查看: 2842|回复: 8
求大神指点。
ID:89372 发表于 2015-9-4 15:32 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include<reg52.h>
typedef unsigned char uchar8;
//¸ù¾Yó2¼t°′¼ü°′ÏÂËù¶Ôó|μÄÖ
#define key_value_1 0xe0
#define key_value_2 0xd0
#define key_value_3 0xb0
#define key_value_4 0x70
#define key_null 0xf0
//¶¨òå°′¼ü°′ÏÂμÄ·μ»ØÖμ
#define key_down 0x08
#define key_long 0x04
#define key_continue 0x02
#define key_up 0x01
//¶¨òå°′¼ü3¤°′£¬¶ì°′
#define key_long_num 200
#define key_continue_num 50
//¶¨òå°′¼üμÄ×′ì¬
#define key_state_init 0  //3õê¼×′ì¬
#define key_state_wobble 1 //Ïû¶¶
#define key_state_press 2 //¶ì°′
#define key_state_long 3 //3¤°′
#define key_state_continue 4 //ᬷ¢
#define key_state_release 5//°′¼üêí·Å
bit timecount=0;//½øèëÖD¶Ï±ê־λ
//¶¨òå°′¼üμÄIO¿ú
sbit key_1=P1^4;
sbit key_2=P1^5;
sbit key_3=P1^6;
sbit key_4=P1^7;
//uchar8 count=0;
void ys1ms(uint z)
  uchar8 y;
  while(z--)
          for(y=0;y<115;y++)
//éèÖÃÕaËĸöIO¿úÎa¶á×′ì¬
void key_csh(void)
  key_1=1;
  key_2=1;
  key_3=1;
  key_4=1;
//»ñè¡°′¼üÖμ
static uchar8 getkey_num(void)
  if(key_1==0) return key_value_1;
  if(key_2==0) return key_value_2;
  if(key_3==0) return key_value_3;
  if(key_4==0) return key_value_4;
  return key_null;
//°′¼üé¨Ãæ3ìDò
void  key_scan(uint *pkeyvalue)
  uint   temp=key_null;
  static uint keystate=key_state_init;
  static uint keytimecount=0;
  static uint keylastnum=key_null;//±£′æ°′¼üêí·ÅμÄÖμ
  temp=getkey_num();
  switch(keystate)
   case key_state_init:
     if(temp!=key_null)
              keystate=key_state_wobble;
           break;
        case key_state_wobble:
              keystate=key_state_press;
           break;
        case key_state_press:
             if(temp!=key_null)
                     keylastnum=temp;//±£′æ°′¼üÖ죬òÔ±ãÔúêí·Å°′¼üêÇ·μ»Ø°′¼üÖμ
                         temp|=key_down;//¼Ç¼°′¼ü°′ÏÂ
                         keystate=key_state_long;
                     keystate=key_state_init;//′Ëê±Ã»óD°′¼ü°′Ͼí·μ»Øμ½3õê¼×′ì¬
          break;
        case key_state_long:
            if(temp!=key_null)//Ôù′ÎÅD¶Ï°′¼üêÇ·ñ»1′|óú°′ÏÂ×′ì¬
                      if(timecount==1)
                            timecount=0;
                     if(++keytimecount>key_long_num)
                             keytimecount=0;
                                 temp|=key_long;//3¤°′°′¼üê¼tòÑ·¢éú
                                 keystate=key_state_continue;//½øèëᬷ¢×′ì¬
                   keystate=key_state_release;
           break;
    case key_state_continue:
            if(temp!=key_null)
                        if(timecount==1)
                            if(++keytimecount>key_continue_num)
                                 keytimecount=0;
                                 temp|=key_continue;
           break;
        case key_state_release:
          keylastnum|=key_up;
                temp=keylastnum;
                break;
                default:
                break;
         *pkeyvalue=temp;
                //P0=*pkeyvalue;
  uint keyvalue=key_null;
  IE=0x82;//¿a¶¨ê±Æ÷ÖD¶Ïóë×üÖD¶Ï
  TMOD=0x01;//éèÖö¨ê±Æ÷Îa·½ê½1
  TH0=0xee;
  TL0=0x00;
  TR0=1;//¿aÆô¶¨ê±Æ÷
  key_scan(&keyvalue);
  P0=keyvalue;
  //if(keyvalue == (key_value_1 | key_down)) P0 = 0xff ;
  //else
  //P0=0XFE;
  /*if(keyvalue == (key_value_1 | key_long)) P0 = 0x00 ;
  if(keyvalue == (key_value_1 | key_continue)) { P0 ^= 0xf0;}
  if(keyvalue == (key_value_1 | key_up)) P0 = 0xa5 ;*/
void time0_int() interrupt 1
  TH0=0xee;
  TL0=0x00;
  timecount=1;
这是源码,在每个case中我用P0=temp调试看到结果跟case中的temp值是一样的,为什么出了switch,将*pkeyvalue=temp;就不对了。我按了按键就等于0x0f或上我按下按键的那个值,搞得我现在好郁闷的。
ID:60379 发表于 2015-9-4 17:10 | 只看该作者
这程序,篇幅长、没解释、乱码,谁愿意看啊?
