查看: 4229|回复: 0
STM8外部中断配置详解
ID:90014 发表于 2015-9-14 12:56 | 只看该作者 回帖奖励 |正序浏览 |阅读模式
1:引用STM8 的中断库
  #include "stm8s_exti.h"
2:配置外部中断的触发管脚
GPIO_Init(LEDS_PORT,MB,GPIO_MODE_IN_FL_IT );
或者
GPIO_Init(LEDS_PORT,MB,GPIO_MODE_IN_PU_IT );
3:初始化中断
EXTI_DeInit();
EXTI_SetTLISensitivity(EXTI_TLISENSITIVITY_RISE_ONLY);//下降沿触发中断
EXTI_SetExtIntSensitivity((EXTI_PORT_GPIOD),EXTI_SENSITIVITY_RISE_ONLY);
4:中断服务子程序的配置
(1)外部定义中断服务子程序
@far @interrupt void EXTI3 (void)
  disableInterrupts();
  counter ();
  enableInterrupts();
(2)声明外部中断子程序
extern void EXTI3 ();
(3)配置外部中断子程序向量表
struct interrupt_vector const _vectab[] = {
{0x82, (interrupt_handler_t)_stext},
{0x82, NonHandledInterrupt},
{0x82, EXTI3              },
{0x82, TIM2_UPD_OVF_TRG_IRQHandler },
{0x82, UART_RI            },
注:在配置中断实以上三部缺一不可
