查看: 5498|回复: 0
关于5410A/D单片机的A/D转换测五伏电压的C51程序
ID:23029 发表于 2010-4-12 16:16 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
汇编语言看懂了,但是改不成C51的程序,请各位高手能帮我一下,谢谢!
LED_MCU_START    EQU    P3.7
ADC_CONTR    EQU    0C5H
ADC_DATA      EQU    0C6H
;ADC_LOW2     EQU    0BEH
P1M0        EQU       91H
P1M1        EQU       92H
ADC_Power_On_Speed_Channel_0   EQU   11100000B
ADC_Power_On_Speed_Channel_1   EQU   11100001B
ADC_Power_On_Speed_Channel_2   EQU   11100010B
ADC_Power_On_Speed_Channel_3   EQU   11100011B
ADC_Power_On_Speed_Channel_4   EQU   11100100B
ADC_Power_On_Speed_Channel_5   EQU   11100101B
ADC_Power_On_Speed_Channel_6   EQU   11100110B
ADC_Power_On_Speed_Channel_7   EQU   11100111B
ADC_Channel_0_Result      EQU    30H
ADC_Channel_1_Result      EQU    31H
ADC_Channel_2_Result      EQU    32H
ADC_Channel_3_Result      EQU    33H
ADC_Channel_4_Result      EQU    34H
ADC_Channel_5_Result      EQU    35H
ADC_Channel_6_Result      EQU    36H
ADC_Channel_7_Result      EQU    37H
ORG    0000H
LJMP   MAIN
ORG    0050H
MAIN:
      CLR  LED_MCU_START
      MOV   SP,  #7FH
      ACALL Initiate_RS232
      ACALL  ADC_Power_On
      ACALL  Set_P12_Open_Drain
      ACALL  Set_ADC_Channel_2
      ACALL  Get_AD_Result
      ACALL  Send_AD_Result
      ACALL  Set_P12_Normal_10
      MOV   A,  ADC_Channel_2_Result
      CPL    A
      MOV    P1,  A
Wait_Loop:
SJMP  Wait_Loop
Initiate_RS232;
CLR   ES
MOV   TMOD,  #20H
MOV   SCON,   #50H
MOV    TH1,  #0FBH
MOV    TL1,   #0FBH
SETB   TR1
RET
Send_Byte:
CLR   TI
MOV   SBUF,  A
Send_Byte_Wait_Finish:
JNB    TI,  Send_Byte_Wait_Finish
CLR    TI
RET
ADC_Power_On:
     PUSH   ACC
     ORL    ADC_CONTR, #80H
     MOV    A, #20H
     ACALL   Delay
     POP   ACC
     RET
;设置P1.2,设置A/D通道所在的I/O为开漏模式
Set_P12_Open_Drain;
PUSH   ACC
MOV    A,  #00000100B
ORL    P1M0,  A
ORL    P1M1,  A
POP     ACC
RET
;设置P1.2,为普通IO
Set_P12_Normal_IO
PUSH   ACC
MOV    A,  #11111011B
ANL    P1M0,  A
ANL    P1M1,  A
POP     ACC
RET
Set_ADC_Channel_2;
MOV    ADC_CONTR,  #ADC_Power_On_Speed_Channel_2
MOV    A,  #05H
ACALL   Delay
RET
Send_AD_Result;
     PUSH    ACC
     ACALL  Send_Byte
     POP    ACC
     RET
Get_AD_Result:
     PUSH   ACC
     MOV    ADC_DATA,  #0
     ORL     ADC_CONTR,  #00001000B
Wait_AD_Finishe:
     MOV   A,  #00010000B
     ANL    A,  ADC_CONTR
     JZ      Wait_AD_Finishe
     ANL    ADC_CONTR,  #11100111B
     MOV   A, ADC_DATA
     MOV   ADC_Channel_2_Result,  A
     POP    ACC
     RET
Delay:
     PUSH   02
     PUSH   03
     PUSH   04
     MOV    R4,  A
Delay_Loop0:
MOV    R3,  #200
Delay_Loop1;
MOV    R2,  #249
Delay_Loop:
DJNZ   R2, Delay_Loop
DJNZ   R3, Delay_Loop1
DJNZ   R4, Delay_Loop0
POP    04
POP    03
POP    02
RET
END
[此贴子已经被作者于2010-4-13 9:25:59编辑过]
