查看: 2168|回复: 0
求助39SF040的读写怎么也不通
ID:114127 发表于 2016-4-14 08:39 | 显示全部楼层 |阅读模式
void delay_10us(unsigned int us)
    while(us--)
        _nop_();_nop_();_nop_();_nop_();_nop_();_nop_();
void delay_Nms(unsigned int ms)
    unsigned int i;
    while(ms--)
        i=252;
        while(i--);
void protect() //解除保护
   // select_segment(0);/*必须写到第0段*/
   P4=0X00;
    XBYTE[0x5555]=0xaa;
    delay_10us(2);
    XBYTE[0x2aaa]=0x55;
    delay_10us(2);
    XBYTE[0x5555]=0xa0;
    delay_10us(2);
/*************39SF020扇区分布****************
地址从00000-3FFFF
每个扇区大小是:4Kbytes  哪么:
0扇区:0 0000-0 0FFF       1扇区:0 1000-0 1FFF
2扇区:0 2000-0 2FFF       3扇区:0 3000-0 3FFF
4扇区:0 4000-0 4FFF       5扇区:0 5000-0 5FFF
62扇区:3 E000-3 EFFF      63扇区:3 F000-3 FFFF
void SectorErase(unsigned char H_addr,unsigned int SectorAddr)//扇区擦除
     //select_segment(H_addr);    /*设置高位*/
     CE=0;
     XBYTE[0x5555]=0xaa;
     delay_10us(2);
     XBYTE[0x2aaa]=0x55;
     delay_10us(2);
     XBYTE[0x5555]=0x80;
     delay_10us(2);
     XBYTE[0x5555]=0xAA;
     delay_10us(2);
     XBYTE[0x2AAA]=0x55;
     delay_10us(2);
     XBYTE[SectorAddr]=0x30;
     delay_10us(2);
     CE=1;
     delay_Nms(30);
void ChipErase()//整片擦除
    // CE=0;
      CE=0;
    //RAM3=0;
     XBYTE[0x5555]=0xaa;
     delay_10us(4);
     XBYTE[0x2aaa]=0x55;
     delay_10us(4);
     XBYTE[0x5555]=0x80;
     delay_10us(4);
     XBYTE[0x5555]=0xAA;
     delay_10us(4);
     XBYTE[0x2AAA]=0x55;
     delay_10us(4);
     XBYTE[0x5555]=0x10;
     delay_10us(4);
     CE=1;
     delay_Nms(100);
unsigned char Read39SF02abyte(unsigned char H_addr,unsigned int L_addr)//读数据
    unsigned char  i;
    //unsigned char i;
    CE=0;
  //  select_segment(H_addr&0x03); /*s_sector 是256的整数倍*/
    i=XBYTE[L_addr];
    CE=1;
  // RAM3=1;
    return  i;
void Write39SF02abyte(unsigned char H_addr,unsigned int L_addr,unsigned char W_Data) //写数据
    CE=0;
    protect(); //解除保护
    XBYTE[L_addr]=W_Data;    //高位
    delay_10us(2);
    CE=1;
  // RAM3=1;
main
ChipErase();
   Write39SF02abyte(00,0X1001,0X55) ;//写数据
    Write39SF02abyte(00,0X1002,0X55); //写数据
     Write39SF02abyte(00,0X1003,0X55);//写数据
     Write39SF02abyte(00,0X1004,0XAA) ;//写数据
      Write39SF02abyte(00,0X1005,0XAA); //写数据
   HHH= Read39SF02abyte(00,0X1001);//读数据
   HHH= Read39SF02abyte(00,0X1002);//读数据
   HHH= Read39SF02abyte(00,0X1003);//读数据
   HHH= Read39SF02abyte(00,0X1004);//读数据
   HHH= Read39SF02abyte(00,0X1005);//读数据
   HHH  =XBYTE[0X1001]  ;}
