查看: 2977|回复: 0
温度测量软件(125-负55摄氏度)
ID:85764 发表于 2015-7-15 23:12 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
数码管显示部分的原理图:http://www.51hei.com/f/51hei-5.pdf
#include<reg52.h>
#define uint  unsigned int
sbit dula=P2^6;
sbit wela=P2^7;
sbit ds=P2^2;
sbit speak=P2^3;
uchar code smg_du[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x40,0x39};
uchar code smg_we[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
uchar dis_smg[3] ;
int temper;
void delay_1ms(uint t)
  uint i,j;
  for(i=0;i<t;i++)
    for(j=0;j<120;j++);
void delayus(uint t)
while(t--);
void reset()
   uchar n;
   ds=1;
   delayus(8);
   ds=0;
   delayus(80);
   ds=1;
   delayus(8);
   n=ds;
   delayus(4);
void write_byte(uchar dat)
uchar i;
for(i=0;i<8;i++)
  ds=0;
  ds=dat&0x01;
  delayus(5);
  ds=1;
  dat>>=1;
uchar read_byte(uchar value)
uchar i;
for(i=0;i<8;i++)
  ds=0;
  value>>=1;
  ds=1;
  if(ds==1)
   value|=0x80;
  delayus(4);
return value;
void write_com()
  reset();
  write_byte(0xcc);
  write_byte(0x44);
int read_temper()
int temper;
uchar a,b;
reset();
write_byte(0xcc);
write_byte(0xbe);
EA=0;
a=read_byte();
b=read_byte();
EA=1;
temper=b;
temper<<=8;
temper|=a;
temper*=0.625;
return temper;
void display(uchar dat1,uchar dat2)
  P0=0x00;
  dula=1;dula=0;
  P0=smg_we[dat1];
  wela=1;wela=0;
  P0=smg_du[dat2];
  dula=1;dula=0;
  delay_1ms(5);
uchar i;
  write_com();
  temper=read_temper();
     //temper-=200;
  delay_1ms(1);
  for(i=0;i<10;i++)
   if(temper>250)
    speak=0;
    delay_1ms(10);
    speak=1;
   if(temper<0)
    temper=~temper+1;
    for(i=0;i<200;i++)
     display(1,10);
     display(2,(temper/100));
     display(3,(temper/10%10));
     display(4,11);
    for(i=0;i<100;i++)
     display(4,11);
