查看: 3823|回复: 0
为什么我用ADC0808写的程序没有反应的
#include <reg52.h>
sbit ALE = P3^3;
sbit OE  = P3^4;
sbit EOC = P3^5;
sbit STA = P3^6;
sbit CLK = P3^7;
unsigned int  num;               //AD转换后的数字量
char  ch;                        //通道号码
//          延时函数
void  delay(unsigned int z)
    unsigned int  x, y;
    for(x = z; x > 0; x--)  for(y = 110; y > 0; y--)  CLK = ~CLK;
//    数码管显示函数
void  display(void)
    char code table[] = {                              //共阴段码
      0x3f, 0x06, 0x5b, 0x4f, 0x66, 0x6d, 0x7d, 0x07,  //0~7
      0x7f, 0x6f, 0x77, 0x7c, 0x39, 0x5e, 0x79, 0x71}; //8~F
    P0 = 0; P2 = 0xf7; P0 = table[ch];              delay(2);//通道号码
    P0 = 0; P2 = 0xfb; P0 = table[num / 100] + 128; delay(2);//百位加上小数点
    P0 = 0; P2 = 0xfd; P0 = table[num % 100 / 10];  delay(2);//十位
    P0 = 0; P2 = 0xfe; P0 = table[num % 10];        delay(2);//个位
    P0 = 0;                                            //关闭显示器
//     转换函数
void main(void)
    while(1) {                   //无穷循环
      ch = P2 / 32;              //取来通道号码
      P3 = ch + 0xf8;            //送给ADC0808
      ALE = 1;  ALE = 0;         //地址锁存
      STA = 1;  STA = 0;         //开始转换,稍候,才可读EOC
      display();                 //显示,既做延时,又输出CLK
      while(EOC == 0)  display(); //等待转换结束
      num = P1;                  //取出转换结果
      num = num * 100 / 51;      //比例变换:255 --> 500
