查看: 2406|回复: 1
抢答器程序
ID:118186 发表于 2016-5-3 16:58 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
# include <reg52.h>
# define uint unsigned int
# define uchar unsigned char
uchar t0,t1,ge,shi;
char temp;
uchar flag,flag1,cout,j,k,kai,i;
bit ok;
uint x,y,z;
sbit wela=P2^7;
sbit dula=P2^6;
sbit beep=P2^3;
sbit key1=P3^4;
sbit key2=P3^5;
sbit key3=P3^6;
sbit key4=P3^7;
sbit key5=P3^0;
uchar code table[]=
        0x3f,0x06,0x5b,0x4f,
        0x66,0x6d,0x7d,0x07,
        0x7f,0x6f,0x00
void delay(uint z)
        uint x,y;
        for(x=z;x>0;x--)
                for(y=114;y>0;y--);
void display(uchar shi,uchar ge)
                dula=1;
                P0=table[shi];
                dula=0;
                P0=0xff;                //消隐
                wela=1;
                P0=0xfe;
                wela=0;
                delay(5);
                dula=1;
                P0=table[ge];
                dula=0;
                P0=0xff;           //消隐
                wela=1;
                P0=0xdf;
                wela=0;
                delay(5);
void key1scan()
//        P3=0xff;
        if(key1==0)                                                   //主持人按钮
                        delay(5);
                        if(key1==0)
                             temp=10;
                                TR0=1;
        //                        TR1=1;
                                beep=1;
                                flag=0;
                                flag1=1;
                                cout=1;
                                if(cout==1)
                                        P1=0xff;
/*                        while(key1!=1);
                        delay(5);
                        while(key1!=1);         */
void keyscan()
        wela=1;
        P0=0xdf;
        wela=0;
        delay(5);
        if(flag==0&&flag1==1)
            if(key2==0)                                                         //第一位选手的按钮
                                delay(5);
                                if(key2==0)
                //                        key3=1;
                //                        key4=1;
                                    TR0=0;
                                        TR1=1;
                        //                shi=temp%10;
                                        ge=1;
                        //                display(shi,1);
                        //                TR1=1;
                                    beep=1;
                                        flag=1;
                                        flag1=0;
                                        cout=0;
                                        if(cout==0)
                                                P1=0xff;
                                            delay(5);
                                                P1=0xfe;
/*                                while(key2!=1);
                                delay(5);
                                while(key2!=1);                 */
        /*                        for(i=0;i<28000;i++)
                                        beep=0;
                                beep=1;                                */
                else if(key3==0)                                                   //第二位选手的按钮
                                delay(5);
                                if(key3==0)
                                    TR0=0;
                                        TR1=1;
                //                        shi=temp%10;
                                        ge=2;
                        //                display(shi,2);
                                        P1=0xff;
                                        delay(5);
                                        P1=0xfd;
                                        beep=1;
                                        flag=1;
                                        flag1=0;
                                        cout=0;
                                        if(cout==0)
                                                        P1=0xff;
                                                    delay(5);
                                                        P1=0xfd;
        /*                        while(key3!=1);
                                delay(5);
                                while(key3!=1);                                   */
                else if(key4==0)
                                delay(5);
                                if(key4==0)                                                        //第三位选手的按钮
                                    TR0=0;
                                        TR1=1;
                        //                shi=temp%10;
                                        ge=3;
                //                        display(shi,3);
                                        P1=0xff;
                                        delay(5);
                                        P1=0xfb;
                                        beep=1;
                                        flag=1;
                                        flag1=0;
                                        cout=0;
                                        if(cout==0)
                                                        P1=0xff;
                                                    delay(5);
                                                        P1=0xfb;
        /*                        while(key4!=1);
                                delay(5);
                                while(key4!=1);                                 */
/*        dula=1;
        P0=table[ge];
        dula=0;
        P0=0xff;
void dispose()
        if(ok==0&&t0%9==0)
                beep=1;
        if(t0==18)
                t0=0;
                temp--;
            shi=temp%10;
                ge=temp/10;
                P1=~P1;
            switch(temp)
                        case 0: TR0=0;TR1=1;flag=1;beep=~beep;kai=1;//ok=1;
                                break;
                        case 3: beep=~beep;ok=0;kai=0;
                                break;
                        case 2: beep=~beep;ok=0;kai=0;
                                break;
                        case 1: beep=~beep;ok=0;kai=0;
                                break;
                        case 9: beep=~beep;ok=1;kai=0;
                                break;
                        case 8: beep=~beep;ok=1;kai=0;
                                break;
void init()
        TMOD=0x11;
        TH0=(65536-50000)/256;
        TL0=(65536-50000)%256;
        TH1=(65536-50000)/256;
        TL1=(65536-50000)%256;
        EA=1;
        ET0=1;
        ET1=1;
        temp=0;
//        shi=temp/10;
//        ge=temp%10;
        wela=1;
        P0=0x0c;
        wela=0;
        dula=1;
        P0=0x3f;
        dula=0;
        init();
                P0=0; //消隐,一开始会有东西闪一下,加这句就不会了
                key1scan();
                dispose();
                display(shi,ge);
                keyscan();
/*                        num1=keyscan();                //把keyscan中num的返回值赋给num1
                        dula=1;
                        D=table[num1-1];
                        dula=0;                           */
void timer0() interrupt 1
        t0++;
void timer1() interrupt 3
        beep=0;
        t1++;
        if(t1==8)
                t1=0;
                beep=1;
                TR1=0;
        if(kai==1&&t1==500)
                t1=0;
                beep=1;
                TR1=0;
