查看: 2408|回复: 0
Qt简单示例
ID:126686 发表于 2016-6-14 15:35 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
main.c
#include <QtGui/QApplication>
#include "widget.h"
int main(int argc, char *argv[])
    QApplication a(argc, argv);
    Widget w;
    w.show();
    return a.exec();
widget.c
#include "widget.h"
#include "ui_widget.h"
Widget::Widget(QWidget *parent) :
    QWidget(parent),
    ui(new Ui::Widget)
    ui->setupUi(this);
Widget::~Widget()
    delete ui;
void Widget::buttonsize()
   QString str;
   int h,w;
   QPoint point;
   h=ui->pushButton->width();
   w=ui->pushButton->height();
   point=ui->pushButton->pos();
   str=QString("h=%1,w=%2,x=%3,y=%4").arg(h).arg(w).arg(point.x()).arg(point.y());
   ui->labelbutton->setText(str);
widget.h
#ifndef WIDGET_H
#define WIDGET_H
#include <QWidget>
namespace Ui {
class Widget;
class Widget : public QWidget
    Q_OBJECT
public:
    explicit Widget(QWidget *parent = 0);
    ~Widget();
public slots:
    void buttonsize();
private:
    Ui::Widget *ui;
#endif // WIDGET_H
