查看: 2105|回复: 1
一个串口加LCD显示的测速程序
ID:95054 发表于 2015-11-8 13:26 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include<reg51.h>
#include<intrins.h>
#include<lcd.h>
void Delayms() ;
sbit LED1=P2^7;
unsigned int send[4]={0,1,2,3};
unsigned char code digit[ ]={"0123456789"};
unsigned char lcd0,lcd1,lcd2,lcd3;
int zhuan,count=0,msec;
int ge,shi,bai,qian;
void WriteAddress(unsigned char x)
     LcdWriteCom(x|0x80);
void Delayms(unsigned int c)
    unsigned char a, b;
    for (;c>0;c--)
                for (b=10;b>0;b--)
                        for (a=10;a>0;a--);
void counter(void) interrupt 0
EX1=0;       //1Øía2¿ÖD¶Ï1
count++;
  EX1=1;
Delayms(10);        //¿aía2¿ÖD¶Ï1
     return;
void Timer_0(void) interrupt 1
   TH0=0x4B;      //50ms¶¨ê±
   TL0=0xFF;
   msec++;
   if(msec==20)      //50*20=1S
{    EX0=0;                        //1Øía2¿ÖD¶Ï0
     msec=0;
     zhuan=count-1;
     count=0;
           TH0=0x4B;     //ÕaàïÖØD¼ÆêyÆ÷¸33õÖμ50ms¶¨ê±
     TL0=0xFF;
           EX0=1;          //¿aía2¿ÖD¶Ï0
void display_sym(void)
  WriteAddress(0x00);
        LcdWriteData('v');
        LcdWriteData('=');
void display_unit(void)
  WriteAddress(0x06);
        LcdWriteData('r');
        LcdWriteData('/');
        LcdWriteData('m');
        LcdWriteData('i');
        LcdWriteData('n');
void uart_init(void)
        SCON=0X50;
        TMOD=0X20;
        PCON=0X80;//2¨ìØÂê¼ó±¶
        TH1=0XFD;
        TL1=0XFD;
        TR1=1;
void jisuan()
{    int i=0;
          zhuan=zhuan*60;
                send[0]=zhuan/1000;
                send[1]=(zhuan%1000)/100;
                send[2]=(zhuan%100)/10;
                send[3]=zhuan%10;
        for(i=0;i<4;i++)
                SBUF='0'+send;
                while(!TI);
                TI=0;
        lcd0=send[0];
        lcd1=send[1];
        lcd2=send[2];
        lcd3=send[3];
        WriteAddress(0x02);
        LcdWriteData(digit[lcd0]);
        LcdWriteData(digit[lcd1]);
        LcdWriteData(digit[lcd2]);
        LcdWriteData(digit[lcd3]);
        zhuan=0;
        Delayms(10) ;
void int_all()
LED1=1;
zhuan=0;
count=0;        //3õê¼»ˉzμÄÖμ
TMOD=0x01;      //Äú2¿ÖD¶Ï¶¨ê±Æ÷Ñ¡Ôñ
TH0=0x47;      //50ms¶¨ê±
TL0=0xC9;
EA=1;       //¿aÖD¶Ï×ü¿a1Ø
ET0=1;       //¿aÄú2¿ÖD¶Ï0
TR0=1;       //¼Æê±Æ÷¿aê¼1¤×÷
IT0=1;       //ía2¿ÖD¶Ï0ÎaϽμÑØê½′¥·¢
void main ()
        LcdInit();
        int_all();
        uart_init();
        display_sym();
  display_unit();
                if(zhuan>0)
                LED1=0;
          jisuan();
D:\新建文件夹\Backup\我的文档\My Pictures\IMG_20151108_132257.jpg
ID:95054 发表于 2015-11-8 13:28 | 只看该作者
这里求助一下,我定时器是50ms,中断是1s算一次,可是LCD和串口是50ms刷新一次数据这正常吗?
