查看: 1517|回复: 0
求大神解答
ID:121740 发表于 2016-5-19 13:46 来自触屏版 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
您好我是学习单片机的新手
我编写了从0到60的数码管显示 但只个位显示 十位只闪耀
请您帮助求解 #include<reg51.h>#define uint unsigned int#define uchar unsigned charsbit DUAN=P2^6;sbit WEI=P2^7;unsigned code ds[]={0x30,0x06,0x5b,0x4f,0x66,                         0x6d,0x7d,0x07,0x7f,0x6f,                                                 0x77,0x7c,0x39,0x5e,0x79,0x71};uchar shiwei,gewei,temp,aa;uint x,y;void delay(uint z);   //延时void display(uchar shiwei,uchar gewei);  //显示函数声明void InitTimer0();void main(void){    InitTimer0();        while(1)                if(aa==20)         //判断是否达到1秒            {                    aa=0;                     temp++;                if(temp==60)  //temp变化范围                {                        temp=0;                }                    shiwei=temp/10;                   //十位                    gewei=temp%10;                 //        个位                display(shiwei,gewei);           //调用显示函数        } }void delay(uint z){  // uint x,y;        for(x=z;x>0;x--)          for(y=110;y>0;y--); } void display(uchar shiwei,uchar gewei) //显示函数{        P0=ds[shiwei];        DUAN=1;        DUAN=0;        P0=0xfe;           WEI=1;        WEI=0;          delay(5);        P0=ds[gewei];        DUAN=1;        DUAN=0;        P0=0xfd;        WEI=1;        WEI=0;           delay(5);} void InitTimer0(void)        //定时器 初始化{    DUAN=0;        WEI=0;        temp=0;    TMOD = 0x01;    TH0 = 0x4c;    TL0 = 0x00;    EA = 1;    ET0 = 1;    TR0 = 1;}void Timer0Interrupt(void) interrupt 1   //  中断{    TH0 = 0x4c;    TL0 = 0x00;         aa++;                     }
