查看: 4548|回复: 0
LM032L液晶 8051 LCD Driver仿真及程序
ISIS 7 Professional
自带的电路仿真图,压缩包里面有hex文件,可以直接打开使用
  1. ; LCD Display Driver Demo.
  2. ; Timing code assumes 1.2MHz Clock
  3. ;LCD Registers addresses
  4. LCD_CMD_WR        equ         0
  5. LCD_DATA_WR        equ        1
  6. LCD_BUSY_RD        equ        2
  7. LCD_DATA_RD        equ        3
  8. ;LCD Commands
  9. LCD_CLS                equ        1
  10. LCD_HOME        equ        2
  11. LCD_SETMODE        equ        4
  12. LCD_SETVISIBLE        equ        8
  13. LCD_SHIFT        equ        16
  14. LCD_SETFUNCTION        equ        32
  15. LCD_SETCGADDR        equ        64
  16. LCD_SETDDADDR        equ        128
  17. ;Reset vector
  18.         org 0000h
  19.         jmp start
  20. ;Start of the program
  21.         org 0100h
  22. string1a:db ' !! A M A Z I N G !! '
  23.          db 0
  24. string1b:db '!! A M A Z I N G !! '
  25.          db 0
  26. string2:db ' A virtual LM032L... '
  27.         db 0
  28. string3:db ' driven by a virtual '
  29.         db 0
  30. string4:db '   8051 processor!'
  31.         db 0
  32. start:        mov A,#038h
  33.         call wrcmd
  34. loop:        mov A,#LCD_SETVISIBLE+6         ;Make the display & blink visible:
  35.         call wrcmd
  36.         mov R7,#2
  37. loop2:
  38.         mov DPTR,#string1a
  39.         call wrstr
  40.         mov DPTR,#200
  41.         call wtms
  42.         mov A,#LCD_CLS                        ;Clear screen
  43.         call wrcmd
  44.         mov DPTR,#string1b
  45.         call wrstr
  46.         mov DPTR,#200
  47.         call wtms
  48.         mov A,#LCD_CLS                        ;Clear screen
  49.         call wrcmd
  50.         djnz R7,loop2
  51.         mov DPTR,#string1a
  52.         call wrstr
  53.         mov DPTR,#400
  54.         call wtms
  55.         mov A,#LCD_SETDDADDR+64
  56.         call wrcmd
  57.         mov DPTR,#string2
  58.         call wrslow
  59.         mov DPTR,#200
  60.         call wtms
  61.         mov A,#LCD_CLS                        ;Clear screen
  62.         call wrcmd
  63.         mov DPTR,#string3
  64.         call wrslow
  65.         mov A,#LCD_SETDDADDR+64
  66.         call wrcmd
  67.         mov DPTR,#string4
  68.         call wrslow
  69.         mov A,#LCD_SETVISIBLE+7                ;Show the blink cursor as well.
  70.         call wrcmd
  71.         mov DPTR,#2000
  72.         call wtms
  73.         mov A,#LCD_CLS                        ;Clear screen
  74.         call wrcmd
  75.         jmp loop
  76. ;Sub routine to write null terminated string at DPTR in program ram.
  77. wrstr:        mov R0,#LCD_DATA_WR
  78. wrstr1:        clr A
  79.         movc A,@A+DPTR
  80.         jz wrstr2
  81.         movx @R0,A
  82.         call wtbusy
  83.         inc DPTR
  84.         push DPL
  85.         push DPH
  86.         pop DPH
  87.         pop DPL
  88.         jmp wrstr1
  89. wrstr2:        ret
  90. ;Sub routine to write null terminated string at DPTR in program ram. Slowly
  91. wrslow:        mov R0,#LCD_DATA_WR
  92. wrslw1:        clr A
  93.         movc A,@A+DPTR
  94.         jz wrslw2
  95.         movx @R0,A
  96.         call wtbusy
  97.         inc DPTR
  98.         push DPL
  99.         push DPH
  100.         mov DPTR,#100
  101.         call wtms
  102.         pop DPH
  103.         pop DPL
  104.         jmp wrslw1
  105. wrslw2:        ret
  106. ;Sub routine to write command:
  107. wrcmd:        mov R0,#LCD_CMD_WR
  108.         movx @R0,A
  109.         jmp wtbusy
  110. ;Sub routine to write character:
  111. wrchar:        mov R0,#LCD_DATA_WR
  112.         movx @R0,A
  113. ;Subroutine to wait for busy clear
  114. wtbusy: mov R1,#LCD_BUSY_RD
  115.         movx A,@r1
  116.         jb ACC.7,wtbusy
  117.         ret
  118. ;Wait for number of seconds in A
  119. wtsec:        push ACC
  120.         call wtms
  121.         pop ACC
  122.         dec A
  123.         jnz wtsec
  124.         ret
  125. ;Wait for number of milliseconds in DPTR
  126. wtms:   xrl DPL,#0FFh                        ;Can't do DEC DPTR, so do the loop by forming 2's complement
  127.         xrl DPH,#0FFh                        ;and incrementing instead.
  128.         inc DPTR
  129. wtms1:        mov TL0,#09Ch                        ;100 ticks before overflow = 1ms at 1.2MHz Clock
  130.         mov TH0,#0FFh
  131.         mov TMOD,#1                        ;Timer 0 mode 1
  132.         setb TCON.4                        ;Timer 0 runs
  133. wtms2:        jnb TCON.5,wtms2
  134.         clr TCON.4                        ;Timer 0 stops
  135.         clr TCON.5
  136.         inc DPTR
  137.         mov A,DPL
  138.         orl A,DPH
  139.         jnz wtms1
  140.         ret
  141.
  142.         END
8051 LCD Driver.zip
11.57 KB, 下载次数: 7, 下载积分: 黑币 -5
