查看: 15896|回复: 15
C51简单计算器设计思想、Proteus仿真及源代码
ID:98923 发表于 2015-12-9 00:36 | 显示全部楼层 |阅读模式
硬件部分比较简单,当键盘按键按下时它的那一行、那一列的端口为低电平。因此,只要扫描行、列端口是否都为低电平就可以确定是哪个键被按下。
二、主程序流程图
程序的主要思想是:将按键抽象为字符,然后就是对字符的处理。将操作数分别转化为字符串存储,操作符存储为字符形式。然后调用compute()函数进行计算并返回结果。具体程序及看注释还有流程图。
三、程序源代码
#include <reg51.h>#include <intrins.h>
#include <ctype.h>
#include <stdlib.h>
uchar operand1[9], operand2[9];
uchar operator;
void delay(uint);
uchar keyscan();
void disp(void);
void buf(uint value);
uint compute(uint va1,uint va2,uchar optor);
uchar code table[] = {0xc0,0xf9,0xa4,0xb0,0x99,
0x92,0x82,0xf8,0x80,0x90,0xff};
uchar dbuf[8] = {10,10,10,10,10,10,10,10};
void delay(uint z)
uint x,y;
for(x=z;x>0;x--)
for(y=110;y>0;y--);
uchar keyscan()
uchar skey;
P1 = 0xfe;
while((P1 & 0xf0) != 0xf0)
delay(3);
switch(P1)
case 0xee: skey = '7'; break;
case 0xde: skey = '8'; break;
case 0xbe: skey = '9'; break;
case 0x7e: skey = '/'; break;
default: skey = '#';
P1 = 0xfd;
delay(3);
switch(P1)
case 0xed: skey = '4'; break;
case 0xdd: skey = '5'; break;
case 0xbd: skey = '6'; break;
case 0x7d: skey = '*'; break;
P1 = 0xfb;
delay(3);
switch(P1)
case 0xeb: skey = '1'; break;
case 0xdb: skey = '2'; break;
case 0xbb: skey = '3'; break;
case 0x7b: skey = '-'; break;
P1 = 0xf7;
delay(3);
switch(P1)
case 0xe7: skey = '$'; break;
case 0xd7: skey = '0'; break;
case 0xb7: skey = '='; break;
case 0x77: skey = '+'; break;
return skey;
uint value1, value2, value;
uchar ckey, cut1 = 0, cut2 = 0;
uchar operator;
uchar i, bool = 0;
init:
buf(0);
disp();
value = 0;
cut1 = cut2 = 0;
bool = 0;
for(i = 0;i < 9;i++)
operand1 = '\0';
operand2 = '\0';
ckey = keyscan();
if(ckey != '#')
if(isdigit(ckey))
switch(bool)
case 0:
operand1[cut1] = ckey;
operand1[cut1+1] = '\0';
value1 = atoi(operand1);
cut1++;
buf(value1);
disp();
break;
case 1:
operand2[cut2] = ckey;
operand2[cut2+1] = '\0';
value2 = atoi(operand2);
cut2++;
buf(value2);
disp();
break;
default: break;
else if(ckey=='+'||ckey=='-'||ckey=='*'||ckey=='/')
bool = 1;
operator = ckey;
buf(0);
dbuf[7] = 10;
disp();
else if(ckey == '=')
value = compute(value1,value2,operator);
buf(value);
disp();
ckey = keyscan();
if(ckey == '$')
goto init;
buf(value);
disp();
else if(ckey == '$')
{ goto init;}
disp();
uint value;
switch(optor)
case '+' : value = va1+va2; break;
case '-' : value = va1-va2; break;
case '*' : value = va1*va2; break;
case '/' : value = va1/va2; break;
default : break;
return value;
void buf(uint val)
uchar i;
if(val == 0)
dbuf[7] = 0;
i = 6;
for(i = 7; val > 0; i--)
dbuf = val % 10;
val /= 10;
for( ; i > 0; i--)
dbuf = 10;
void disp(void)
uchar bsel, n;
bsel=0x01;
for(n=0;n<8;n++)
P2=bsel;
P0=table[dbuf[n]];
bsel=_crol_(bsel,1);
delay(3);
P0=0xff;
C51简单计算器.zip
1.24 MB, 下载次数: 244, 下载积分: 黑币 -5
ID:112618 发表于 2016-4-10 10:08 | 显示全部楼层
楼主你好,我刚入门,对51引脚不懂,下载你的帖子还是一部分看不懂,你能帮我改下这个吗?
ID:117574 发表于 2016-5-10 18:33 来自触屏版 | 显示全部楼层
你现在回了吗
ID:114732 发表于 2016-5-14 16:19 | 显示全部楼层
先谢楼主的分享
ID:145691 发表于 2016-11-2 14:34 | 显示全部楼层
负数能运算不
ID:146409 发表于 2016-11-6 14:01 | 显示全部楼层
初学者来参考参考
ID:156892 发表于 2016-12-22 16:07 | 显示全部楼层
计算按键和显示屏元件名是什么呀
ID:157940 发表于 2016-12-27 08:53 | 显示全部楼层
谢谢楼主
ID:153199 发表于 2017-1-1 12:22 | 显示全部楼层
很详细的资料
ID:171316 发表于 2017-3-16 20:05 | 显示全部楼层
谢谢楼主
ID:168012 发表于 2017-3-17 08:57 | 显示全部楼层
厉害,厉害
ID:212212 发表于 2017-6-19 09:26 | 显示全部楼层
有没有汇编语言的
ID:242365 发表于 2017-10-24 17:59 | 显示全部楼层
可以共享一下吗
ID:336429 发表于 2018-5-24 14:52 | 显示全部楼层
被认为是不安全的文件不能下载,想要下载下来学习学习的。
ID:794325 发表于 2020-7-1 15:35 | 显示全部楼层
楼主你好,用了你的代码,有一些问题,不知道如何修改,想询问一下您,不知道如何上传图片。。。
  1. operand1 = '\0';
这里出现错误
error C213: left side of asn-op not an lvalue,是下面这部分代码中的
  1. init:
  2. buf(0);
  3. disp();
  4. value = 0;
  5. cut1 = cut2 = 0;
  6. bool = 0;
  7. for(i = 0;i < 9;i++)
  8. {
  9. operand1 = '\0';
  10. operand2 = '\0';
  11. }
ID:794325 发表于 2020-7-1 17:00 | 显示全部楼层
上面那个我加了个[i]就可以了,但是运行的时候为什么数码管不显示数字啊
