查看: 3437|回复: 0
自制花式闪烁led 2x8 附带仿真
ID:96354 发表于 2015-12-19 14:56 | 显示全部楼层 |阅读模式
#include<reg51.h>
unsigned char code Tab[87][2]={{0xfe,0x01},{0xfd,0x01},{0xfb,0x01},{0xf7,0x01},{0xef,0x01},{0xdf,0x01},{0xbf,0x01},{0x7f,0x01},
                                                           {0x7f,0x02},{0xbf,0x02},{0xdf,0x02},{0xef,0x02},{0xf7,0x02},{0xfb,0x02},{0xfd,0x02},{0xfe,0x02},
                                                           {0xfe,0x01},{0xfe,0x02},{0xfd,0x01},{0xfd,0x02},{0xfb,0x01},{0xfb,0x02},{0xf7,0x01},{0xf7,0x02},
                                                           {0xef,0x01},{0xef,0x02},{0xdf,0x01},{0xdf,0x02},{0xbf,0x01},{0xbf,0x02},{0x7f,0x01},{0x7f,0x02},
                                                           {0xfe,0x03},{0xfd,0x03},{0xfb,0x03},{0xf7,0x03},{0xef,0x03},{0xdf,0x03},{0xbf,0x03},{0x7f,0x03},
                                                           {0x7f,0x03},{0xbf,0x03},{0xdf,0x03},{0xef,0x03},{0xf7,0x03},{0xfb,0x03},{0xfd,0x03},{0xfe,0x03},
                                                           {0xfe,0x01},{0xfd,0x03},{0xfb,0x01},{0xf7,0x03},{0xef,0x01},{0xdf,0x03},{0xbf,0x01},{0x7f,0x03},
                                                           {0x7f,0x03},{0xbf,0x01},{0xdf,0x03},{0xef,0x01},{0xf7,0x03},{0xfb,0x01},{0xfd,0x03},{0xfe,0x01},
                                                           {0xfe,0x00},{0xfd,0x01},{0xfb,0x03},{0xf7,0x00},{0xef,0x01},{0xdf,0x03},{0xbf,0x00},{0x7f,0x01},
                                                           {0x7f,0x02},{0xbf,0x03},{0xdf,0x00},{0xef,0x02},{0xf7,0x03},{0xfb,0x00},{0xfd,0x02},{0xfe,0x03},
void delay(unsigned int j)
        unsigned int i;
        for(i=0;i<j;i++)
        unsigned char k;
        for(k=0;k<87;k++)
                P2=Tab[k][0];
                P1=Tab[k][1];
                delay(10000);
可以考虑用左移右移,不是太懂,也请大神指教
花式双排流水灯.rar
50.33 KB, 下载次数: 8, 下载积分: 黑币 -5
admin + 50 共享资料的积分奖励!
