查看: 3942|回复: 0
单片机唱歌最炫民族风
ID:79544 发表于 2015-7-23 14:59 | 显示全部楼层 |阅读模式
  1. /******************************************************************************/
  2. /**程序名称:单片机播放欢乐颂与最炫民族风片段
  3. /**其    他:用于时钟周期为12MHz的STC89C52单片机
  4. /******************************************************************************/
  5. #include<reg52.h>
  6. sbit BUZZER = P1^7;
  7. #define uchar unsigned char
  8. #define uint  unsigned int
  9. #define REST         36                        //休止符
  10. #define A                  0                  //低音1
  11. #define AB          1                  //低音1.5
  12. #define B                  2                  //低音2
  13. #define BC          3                  //低音2.5
  14. #define C                  4                  //低音3
  15. #define D                  5                  //低音4
  16. #define DE                 6                  //低音4.5
  17. #define E                 7                       //低音5
  18. #define EF          8                  //低音5.5
  19. #define F                  9                  //低音6
  20. #define FG          10          //低音6.5
  21. #define G                 11          //低音7
  22. #define L                  12          //中音1
  23. #define LM          13          //中音1.5
  24. #define M                  14          //中音2
  25. #define MN          15          //中音2.5
  26. #define N                  16                 //中音3
  27. #define O                  17          //中音4
  28. #define OP          18          //中音4.5
  29. #define P                  19          //中音5
  30. #define PQ          20          //中音5.5
  31. #define Q                  21          //中音6
  32. #define QR          22          //中音6.5
  33. #define R                  23          //中音7
  34. #define S                  24          //高音1
  35. #define SU          25          //高音1.5
  36. #define U                  26          //高音2
  37. #define UV          27          //高音2.5
  38. #define V                  28          //高音3
  39. #define W                  29          //高音4
  40. #define WX          30          //高音4.5
  41. #define X                  31          //高音5
  42. #define XY          32          //高音5.5
  43. #define Y                  33          //高音6
  44. #define YZ          34          //高音6.5
  45. #define Z                  35          //高音7
  46. //音阶
  47. uchar code m_note[][2] = {
  48. {248,136},{248,243},{249,88},{249,184},{250,18},{250,103},{250,184},{251,3},{251,75},
  49. {251,143},{251,206},{252,11},{252,67},{252,121},{252,172},{252,219},{253,9},{253,51},
  50. {253,91},{253,129},{253,165},{253,199},{253,231},{254,5},{254,33},{254,60},{254,85},
  51. {254,109},{254,132},{254,153},{254,173},{254,192},{254,210},{254,227},{254,243},{255,2},
  52. {0,0},
