查看: 6348|回复: 0
hc-sr04超声波模块程序+11.0592mhz晶振+stc89c52rc单片机+四位数码管
ID:104287 发表于 2016-1-31 00:45 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
        /*hc-sr04超声波模块+11.0592mhz晶振+stc89c52rc单片机+四位数码管*/
#include <reg51.h>
#include<intrins.h>
unsigned char a,b,c,d;
float num=0.0;
sbit du=P2^6;
sbit we= P2^7;
sbit send=P2^1;
sbit receive=P2^2;
unsigned char duan[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
unsigned char wei []={0xfe,0xfd,0xfb,0xf7,0x2f,0x1f};
void delay_10us()
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
void delay_200ms(void)
unsigned char i,j,k;
for(i=5;i>0;i--)
for(j=132;j>0;j--)
for(k=150;k>0;k--);
void main ()
unsigned int timeh,timel;
send=0;//先置零
   receive=0;//置零
   EA=0;
   send=1;
   delay_10us();
   delay_10us();//延时20us
   send=0;
   while(receive==0)//等待高电平
   TMOD=0X01;//设置定时器0的工作方式
   TH0=0;//赋初值
   TL0=0;
   EA=1;///打开总中断开关
   ET0=1;//打开定时器开关
   TR0=1;
   while(receive)//等待低电平
    timeh=TH1;//取出定时器的值
    timel=TL1;
    TR0=0;
    num=(TH0*255+TL0)/100.0*340/2;
    a=(unsigned int )num%10;//算清各位十位百位
    b=(unsigned int)num%100/10;
    c=(unsigned int )num/100%10;
    d=(unsigned int)num/10;
    P0=0xff;//数码管显示输出
    we=1;
    P0=0xfe;
    we=0;
    P0=0x00;
    du=1;
    P0=duan[a];
    delay_200ms;
    delay_200ms;
    delay_200ms;
    delay_200ms;
    delay_200ms;
    delay_200ms;
    delay_200ms;
    delay_200ms;
    P0=0x00;
    du=0;
    P0=0xff;
    we=1;
    P0=0xfd;
    we=0;
    P0=0x00;
    du=1;
    P0=duan;
    delay_200ms;
    delay_200ms;
    delay_200ms;
    delay_200ms;
    delay_200ms;
    delay_200ms;
    delay_200ms;
    delay_200ms;
    P0=0x00;
    du=0;
    P0=0xff;
    we=1;
    P0=0xfb;
    we=0;
    P0=0x00;
    du=1;
    P0=duan[c];
    delay_200ms;
    delay_200ms;
    delay_200ms;
    delay_200ms;
    delay_200ms;
    delay_200ms;
    delay_200ms;
    delay_200ms;
    P0=0x00;
    du=0;
    P0=0xff;
    we=1;
    P0=0xf7;
    we=0;
    P0=0x00;
    du=1;
    P0=duan[d];
    delay_200ms;
    delay_200ms;
    delay_200ms;
    delay_200ms;
    delay_200ms;
    delay_200ms;
    P0=0x00;
    du=0;
void timer0 ()interrupt 1
TH0=0;
TL0=0;
/*四位数码管要消影+注意定时器和外部中断的使用*/
收藏收藏1 分享淘帖 顶1 踩
