查看: 2564|回复: 0
蓝牙小车源代码
ID:117095 发表于 2016-4-27 16:37 | 显示全部楼层 |阅读模式
教程http://www.51hei.com/bbs/dpj-44598-1.html
void motor(char pin,char pwmpin,char state,int val) {     pinMode(pin, OUTPUT);
                 if(state==1)   {       analogWrite(pwmpin,val);     digitalWrite(pin,1);    }
                 else if(state==2)  {      analogWrite(pwmpin,val);    digitalWrite(pin,0);  }
                 else if(state==0)  {     analogWrite(pwmpin,0);     digitalWrite(pin,0);  } }
                 void runfoward(int i) {   motor(4,5,1,i);   motor(7,6,1,i); }
                 void runback(int j) {    motor(4,5,2,j);    motor(7,6,2,j);  }
                 void turnL(int m) {   motor(4,5,1,m);   motor(7,6,2,m); }
                 void turnR(int n) {   motor(4,5,2,n);   motor(7,6,1,n); }
                 void stop() {   motor(4,5,0,0);   motor(7,6,1,0);  }
                 void setup() {   Serial.begin(9600); }
                 void loop() {    while (Serial.available() > 0)
                 {     int inChar = Serial.read();     inChar=inChar-0x30;
                 if(inChar == 1)  //foward
                 {         runfoward(250);        delay(300);        stop();       }
                       else if(inChar == 2)  //back
                 {        runback(250);        delay(300);        stop();       }
                      else if(inChar == 3)  //R
                          {        turnR(250);        delay(300);        stop();       }
                          else if(inChar == 4)  //L
                          {        turnL(250);        delay(300);        stop();       }
                          else      {         stop();       }       inChar=0;  } }
  if(state==1)
  else if(state==2)
else if(state==0)
  motor(4,5,1,i);
  motor(7,6,1,i);
void runback(int j)
   motor(4,5,2,j);
   motor(7,6,2,j);
void turnL(int m)
  motor(4,5,1,m);
  motor(7,6,2,m);
void turnR(int n)
  motor(4,5,2,n);
  motor(7,6,1,n);
void stop()
  motor(4,5,0,0);
  motor(7,6,1,0);
void setup()
  Serial.begin(9600);
void loop()
   while (Serial.available() > 0) {
    inChar=inChar-0x30;
        runfoward(250);
       delay(300);
       stop();
       runback(250);
       delay(300);
       stop();
       turnR(250);
       delay(300);
       stop();
       turnL(250);
       delay(300);
       stop();
        stop();
     inChar=0;
