查看: 2099|回复: 1
跪求c51的循迹程序,是四对管的
ID:113369 发表于 2016-5-14 12:21 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
跪求c51的循迹程序,是四对管的
ID:97007 发表于 2016-5-14 12:38 | 只看该作者
#include <REGX52.H>
#define uchar unsinged char
#define uint unsinged int
//*****驱动芯片l298管脚位声明******
sbit PWM2=P1^0;
sbit PWM1=P1^5;
sbit IN1=P1^4;
sbit IN2=P1^3;
sbit IN3=P1^2;
sbit IN4=P1^1;
//*******传感器TCRT管脚位声明*******
sbit XL=P3^7;//左一
sbit YL=P3^6;//左二
sbit XR=P3^5;//右一
sbit YR=P3^4;//右二
//******用于定时计数的两个全局变量位声明****
int count1=0;
int count2=0;
//*****左边电机前进*****
void forward_turn1()
   IN1=0;
   IN2=1;
//*****左边电机后退*****
void reverse_turn1()
   IN1=1;
   IN2=0;
//*****右边电机前进*****
void forward_turn2()
   IN3=0;
   IN4=1;
//*****右边电机后退*****
void reverse_tuen2()
   IN3=1;
   IN4=0;
//******左边电机速度控制函数*****
void speed1(int ct,int sd)
        if(ct<=sd)
          PWM1=1;
          PWM1=0;
//******右边电机速度控制函数*****
void speed2(int ct,int sd)
        if(ct<=sd)
          PWM2=1;
          PWM2=0;
//**********小车直线前进函数*******
void advance(int ct1,int sd1,int ct2,int sd2)
        forward_turn1();
        forward_turn2();
        speed1(ct1,sd1);
        speed2(ct2,sd2);
//******小车左转*******
void Left_turn1(int ct1,int sd1,int ct2,int sd2)
        forward_turn1();
        forward_turn2();
        speed1(ct1,sd1);
        speed2(ct2,sd2);
//******小车右转*******
void Right_turn2(int ct1,int sd1,int ct2,int sd2)
        forward_turn1();
        forward_turn2();
        speed1(ct1,sd1);
        speed2(ct2,sd2);
//*******主函数********
main()
        TMOD=0X11;
        TH0=(65536-1000)/256;
    TL0=(65536-1000)%256;
        EA=1;
        EX0=1;
        ET0=1;
        TR0=1;
        TH1=(65536-1000)/256;
    TL1=(65536-1000)%256;
        EA=1;
        EX1=1;
        ET1=1;
        TR1=1;
                if(XL==0&&XR==0&&YL==0&&YR==0)        //传感器未检测到直线,小车直行
                        advance(count1,500,count2,500);
                        if(XL==0&&XR==0&&YL==1&&YR==0)        //左边内测检测到,小左转
                    Left_turn1(count1,0,count2,100);
                        if(XL==1&&XR==0&&YL==0&&YR==0)        //左外,大左转
                        Left_turn1(count1,0,count2,150);
                        if(XL==0&&XR==0&&YL==0&&YR==1)        //右内,小右转
                        Right_turn2(count1,100,count2,0);
                    if(XL==0&&XR==1&&YL==0&&YR==0)        //右外,大右转
                        Right_turn2(count1,150,count2,0);
                /*        if(XL==1&&XR==0&&YL==1&&YR==0)        //左2,中左转
                        Left_turn1(count1,100,count2,300);
                        if(XL==0&&XR==1&&YL==0&&YR==1)        //右2,中右转
                        Right_turn2(count1,300,count2,100);
//*********中断服务程序*******
void time0() interrupt 1
        count1++;
        if(count1>=1000)
        count1=0;
void time1() interrupt 3
        count2++;
        if(count2>=1000)
        count2=0;
参与人数 1黑币 +100 收起 理由
admin + 100 回帖助人的奖励!
