查看: 4531|回复: 1
msp430g2231在lcd1602显示自定义字符
ID:110653 发表于 2016-3-30 17:22 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
          自己又蛋疼写的程序。主要是在1602上写入自定义字符,可以用h1838遥控,没有实际意义,做个测试文件,以后自己好再调试。msp430g2231只有8个io口(可以拓展为10个)怎么利用这些io口,我想了个简单的办法。红外遥控占用一个io口,1602只是需要4根线(164驱动的)当然可以节省到2个io口,共占6个io口的,本来打算做个遥控车的,用PWM驱动,但肯跌的是自己不能解决电机反向电流的干扰。一上电机程序就崩溃,无奈,只好这样了。不过写入自定义字符确实是件不错的乐趣。
                            补充内容:
        图片暂时无法上传,看了很多开发板的原理图,我发现高明的设计不在于用了什么高端的芯片,而是精明的设计,虽然我还不具备这样的能力,也不知道我理解的怎么样?先写下我的思路。
部分程序预览:
  1. #include"config.h"
  2. uchar const pic[8][8]={
  3. {0x04,0x0E,0x15,0x04,0x04,0x04,0x04,0x00},//↑
  4. {0x00,0x04,0x04,0x04,0x04,0x15,0x0E,0x04},//↓
  5. {0x00,0x04,0x08,0x1F,0x08,0x04,0x00,0x00},//←
  6. {0x00,0x04,0x02,0x1F,0x02,0x04,0x00,0x00},//→
  7. {0x04,0x04,0x0A,0x1F,0x1F,0x0A,0x04,0x04},//占位符
  8. {0x00,0x1B,0x1B,0x1B,0x1B,0x1B,0x1B,0x00},/*暂停*/
  9. {0x11,0x13,0x15,0x19,0x15,0x13,0x11,0x00},/*后退*/
  10. {0x11,0x19,0x15,0x13,0x15,0x19,0x11,0x00},/*"前进*/
  11. };
  12. uchar const pic1[8][8]={
  13. {0x00,0x0E,0x1F,0x11,0x11,0x11,0x11,0x1F},/*电量空*/
  14. {0x00,0x0E,0x1F,0x11,0x11,0x11,0x1F,0x1F},/*一格电*/
  15. {0x00,0x0E,0x1F,0x11,0x11,0x1F,0x1F,0x1F},/*2格电*/
  16. {0x00,0x0E,0x1F,0x11,0x1F,0x1F,0x1F,0x1F},/*3格电*/
  17. {0x00,0x0E,0x1F,0x1F,0x1F,0x1F,0x1F,0x1F},/*4格电满电*/
  18. {0x00,0x0F,0x09,0x0D,0x0B,0x09,0x11,0x00},/*凡*/
  19. {0x11,0x0E,0x1F,0x11,0x1F,0x04,0x1B,0x04},/*机器人*/
  20. {0x00,0x1F,0x0A,0x0A,0x0A,0x11,0x00,0x00},/*pi*/
  21. };
  22. //音量大小设置1-8
  23. uchar const pic3[8][8]={
  24. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1f},/*"未命名文件",1*/
  25. {0x00,0x00,0x00,0x00,0x00,0x00,0x1f,0x1f},/*"未命名文件",2*/
  26. {0x00,0x00,0x00,0x00,0x00,0x1f,0x1f,0x1f},/*"未命名文件",3*/
  27. {0x00,0x00,0x00,0x00,0x1f,0x1f,0x1f,0x1f},/*"未命名文件",4*/
  28. {0x00,0x00,0x00,0x1f,0x1f,0x1f,0x1f,0x1f},/*"未命名文件",5*/
  29. {0x00,0x00,0x1f,0x1f,0x1f,0x1f,0x1f,0x1f},/*"未命名文件",6*/
  30. {0x00,0x1f,0x1f,0x1f,0x1f,0x1f,0x1f,0x1f},/*"未命名文件",7*/
  31. {0x1f,0x1f,0x1f,0x1f,0x1f,0x1f,0x1f,0x1f},/*"未命名文件",8*/
  32. };
  33. uchar flag,flag1,flag2;
  34. uchar flag3,flag4;
  35. //extern void read_xyz_normol();
  36. void extern_1m()
  37. {
  38.    WDTCTL = WDTPW + WDTHOLD;                 // Stop WDT
  39.   if (CALBC1_1MHZ==0xFF)                                        // If calibration constant erased
  40.   {
  41.     while(1);                               // do not load, trap CPU!!
