查看: 2657|回复: 2
帮帮呗 怎么写实现一键切换功能;我写的主函数没效果,其他函数正常
ID:81211 发表于 2015-9-4 09:18 | 显示全部楼层 |阅读模式
#include<reg51.h>
#include"LCD.h"
#include"ds1302.h"
#include"temp.h"
sbit check=P1^0;
void timeLcdDisplay();
void tempLcdDisplay(int temp);
void time_transfer();
void temp_transfer();
{check=1;
        while(1)  //想在温度和时间之间一键切换
if(check==0)
Delay1ms(10);
        while(check==0)
        {temp_transfer();}
else{
time_transfer();
{  uint a;
LcdInit();
        Ds1302Init();
        for(a=0;a<60;a++)
        Ds1302ReadTime();
                timeLcdDisplay();
{uint a,b;
LcdInit();                         //3êˉLCD1602
        LcdWriteCom(0x88);        //D′μ· 80±íê3êμ·
        LcdWriteData('C');
        for(a=0;a<200;a++)
        tempLcdDisplay(Ds18b20ReadTemp());
                        Delay1ms(200);
        LcdWriteCom(0x80+0X40);
        LcdWriteData('0'+TIME[2]/16);                                //ê±
        LcdWriteData('0'+(TIME[2]&0x0f));
        LcdWriteData('-');
        LcdWriteData('0'+TIME[1]/16);                                //·
        LcdWriteData('0'+(TIME[1]&0x0f));
        LcdWriteData('-');
        LcdWriteData('0'+TIME[0]/16);                                //
        LcdWriteData('0'+(TIME[0]&0x0f));
        LcdWriteCom(0x80);
        LcdWriteData('2');
        LcdWriteData('0');
        LcdWriteData('0'+TIME[6]/16);                        //ê
        LcdWriteData('0'+(TIME[6]&0x0f));
        LcdWriteData('-');
        LcdWriteData('0'+TIME[4]/16);                        //
        LcdWriteData('0'+(TIME[4]&0x0f));
        LcdWriteData('-');
        LcdWriteData('0'+TIME[3]/16);                        //è
        LcdWriteData('0'+(TIME[3]&0x0f));
        LcdWriteCom(0x8D);
        LcdWriteData('0'+(TIME[5]&0x07));        //Dú
unsigned char datas[] = {0, 0, 0, 0, 0}; //¨òêy×é
        float tp;
        if(temp< 0)                                //μ±èμaoêy
                  LcdWriteCom(0x80);                //D′μ· 80±íê3êμ·
            LcdWriteData('-');                  //êo
                //òòaáèμèêêμêèμ21£ùò1£ùè·′ó3-
                temp=temp-1;
                temp=~temp;
                tp=temp;
                temp=tp*0.0625*100+0.5;
                //ááDêyμí*100£+0.5êéáè£òòaCóμêy×aaDíμê±oò°Dêyμ
                //oóμêy×ˉè¥μ£21üê·′óóú0.5£+0.5oó′óóú0.5μíê1á£Dóú0.5μí
                //óé0.5£1êúDêyμoó£
            LcdWriteData('+');                 //êy
                tp=temp;//òòaêyY′|àíóDDêyμùòè3òμDí±á
                //è1èêyμ′£′yêyμ-íê21ü±éí
                //óé0.5£1êúDêyμoó£
        datas[0] = temp / 10000;
        datas[1] = temp % 10000 / 1000;
        datas[2] = temp % 1000 / 100;
        datas[3] = temp % 100 / 10;
        datas[4] = temp % 10;
        LcdWriteCom(0x82);                  //D′μ· 80±íê3êμ·
        LcdWriteData('0'+datas[0]); //°ù
        LcdWriteCom(0x83);                 //D′μ· 80±íê3êμ·
        LcdWriteData('0'+datas[1]); //ê
        LcdWriteCom(0x84);                //D′μ· 80±íê3êμ·
        LcdWriteData('0'+datas[2]); //
        LcdWriteCom(0x85);                //D′μ· 80±íê3êμ·
        LcdWriteData('.');                 //ê .ˉ
        LcdWriteCom(0x86);                 //D′μ· 80±íê3êμ·
        LcdWriteData('0'+datas[3]); //êDêyμ
        LcdWriteCom(0x87);                 //D′μ· 80±íê3êμ·
        LcdWriteData('0'+datas[4]); //êDêyμ
ID:74784 发表于 2015-9-4 10:50 | 显示全部楼层
你想别人怎么帮你???
ID:81211 发表于 2015-9-4 10:59 | 显示全部楼层
        uchar System_Mode;
                if(key0==0)
                        System_Mode=1;
                if(key0==1)
                        System_Mode=2;
   switch(System_Mode)
                { case 1:
                        temp_transfer();
      break;
      case 2:
      time_transfer();
                        break;
                        default:
                        break;}
LcdInit();
        Ds1302Init();
        Ds1302ReadTime();
                timeLcdDisplay();
                if(key0==0) break;
{LcdInit();
        LcdWriteCom(0x88);
        LcdWriteData('C');
                        Delay1ms(100);
                if(key0==1) break;
