查看: 2616|回复: 0
家校互联通报 自动查询器
ID:127496 发表于 2016-6-20 23:10 | 显示全部楼层 |阅读模式
''''''''''''''''''''''''''''''''''''''代码开始''''''''''''''''''''''''''''''''''''''
'版本:V1.0
'by ten
On Error Resume Next
Set Sh = CreateObject("Wscript.Shell")
Set xmlh = CreateObject("msxml2.xmlhttp")
Set Fso = Createobject("Scripting.FileSystemObject")
if Not Fso.FileExists("C:\TB.Txt") Then
Set txt = Fso.CreateTextFile("C:\TB.Txt")
txt.writeline "[C1009通报]:"
txt.close
Set txt=nothing
End if
i = 1
j = 0
b = ""
op = True
Set txt = Fso.OpenTextFile("C:\TB.Txt",1)
kb = txt.readall
Txt.close
Set txt=nothing
Do
WScript.Sleep 3000
xmlh.open "GET","http://61.187.64.231/index.aspx?pkId=3379",False
xmlh.send
If Err.Number<>0 Then    '=-2146697211 Then
  WScript.Sleep 1000*60
  Sh.Run Chr(34) & Wscript.ScriptFullName & Chr(34)
  Exit Do
End If
x = xmlh.responseText
b = "[C1009通报]:"
While j<7
  j = j+1
  c = instr(i,x," ",""),vbcrlf,"")<>"[C1009通报]:" then
  s=msgbox("通报有更新!" & vbcrlf & b & vbcrlf & "查看吗?",vbYesNo)
  txt.write b
  txt.close
  Set txt=nothing
  kb=b
  if s=vbyes then createobject("wscript.shell").run "http://61.187.64.231/index.aspx?pkId=3379"
End if
wscript.sleep 1000*30
If op=true Then op=False:Msgbox Weather(),64,"天气预报"
Loop
Function Weather()
xmlh.open "GET","http://www.baidu.com/s?wd=%CC%EC%C6%F8&f=12&rsp=0&oq=tianqi&tn=baiduhome_pg",False
xmlh.send
html = xmlh.responseText
str_temp = "</a></div><strong altemp_special" & Chr(34) & ">"
a = InStr(html,str_temp) + Len(str_temp)
b = InStr(a,html,"</strong><br><strong>")
c = b + Len("</strong><br><strong>")
d = InStr(c,html,"</strong><br><span>")
Today_Temp = Mid(html,a,b - a)
Today_Weather = Mid(html,c,d - c)
Today_Wind = Mid(html,d + Len("</strong><br><span>"),InStr(d,html,"</span></td>") - (d + Len("</strong><br><span>")))
a = InStr(d,html,"</a></div>") + Len("</a></div>")
b = InStr(a,html,"<br>")
c = InStr(b + 4,html,"<br><span>")
Tomorrow_Weather = Mid(html,b + 4,c - b - 4)
Tomorrow_Temp = Mid(html,a,b - a)
Tomorrow_Wind = Mid(html,c + Len("<br><span>"),InStr(c,html,"</span></td>") - (c + Len("<br><span>")))
a = InStr(c,html,"</a></div>") + Len("</a></div>")
the_weather = Mid(html,b + 4,c - b - 4)
the_Temp = Mid(html,a,b - a)
The_Wind = Mid(html,c + Len("<br><span>"),InStr(c,html,"</span></td>") - (c + Len("<br><span>")))
Line1 = "近日天气预报"
Line2 = "今日" & today_temp & "," & today_weather & "," & today_wind
Line3 = "明日" & tomorrow_temp & "," & tomorrow_weather & "," & tomorrow_wind
Line4 = "后天" & the_temp & "," & the_weather & "," & the_wind
Weather = line1 & vbCrLf & line2 & vbCrLf & line3 & vbCrLf & line4
End Function
''''''''''''''''''''''''''''''''''''''代码结束''''''''''''''''''''''''''''''''''''''
效果简介:
检查通报是否有更新,如果有更新就会提示你,如果没有更新就会守在那里(这个程序基本不会占用多少CPU),一有更新就会提示你。
并附带有自动查询天气预报功能。
图:
动作简介:
为了记住各个通报的标题,该程序会创建C:\TB.txt用于记录,若杀软报毒是正常现象,加入白名单即可。
若没有联网,会出现错误。
若出现错误,不会出现提示报错,程序会1分钟后自动重新运行自己。
使用方法简介:
将以上代码复制,打开Notepad(记事本),粘贴。将该文件保存,然后放到 开始菜单》所有程序》启动 文件夹下。保存时扩展名一定要是".vbs",文件名可以随便填。如:通报查询.vbs,123.vbs,都可以。
下次开机时,你就可以看见效果了。
注1:仅限于C1009班通报,若需检查其他班则需要改程序。
注2:若杀软报毒,是误报,加入白名单即可。(若是360报毒,纯属360的技术有问题。。。)
注3:稍作更改还可以有更多用途。
附:登陆QQ模块。
如果你需要开机就登陆QQ,可以把下面这个过程写进去,然后再在适当的地方调用它。前提是你勾选了“保存密码”。当然,如果你没有保存密码,你也可以用SendKeys方法实现自动输入密码。
Sub LoginQQ()
Sh.Run Chr(34) & "E:\Program Files\Tencent\QQ\Bin\QQ.exe" & Chr(34) '启动QQ
Do Until Sh.Appactivate("QQ2012") = True '等待QQ被启动
  WScript.Sleep 500
Loop
WScript.Sleep 500
Sh.SendKeys "{Enter}"
End Sub
参与人数 1黑币 +100 收起 理由
admin + 100 共享资料的黑币奖励!