  42.   }
  43.   DCOCTL = 0;                               // Select lowest DCOx and MODx settings
  44.   BCSCTL1 = CALBC1_1MHZ;
  45.   DCOCTL = CALDCO_1MHZ;                     // Load 8MHz constants
  46. }
  47. void sendbyte(uchar byte)
  48. {
  49. uchar c,num;
  50. num=byte;
  51. for(c=0;c<8;c++)
  52. {
  53. P1OUT&=~0x80;
  54. CLK0;
  55. P1OUT|=num&0x80; //(0x80即十进制的128, 二进制的10000000 按位发送
  56. CLK1;
  57. num<<=1;
  58. }
  59. }
  60. // - - 向LCD1602写指令
  61. void LCD_write_command(uchar dat)
  62. {
  63. LCD_RS_LOW; // - - 指令
  64. //LCD_RW_LOW; // - - 写入
  65. sendbyte(dat);
  66. //delay_us(10);
  67. LCD_EN_HIGH; // - - 允许
  68. //delay_us(1);
  69. LCD_EN_LOW;
  70. }
  71. // - - 向LCD1602写数据
  72. void LCD_write_data(uchar dat)
  73. {
  74. LCD_RS_HIGH;// - - 数据
  75. //LCD_RW_LOW;// - - 写入
  76. sendbyte(dat);
  77. //delay_us(10);
  78. LCD_EN_HIGH;// - - 允许
  79. //delay_us(1);
  80. LCD_EN_LOW;
  81. }
  82. // - - 设置显示位置
  83. void LCD_set_xy(uchar x,uchar y)
  84. {
  85.   uchar address;
  86.   if(y==1)
  87.   {
  88.     address=0x80+x; // - - 第一行位置
  89.   } else {
  90.     address=0xc0+x; // - - 第二行位置
  91.   }
  92. //    LCD_delay_10us(1);
  93.     LCD_write_command(address);
  94. }
  95. // - - 显示一个字符函数
  96. void LCD_disp_char(uchar x,uchar y,uchar dat) // - - LCD_disp_char(0,1,0x38); // - - 显示8
  97. {
  98.     LCD_set_xy(x,y);
  99. //    LCD_delay_10us(1);
  100.     LCD_write_data(dat);
  101. }
  102. // - - 显示一个字符串函数
  103. void LCD_disp_string(uchar x,uchar y,char *s)
  104. {
  105.   LCD_set_xy(x,y);
  106. // LCD_delay_10us(1);
  107.   while(*s!='\0')
  108.   {
  109.     LCD_write_data(*s);
  110.     s++;
  111.   }
  112. }
  113. void LCD_init(void)
  114. {
  115.   RSEN_INIT;
  116.   CLKDAT_INIT;
  117.   LCD_READ_DIR;
  118. LCD_write_command(0x38); // - - 设置8位格式,2行,5x7
  119. //delay_us(20);
  120. LCD_write_command(0x0c); // - - 整体显示,关光标,不闪烁
  121. //delay_us(20);
  122. LCD_write_command(0x06); // - - 设定输入方式,增量不移位
  123. //delay_us(20);
  124. LCD_write_command(0x01); // - - 清除屏幕显示
  125. //delay_us(200);
  126. }
  127. void lcd1602_write_pic(unsigned char add,uchar const *pic_num)
  128. {
  129. unsigned char i;
  130. add=add<<3;
  131. for(i=0;i<8;i++)
  132. {
  133. LCD_write_command(0x40|add+i);
  134. LCD_write_data(*pic_num++);
  135. }
  136. }
  137. void lcd1602_write_pic_all()//显示跳变所有显示
  138. {
  139.   uchar i;
  140.   switch(flag)
  141.   {
  142.   case 0:flag=1;break;
  143.   case 1:flag=0;break;
  144.   default:flag=0;break;
  145.   }
  146.   if(flag==0)
  147.   {
  148.   for(i=0;i<8;i++)
  149.     lcd1602_write_pic(i,pic[i]);
  150.    LCD_disp_string(0,1,"        ");
  151. for(i=0;i<8;i++)
  152.    LCD_disp_char(i,0,i);
  153.   }
  154.   else{
  155. for(i=0;i<8;i++)
  156.     lcd1602_write_pic(i,pic1[i]);
  157. LCD_disp_string(0,0,"        ");
  158. for(i=0;i<8;i++)
  159.    LCD_disp_char(i,1,i);
  160.   }
  161. }
  162. void lcd1602_write_pic_baterry() //自定义数据1
  163. {
  164.   if(flag>=5)
  165.     flag=0;
  166.   lcd1602_write_pic(1,pic1[flag]);
  167.   LCD_disp_char(15,0,1);
  168. }
  169. void lcd1602_write_pic_robot()  //自定义数据0
