();
          if ( PLC_Rxd_OK )
         P_Drvier->plc_rx();
         PLC_Rxd_OK=0;
       if ( PLC_TX_EN )
                 PLC_TX_EN=0;
                printf_usart("Iam from channel C please check me!\r\n");
                         USART_SEND=~USART_SEND;
//Post_Messages_to_Distance(1,2,3,"HD0123456789",9) ;
#include "pl3201.h"
#include "usart.h"
#include"app.h"
  sbit USART_RX=P3^3;
  sbit USART_TX=P2^2;
extern check_usart();
void main ( void )
init_PLC3201();
initsys ();
for(;;)
        //         check_usart();
           Check_sys_plc();
          if ( PLC_Rxd_OK )
                 P_Drvier->plc_rx();
                 PLC_Rxd_OK=0;
  if(RI)
          RI=0;
         USART_RX=~USART_RX;
         SendOneByte(SBUF);
       if ( PLC_TX_EN )
             PLC_TX_EN=0;
                   USART_TX=~USART_TX;
                printf_usart("I am from channel B,plese check me!\r\n");
#include "pl3201.h"
#include "usart.h"
#include"app.h"
extern check_usart(void);
extern void SendOneByte1(unsigned char c);
void main ( void )
         char a;
init_PLC3201();
initsys ();
Show_version();
for(;;)
           check_usart();
           Check_sys_plc();
          if ( PLC_Rxd_OK )
                 P_Drvier->plc_rx();
                 PLC_Rxd_OK=0;
                /* if(RI)
                         a=SBUF;
                         RI=0;
                  SendOneByte1(a) ;
       if ( PLC_TX_EN )
         //          printf_usart("74hc595\n");
                 PLC_TX_EN=0;
