查看: 2689|回复: 1
求大神,单片机矩阵按键如何检测松手
ID:97038 发表于 2015-12-12 23:46 | 显示全部楼层 |阅读模式
写了个单片机矩阵按键的程序,灵敏,但不知道如何实现判断按键已经松手了,松手后执行另一条程序!
uchar KeyRvs(void)
        uchar temH, temL,tem ,key1,key;
        P1 = 0xf0; temH = P1;//低四位先输出0;读入,高四位含有按键信息
        P1 = 0x0f; temL = P1;//然后反转输出0;读入,低四位含有按键信息
        tem=temH+temL;
       switch(tem)
                 case 0xee: key = 1; break;
                 case 0xde: key = 2; break;
                 case 0xbe: key = 3; break;
                 case 0x7e: key = 10; break;  //A
                 case 0xed: key = 4; break;
                 case 0xdd: key = 5; break;
                 case 0xbd: key = 6; break;
                 case 0x7d: key = 11;break;         //B
                 case 0xeb: key = 7; break;
                 case 0xdb: key = 8; break;
                 case 0xbb: key = 9; break;
                 case 0x7b: key = 12;break;         //C
                 case 0xe7: key = 15;break;         //F
                 case 0xd7: key = 0; break;
                 case 0xb7: key = 14;break;         //E
                 case 0x77: key = 13;break;         //D
//                 case 0xff: key = 16;break;         //
        return key;
ID:97249 发表于 2015-12-19 12:17 来自触屏版 | 显示全部楼层
松手后键值就为0了,用while(键值为真);就ok了
admin + 50 回帖助人的奖励!