  53. };
  54. //音符(1对应三十二分音符,32对应全音符)
  55. uchar code display[][2] = {
  56. //欢乐颂
  57. {N,8},{N,8},{O,8},{P,8},{P,8},{O,8},{N,8},{M,8},{L,8},{L,8},{M,8},{N,8},{N,12},{M,4},{M,8},{0xff,8},
  58. {N,8},{N,8},{O,8},{P,8},{P,8},{O,8},{N,8},{M,8},{L,8},{L,8},{M,8},{N,8},{M,12},{L,4},{L,8},{0xff,8},
  59. {M,8},{M,8},{N,8},{L,8},{M,8},{N,4},{O,4},{N,8},{L,8},{M,8},{N,4},{O,4},{N,8},{M,8},{L,8},{M,8},{E,8},
  60. {N,8},{N,8},{O,8},{P,8},{P,8},{O,8},{N,8},{M,8},{L,8},{L,8},{M,8},{N,8},{M,12},{L,4},{L,8},{0xff,8},
  61. {M,8},{M,8},{N,8},{L,8},{M,8},{N,4},{O,4},{N,8},{L,8},{M,8},{N,4},{O,4},{N,8},{M,8},{L,8},{M,8},{E,8},
  62. {N,8},{N,8},{O,8},{P,8},{P,8},{O,8},{N,8},{M,8},{L,8},{L,8},{M,8},{N,8},{M,12},{L,4},{L,8},{0xff,8},
  63. //乐谱(最炫民族风)
  64. {N,8},{F,4},{F,4},{L,8},{N,8},{M,4},{M,2},{N,2},{M,4},{L,4},
  65. {M,4},{L,4},{F,8},{N,8},{F,4},{F,4},{L,8},{N,8},
  66. {P,4},{M,2},{N,2},{M,4},{L,4},{M,4},{L,4},{G,4},{E,4},
  67. {N,8},{F,4},{F,4},{L,8},{N,8},{M,4},{M,2},{N,2},{M,4},{L,4},
  68. {M,4},{L,4},{F,4},{E,4},{N,8},{F,4},{F,4},{L,8},{N,8},
  69. {P,4},{N,4},{0xff,24},//前奏
  70. {F,8},{F,4},{E,4},{F,8},{F,4},{L,4},{L,8},{M,4},{L,4},{F,8},
  71. {0xff,8},{L,8},{L,4},{E,4},{L,4},{M,4},{N,4},{P,4},{P,4},{N,4},
  72. {M,8},{N,8},{0xff,8},{Q,4},{Q,4},{Q,4},{P,4},{N,4},{N,8},{L,4},
  73. {F,4},{F,4},{F,4},{N,4},{M,8},{0xff,8},{N,4},{N,4},{P,4},{N,4},
  74. {M,4},{N,4},{M,4},{L,4},{F,8},{E,8},{F,8},{0xff,8},
  75. {F,8},{F,4},{E,4},{F,8},{F,4},{L,4},{L,8},{M,4},{L,4},{F,8},
  76. {0xff,8},{L,8},{L,4},{E,4},{L,4},{M,4},{N,4},{P,4},{P,4},{N,4},
  77. {M,8},{N,8},{0xff,8},{Q,4},{Q,4},{Q,4},{P,4},{N,4},{N,8},{L,4},
  78. {F,4},{F,4},{F,4},{N,4},{M,8},{0xff,8},{N,4},{N,4},{P,4},{N,4},
  79. {M,4},{N,4},{M,4},{L,4},{F,8},{E,8},{F,8},{0xff,8},
  80. {N,4},{N,4},{P,4},{N,4},{N,4},{P,4},{P,4},{Q,4},{S,4},{Q,4},
  81. {P,8},{Q,8},{0xff,8}, //此处有变调
  82. {F,8},{F,4},{E,4},{F,8},{L,8},{M,4},{N,2},{M,2},{L,4},{M,4},
  83. {N,8},{0xff,8},{F,4},{Q,4},{Q,4},{P,4},{M,4},{N,2},{M,2},
  84. {L,4},{M,4},{N,8},{0xff,8},{0xff,16},{L,4},{F,4},{F,4},{L,4},
  85. {M,8},{E,4},{E,4},{N,4},{P,4},{N,4},{M,4},{L,8},{0xff,8},
  86. {F,4},{L,4},{M,4},{N,4},{M,4},{L,4},{E,4},{C,4},{F,8},{0xff,8},{0xff,16},
  87. {F,8},{F,4},{E,4},{F,8},{L,8},{M,4},{N,2},{M,2},{L,4},{M,4},
  88. {N,8},{0xff,8},{F,4},{Q,4},{Q,4},{P,4},{M,4},{N,2},{M,2},
  89. {L,4},{M,4},{N,8},{0xff,8},{0xff,16},{L,4},{F,4},{F,4},{L,4},
  90. {M,8},{E,4},{E,4},{N,4},{P,4},{N,4},{M,4},{L,12},{L,4},
  91. {F,4},{L,4},{M,4},{N,4},{P,4},{N,4},{N,4},{P,4},{Q,8},{0xff,8},{0xff,8},
  92. {Q,6}, {Q,2},{Q,4},{Q,4},{Q,6},{P,2},{N,4},{M,4},{M,6},{M,2},{N,6},{P,2},{N,6},{M,2},
  93. {L,6},{F,2},{F,8},{F,4},{E,4},{F,8},{F,4},{L,4}, {M,4},{N,2},{M,2},        {L,4},{M,4},{N,8},{0xff,8},