ID:89372 发表于 2015-9-4 22:27 | 只看该作者
RE: 求大神指点。
//宏定义根据硬件来定义按键按下时的值
//定义按下,长按,连发,释放时按键的值
#define key_up 0x01
//定义按键时间为长短按
//定义按键的六种状态
bit timecount=0;
//定义按键的IO
sbit key_1=P1^4;
sbit key_2=P1^5;
sbit key_3=P1^6;
sbit key_4=P1^7;
//初始化按键IO为读状态
void key_csh(void)
  key_1=1;
  key_2=1;
  key_3=1;
  key_4=1;
//通过按键按下的时候能够获取对应的按键值
  return key_null;
//判断按键是否为长按,短按,连发释放程序
  uint   temp=key_null;//反馈按键的值
  static uint keylastnum=key_null;//存储最后的按键值
  temp=getkey_num();//获取按键值
  switch(keystate)
     if(temp!=key_null)
           break;
           break;
             if(temp!=key_null)
                     keylastnum=temp;//±
                         temp|=key_down;//
          break;
                      if(timecount==1)
                            timecount=0;
                             keytimecount=0;
                                 temp|=key_long;//3
           break;
            if(temp!=key_null)
                        if(timecount==1)
                                 keytimecount=0;
                                 temp|=key_continue;
           break;
          keylastnum|=key_up;
                temp=keylastnum;
                break;
                default:
                break;
         *pkeyvalue=temp;
                //P0=temp;
  TH0=0xee;
  TL0=0x00;
  timecount=1;
为了减少误解我没有附上主函数,放入每个case中P0=temp,temP的值与按键值或上按键状态值是相等的,但是出了switch   *pkeyvalue=temp; P0=temp;temp值就不知道为什么不对了。初来乍到不知道怎么发帖还望多多包涵。
ID:89423 发表于 2015-9-5 12:01 | 只看该作者
一样不懂
ID:1 发表于 2015-9-5 23:22 来自触屏版 | 只看该作者
这是一个按键扫描程序吗,
ID:84147 发表于 2015-9-6 11:33 | 只看该作者
这程序。看起来费劲啊
ID:89372 发表于 2015-9-6 12:54 | 只看该作者
admin 发表于 2015-9-5 23:22
这是一个按键扫描程序吗,
对这是一个按键扫描。分别为按下,长,短按,释放着几种状态。按道理来说着这是一个址传递。可以改变变量值。但是目前不知道为什么*pkeyvalue=temp;*pkeyvalue这个值出case的就不对了。怎么写才能让你们不费劲看呢?是需要多少行?
ID:89372 发表于 2015-9-6 13:01 | 只看该作者
血一 发表于 2015-9-6 11:33
这程序。看起来费劲啊
球指点发帖一般怎么发,才能让你们轻松看懂回复。
ID:89488 发表于 2015-9-6 13:29 | 只看该作者
好长啊,,,一般都是自己找错误,别人找的话多少时间啊