  170. {
  171.    if(++flag1>=15)
  172.    {
  173.     flag1=0;
  174.     LCD_disp_char(14,0,' ');
  175.    }
  176.    else
  177.    LCD_disp_char(flag1-1,0,' ');
  178.    lcd1602_write_pic(0,pic1[6]);
  179.    LCD_disp_char(flag1,0,0);
  180. }
  181. void lcd1602_write_pic_dian(unsigned char add)  //自定义数据0
  182. {
  183.   if(++flag2==8)
  184.       flag2=0;
  185. lcd1602_write_pic(add,pic[flag2]);
  186. LCD_disp_char(10,1,add);
  187. }
  188. void lcd1602_write_pic_volum(unsigned char add)
  189. {
  190. if(flag3>=8)
  191.   flag3=0;
  192. lcd1602_write_pic(add,pic3[flag3]);
  193. LCD_disp_char(15,1,add);
  194. }
  195. void lcd1602_write_pic_qu(unsigned char add)
  196. {
  197.   if(++flag4>=8)
  198.   flag4=0;
  199.   uchar i;
  200.   for(i=0;i<4;i++)
  201.   {
  202.      lcd1602_write_pic(add+i,pic3[(i+flag4)%8]);
  203.      LCD_disp_char(i,1,add+i);
  204.   }
  205. }
  206. void sendbyte_4wire(char date)
  207. {
  208.   uchar i;
  209.   for(i=0;i<2;i++)
  210.   {
  211.     LCD_EN_HIGH;
  212.     sendbyte(date);
  213.     LCD_EN_LOW;
  214.     date<<=4;
  215.   }
  216. }
  217. void lcd_4wire(uchar cd,uchar date)
  218. {
  219.   if(cd==0)
  220.     LCD_RS_LOW;
  221.   else LCD_RS_HIGH;
  222.   sendbyte_4wire(date);
  223. }
  224. void lcd_4wire_init()
  225. {
  226.     RSEN_INIT;
  227.   CLKDAT_INIT;
  228.   lcd_4wire(0,0x28);
  229.   lcd_4wire(0,0x0f);
  230.   lcd_4wire(0,0x06);
  231.   lcd_4wire(0,0x01);
  232.   lcd_4wire(0,0x80);
  233. }
  234. void lcd_4wire_setxy(uchar x,uchar y)
  235. {
  236.   uchar address;
  237.   if(y==1)
  238.   {
  239.     address=0x80+x; // - - 第一行位置
  240.   } else {
  241.     address=0xc0+x; // - - 第二行位置
  242.   }
  243. //    LCD_delay_10us(1);
  244.    lcd_4wire(0,address);
  245. }
  246. void LCD_4wire_disp_char(uchar x,uchar y,uchar  dat) // - - LCD_disp_char(0,1,0x38); // - - 显示8
  247. {
  248.     lcd_4wire_setxy(x,y);
  249. //    LCD_delay_10us(1);
  250.     lcd_4wire(1,dat);
  251. }
  252. // - - 显示一个字符串函数
  253. void lcd_4wire_disp_string(uchar x,uchar y,char *s)
  254. {
  255.   lcd_4wire_setxy(x,y);
  256. // LCD_delay_10us(1);
  257.   while(*s!='\0')
  258.   {
  259.     lcd_4wire(1,*s);
  260.     s++;
  261.   }
  262. }
  263. void init_TA()
  264. {
  265.   TACCTL0 = CCIE;                           // TACCR0 interrupt enabled
  266.   TACCR0 = 50000;                            //400ms中断一次
  267.   TACTL = TASSEL_2 + MC_1+ID_3;                  // SMCLK, upmode
  268. }
  269. #pragma vector=TIMER0_A0_VECTOR
  270. __interrupt void Timer_A (void)
  271. {
  272.
  273. //  LCD_disp_char(0,0,'F');
  274. // lcd_4wire_disp_string(0,0,"wo shi");
  275. // lcd1602_write_pic_all();
  276. lcd1602_write_pic_baterry();
  277. lcd1602_write_pic_robot();
  278. lcd1602_write_pic_dian(2);
  279. lcd1602_write_pic_volum(3);
  280. lcd1602_write_pic_qu(4);
  281. //read_xyz_normol();
  282. }
液晶显示.rar
38.72 KB, 下载次数: 7, 下载积分: 黑币 -5
ID:117823 发表于 2016-6-4 02:11 来自触屏版 | 只看该作者
在1602上显示四线的可以,164转两线的也可以,iicpcf8574,74hc595均可以,在1m时钟下可以不延时,在8m时钟下可以不延时,在16m时钟下一定要延时。下
参与人数 1黑币 +40 收起 理由
admin + 40 很给力!