  94. {Q,4},{P,4},{N,4},{M,4},{P,4},{N,4},{M,4},{L,4},{L,8},{0xff,8},{F,2}, {A,2},{B,2},{C,2},{B,2},
  95. {A,2}, {F,2},{A,2},
  96. {N,4},{N,4},{P,4},{N,4},{N,4},{P,4},{P,4},{Q,4},{S,4},{Q,4},
  97. {P,8},{Q,8},{0xff,8}, //此处有变调
  98. {F,8},{F,4},{E,4},{F,8},{L,8},{M,4},{N,2},{M,2},{L,4},{M,4},
  99. {N,8},{0xff,8},{F,4},{Q,4},{Q,4},{P,4},{M,4},{N,2},{M,2},
  100. {L,4},{M,4},{N,8},{0xff,8},{0xff,16},{L,4},{F,4},{F,4},{L,4},
  101. {M,8},{E,4},{E,4},{N,4},{P,4},{N,4},{M,4},{L,8},{0xff,8},
  102. {F,4},{L,4},{M,4},{N,4},{M,4},{L,4},{E,4},{C,4},{F,8},{0xff,8},{0xff,16},
  103. {F,8},{F,4},{E,4},{F,8},{L,8},{M,4},{N,2},{M,2},{L,4},{M,4},
  104. {N,8},{0xff,8},{F,4},{Q,4},{Q,4},{P,4},{M,4},{N,2},{M,2},
  105. {L,4},{M,4},{N,8},{0xff,8},{0xff,16},{L,4},{F,4},{F,4},{L,4},
  106. {M,8},{E,4},{E,4},{N,4},{P,4},{N,4},{M,4},{L,12},{L,4},
  107. {F,4},{L,4},{M,4},{N,4},{P,4},{N,4},{N,4},{P,4},{Q,8},{0xff,8},{0xff,8},
  108. {0,0xff},
  109. };
  110. uchar time_h,time_l;
  111. void Delay(uchar x);
  112. void main()
  113. {
  114.         uchar j;
  115.         uint i;
  116.         TMOD = 0x01;
  117.         ET0 = 1;
  118.         EA = 1;
  119.         TR0 = 1;
  120.         i = 0;
  121.         j = 0;
  122.         while(1)
  123.         {
  124.                 while(display[i][1] != 0xff)
  125.                 {
  126.                         if(display[i][0] == 0xff)
  127.                         {
  128.                                 TR0 = 0;
  129.                                 Delay(display[i][1]);
  130.                             BUZZER = 1;
  131.                         }
  132.                         else
  133.                         {
  134.                                 time_h = m_note[display[i][0]][0];
  135.                                 time_l = m_note[display[i][0]][1];
  136.                                 TH0 = time_h;
  137.                                 TL0 = time_l;
  138.                                 ET0 = 1;
  139.                                 TR0 = 1;
  140.                                 Delay(display[i][1]);
  141.                                 TR0 = 0;
  142.                                 ET0 = 0;
  143.                             BUZZER = 1;
  144.                         }
  145.                         i++;
  146.                 }
  147.                 i = 0;
  148.         }
  149. }
  150. void Timer0() interrupt 1
  151. {
  152.         TR0 = 0;
  153.         TH0 = time_h;
  154.         TL0 = time_l;
  155.         BUZZER = ~BUZZER;
  156.         TR0 = 1;
  157. }
  158. void Delay(uchar x)
  159. {
  160.         uint i,j;
  161.         for(i = 0;i < x;i++)
  162.                 for(j = 0;j < 12000;j++);
  163. }
admin + 50 共享资料的积分奖励!
