查看: 5270|回复: 7
为什么我按单片机矩阵按键时,蜂鸣器的功能却都实现不了,求大神看看程序哪里错了
当每按一次点阵按键的其中一个时,蜂鸣器都会响一次,为什么我按点阵按键时,蜂鸣器的功能却都实现不了,求教。。。。
#include<reg52.h>
#include<intrins.h>
uchar key=0,ke=125,n;
uchar w;
uchar a;
uint j,k,m;
sbit keyin1=P1^0;
sbit keyin2=P1^1;
sbit keyout1=P1^2;
sbit keyout2=P1^3;
sbit s5=P1^7;
uchar code led1[8][8]=
{0xFF,0xFF,0xFF,0x7F,0xFF,0xFF,0xFF,0xFF},
{0xFF,0xFF,0x7F,0x3F,0x7F,0xFF,0xFF,0xFF},
{0xFF,0x7F,0xBF,0x1F,0xBF,0x7F,0xFF,0xFF},
{0xFF,0xBF,0xDF,0x0F,0xDF,0xBF,0xFF,0xFF},
{0xFF,0xDF,0xEF,0x87,0xEF,0xDF,0xFF,0xFF},
{0xFF,0xEF,0xF7,0xC3,0xF7,0xEF,0xFF,0xFF},
{0xFF,0xF7,0xFB,0xE1,0xFB,0xF7,0xFF,0xFF},
{0xFF,0xFB,0xFD,0xF0,0xFD,0xFB,0xFF,0xFF}
  uchar code led2[8][8]=
{0xFF,0xFF,0xFF,0xFE,0xFF,0xFF,0xFF,0xFF},
{0xFF,0xFF,0xFE,0xFC,0xFE,0xFF,0xFF,0xFF},
{0xFF,0xFE,0xFD,0xF8,0xFD,0xFE,0xFF,0xFF},
{0xFF,0xFD,0xFB,0xF0,0xFB,0xFD,0xFF,0xFF},
{0xFF,0xFB,0xF7,0xE1,0xF7,0xFB,0xFF,0xFF},
{0xFF,0xF7,0xEF,0xC3,0xEF,0xF7,0xFF,0xFF},
{0xFF,0xEF,0xDF,0x87,0xDF,0xEF,0xFF,0xFF},
{0xFF,0xDF,0xBF,0x0F,0xBF,0xDF,0xFF,0xFF}
void Delay(unsigned int i )
        unsigned int k ;
         for (k=0;k<i;k++);
uchar  keyscan(void)
        keyout2=0;         keyout1=1;
          if(keyin1==0)
                        Delay(10);
                if(keyin1==0)
                 s5=1;
                Delay(200);
                 s5=0;
                key=1;
          if(keyin2==0)
                Delay(10);
                if(keyin2==0)
                  s5=0;
                  Delay(200);
                  s5=1;
                  if(ke==5) ke=5;
                  else ke=ke-40;
          while((keyin1==0)||(keyin2==0))        ;
          keyout2=1;         keyout1=0;
          if(keyin1==0)
        Delay(10);
                if(keyin1==0)
                 s5=0;
                 Delay(10);
                 s5=1;
                 key=3;
          if(keyin2==0)
                        Delay(20);
                if(keyin2==0)
                  s5=1;
                  Delay(200);
                 s5=0;
                 if(ke==245)ke=245;
                 ke=ke+40;
            return key;
         void  main ()
                key=keyscan();
                  n=key ;
          if(n==1)
                   s5=0;
                Delay(10);
                 s5=1;
                 a=0x01;
        for (k=0;k<8;k++)
                                 P0=~a;
                a=_crol_(a,1);
                for (m=0;m<20;m++);
           for (m=0;m<ke;m++)
      {w=0x01;
          for(j=0;j<8;j++)
          {         if(n==3)break;
                  key=keyscan();
                  n=key ;
            P2=w;
                P3=led2[k][j];
         Delay(50);
                w<<=1;
          if(n==3 )
                 s5=0;
                Delay(10);
                 s5=1;
                 a=0x01;
        for (k=0;k<8;k++)
                                 P0=~a;
                a=_cror_(a,1);
                for (m=0;m<20;m++);
           for (m=0;m<ke;m++)
      {w=0x01;
          for(j=0;j<8;j++)
          {        if(n==1)break;
          key=keyscan();
                  n=key ;
            P2=w;
                P3=led1[k][j];
         Delay(50);
                w<<=1;
ID:7485 发表于 2015-11-30 11:27 | 只看该作者
得看你的电路是怎么接的。
ID:83671 发表于 2015-11-30 20:44 | 只看该作者
ahshmj 发表于 2015-11-30 11:27
得看你的电路是怎么接的。
图片 传不上去
ID:7485 发表于 2015-12-3 19:07 | 只看该作者
你那蜂鸣器响的时间太短了吧?而且是当K4是高电平时才响。89c52高电平好像驱动不了这个三极管,否则你一上电他就会不停地响。
ID:7485 发表于 2015-12-3 19:09 | 只看该作者
你可以改一下,用低电平驱动。
ID:79544 发表于 2015-12-4 12:55 | 只看该作者
把驱动蜂鸣器的三极管换成pnp型8550
ID:153199 发表于 2016-12-31 15:28 | 只看该作者
结合电路分析
ID:153199 发表于 2016-12-31 15:29 | 只看该作者
换一下三极管试试
