查看: 2766|回复: 4
大家帮帮忙呀,看看这个程序配合这个图为什么不行呀
ID:60551 发表于 2015-12-30 21:32 | 显示全部楼层 |阅读模式
#include "reg52.h"
sbit relay11=P1^7;
sbit relay12=P1^6;
sbit relay21=P1^5;
sbit relay22=P1^4;
sbit relay31=P1^3;
sbit relay32=P1^2;
sbit relayLED1=P3^5;
sbit relayLED2=P3^4;
sbit relayLED3=P3^3;
bit flag1;
bit flag2;
bit flag3;
sbit key1=P3^1;
sbit key2=P3^0;
sbit key3=P3^2;
void keyscan();
void init();
void delay(unsigned char n)  //约n(ms)延时
{ unsigned char i,j,k;
  for(k=0;k<n;k++)
      for(j=0;j<10;j++)         // 约1ms延时
         for(i=0;i<30;i++)  //约0.1ms延时
   init();
   keyscan();
void keyscan()
   if(key1==0)
        delay(100);
                flag1=1;
                if(key1==0)
                        if(flag2==1)
                          relayLED2=0;
                          relay21=0;
                          relay22=1;
                          delay(1000);
                          relay22=0;
                          flag2=0;
                                if(flag3==1)
                          relayLED3=0;
                          relay31=0;
                          relay32=1;
                          delay(1000);
                          relay32=0;
                          flag3=0;
                          relayLED1=1;
                          relay11=1;
                          relay12=0;
                          delay(1000);
                          relay11=0;
                        while(!key1);
   if(key2==0)
        delay(100);
                flag2=1;
                if(key2==0)
                        if(flag1==1)
                          relayLED1=0;
                          relay11=0;
                          relay12=1;
                          delay(1000);
                          relay12=0;
                          flag1=0;
                                if(flag3==1)
                          relayLED3=0;
                          relay31=0;
                          relay32=1;
                          delay(1000);
                          relay32=0;
                          flag3=0;
                          relayLED2=1;
                          relay21=1;
                          relay22=0;
                          delay(1000);
                          relay21=0;
                        while(!key2);
   if(key3==0)
        delay(100);
                flag3=1;
                if(key3==0)
                    if(flag1==1)
                          relayLED1=0;
                          relay11=0;
                          relay12=1;
                          delay(1000);
                          relay12=0;
                          flag1=0;
                        if(flag2==1)
                          relayLED2=0;
                          relay21=0;
                          relay22=1;
                          delay(1000);
                          relay22=0;
                          flag2=0;
                          relayLED3=1;
                          relay31=1;
                          relay32=0;
                          delay(1000);
                          relay31=0;
                        while(!key3);
void init()
P2=0xff;
relay11= 0;
relay12= 0;
relay21= 0;
relay22= 0;
relay31= 0;
relay32= 0;
relayLED1= 0;
relayLED2= 0;
relayLED3= 0;
flag1=0;
flag2=0;
flag3=0;
key1=1;
key2=1;
key3=1;
已做成板子,不接负载没有问题 ,一接负载 按钮就会乱,有时还不管用
2015.1.pdf
503.26 KB, 下载次数: 11
ID:60551 发表于 2015-12-30 21:33 | 显示全部楼层
负载是 3 个脉冲电磁阀
ID:85702 发表于 2016-1-4 23:15 | 显示全部楼层
感觉是电磁干扰吧.试试去干扰吧
ID:101873 发表于 2016-1-5 10:15 | 显示全部楼层
焊点的问题
ID:101916 发表于 2016-1-5 13:53 | 显示全部楼层
延时太短
