查看: 11644|回复: 11
电位器控制电机转速测量速度单片机程序,AD,PWM,测速,1602液晶
ID:91350 发表于 2015-10-1 00:27 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include<reg52.h>//51单片机头文件
#define uchar unsigned char//宏定义
//uchar code smg_du[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};//数码管段码
//uchar code smg_we[]={0x00,0x04,0x08,0x0c,0x10,0x14,0x18,0x1f};//数码管位码
uchar code digit[]={"0123456789"};//定义字符数组数字
uchar disp[8];//存储拆开的数
uint cnt;//中断次数
uchar v;//电机0速度
uchar date,num,CYCLE,PWM_ON;
sbit sda=P2^0;
sbit scl=P2^1;
uchar flag;        //计满1秒钟标志位
uint i;
char j,k=5;
sbit PWM=P1^0; //pwm输出口
sbit rs=P2^6;//数据命令选择
sbit rw=P2^5;//读写控制信号
sbit e=P2^7;//使能信号
void delay1()                //微秒延时
void start()                //I2C开始信号
  sda=1;
     delay1();
   scl=1;
     delay1();
   sda=0;
        delay1();
void stop()              //I2C停止信号
  sda=0;
     delay1();
   scl=1;
     delay1();
   sda=1;
     delay1();
void respons()                //I2C应答信号
        uchar i;
        scl=1;
        delay1();
        while((sda==1)&&(i<250))i++;
        scl=0;
        delay1();
void writebyte(uchar date)                //I2C写信号
        uchar i,temp;
        temp=date;
        for(i=0;i<8;i++)
                temp=temp<<1;
                scl=0;
                delay1();
                sda=CY;
                delay1();
                scl=1;
                delay1();
        scl=0;
        delay1();
        sda=1;
        delay1();
uchar readbyte()                //I2C读信号
        uchar i,k;
        scl=0;
        delay1();
        sda=1;
        for(i=0;i<8;i++)
                scl=1;
                delay1();
                k=(k<<1)|sda;
                scl=0;
                delay1();
        return k;
void init1()                        //初始化
        scl=1;
        delay1();
        sda=1;
        delay1();
uchar read_ad(uchar channel)                //读取ad转换结果
        uchar num;
        start();
        writebyte(0x90);
        respons();
        writebyte(0x40|channel);
        respons();
        start();
        writebyte(0x91);
        respons();
        num=readbyte();
        stop();
        return num;
void delay_50us(uint t)//50us延时函数
uchar j;
for(;t>0;t--)
    for(j=19;j>0;j--);
void write_com(uchar com)//写地址
e=0;
rs=0;
rw=0;
P0=com;
delay_50us(10);
e=1;
delay_50us(10);
e=0;
void write_data(uchar dat)// 写数据
e=0;
rs=1;
rw=0;
P0=dat;
delay_50us(10);
e=1;
delay_50us(10);
e=0;
void init(void)//液晶初始化
  delay_50us(300);
  write_com(0x38);
  delay_50us(100);
  write_com(0x38);
  delay_50us(100);
  write_com(0x38);
  write_com(0x38);
  write_com(0x08);
  write_com(0x01);
  write_com(0x06);
  write_com(0x0c);
void writeaddress(uchar x)//指定字符的实际地址
  write_com(x|0x80);//显示位置的确定方法规定为“80h+地址码x“
void display_sym(void)//显示速度提示符
writeaddress(0x00);//写显示地址第一行第一列
write_data('v');//写数据v
write_data('=');//写数据=
void dispose()//
disp[0]=v/1000;
disp[1]=(v%1000)/100;
disp[2]=(v/100)/10;
disp[3]=v%10;
void display_val(void)
writeaddress(0x02);//写显示地址,第一行第三列
  write_data(digit[disp[0]]);//千
  write_data(digit[disp[1]]);//百
  write_data(digit[disp[2]]);//时
  write_data(digit[disp[3]]);//个
void display_uint(void)//显示速度单位
  writeaddress(0x06);//第1行第7列
  write_data('r');//千
  write_data('/');//百
  write_data('m');//时
  write_data('i');//个
  write_data('n');//个
void initial()//初始化
TMOD=0x51; //定时器T1工作与计数器模式1,定时器T0工作于计数器模式1
RCAP2H=(65536-50000)/256;
RCAP2L=(65536-50000)%256;
TH0=(65536-1000)/256;
TL0=(65536-1000)%256;
ET0=1;
TR0=1;
ET2=1;
TR2=1;
EA=1;
init();
init1();
v=0;
CYCLE = 100;
initial();
cnt=0;
display_sym();
display_uint();
num=num=read_ad(0);
PWM_ON=num;
TR1=1;
TH1=0;
TL1=0;
flag=0;        // 时间还未满1分钟
while(flag==0);        // 时间未满等待
v=(TH1*256+TL1)*60/20;        // 计算速度,每周产生20个脉冲
dispose();
display_val();
void time2() interrupt 5//定时器T2中断服务程序
TF2=0;
cnt++;
if(cnt==20)
flag=1;
cnt=0;
void tim(void) interrupt 1 using 1
static unsigned char count; //
TL0=(65536-1000)%256;//定时1mS
if (count==PWM_ON)
     PWM = 1; //灯灭
  count++;
if(count == CYCLE)
    count=0;
        if(PWM_ON!=0) //如果左右时间是0 保持原来状态
           PWM = 0;//灯亮
收藏收藏2 分享淘帖 顶顶 踩踩
ID:90625 发表于 2015-10-1 22:12 | 只看该作者
什么东东呀?想看看
ID:79544 发表于 2015-10-3 12:16 | 只看该作者
有图和资料吗?分享出来,好东西就要分享。
ID:88707 发表于 2015-10-5 15:11 | 只看该作者
没图看着很吃力啊
ID:83018 发表于 2015-10-9 15:33 | 只看该作者
有图吗
ID:92134 发表于 2015-10-12 11:57 | 只看该作者
感谢楼主
ID:79544 发表于 2015-11-18 17:27 | 只看该作者
楼主是用什么AD芯片
ID:76408 发表于 2015-11-18 18:15 | 只看该作者
楼主辛苦了,我正需要,最好再发个图好吗?
ID:96218 发表于 2015-11-18 19:10 | 只看该作者
最好上个图  大家一起学习一下
ID:183120 发表于 2017-6-20 15:27 | 只看该作者
学习了,但是没图,就懵逼了
ID:248805 发表于 2017-11-13 09:25 | 只看该作者
没看懂。。。。。
ID:281525 发表于 2018-2-1 18:01 | 只看该作者
v=(TH1*256+TL1)*60/20;     这个怎么理解啊    我看了半天也看不懂呢    好心人教了
