查看: 2193|回复: 0
矩阵键盘
ID:128093 发表于 2016-6-25 16:36 | 显示全部楼层 |阅读模式
#include <reg52.h>
#define uint  unsigned int
sbit we = P2^7;
sbit du = P2^6;
uchar code leddata[]={
                0x3F,  //"0"
                0x06,  //"1"
                0x5B,  //"2"
                0x4F,  //"3"
                0x66,  //"4"
                0x6D,  //"5"
                0x7D,  //"6"
                0x07,  //"7"
                0x7F,  //"8"
                0x6F,  //"9"
                0x77,  //"A"
                0x7C,  //"B"
                0x39,  //"C"
                0x5E,  //"D"
                0x79,  //"E"
                0x71,  //"F"
                0x76,  //"H"
                0x38,  //"L"
                0x37,  //"n"
                0x3E,  //"u"
                0x73,  //"P"
                0x5C,  //"o"
                0x40,  //"-"
                0x00,  //熄灭
                0x00  //自定义
void delay(uint z)
        uint x,y;
        for(x = z; x > 0; x--)
                for(y = 114; y > 0 ; y--);
uchar KeyScan()        //带返回值的子函数
        uchar cord_l,cord_h;//声明列线和行线的值的储存变量
        P3 = 0x0f;//0000 1111
        if( (P3 & 0x0f) != 0x0f)//判断是否有按键按下
                delay(5);//软件消抖
                          cord_h = P3 & 0x0f;// 储存行线值
                          P3 = cord_l | 0xf0;
                          cord_l = P3 & 0xf0;// 储存列线值
                          while( (P3 & 0xf0) != 0xf0 );//松手检测
                          return (cord_l + cord_h);//返回键值码
void KeyPro()
        switch( KeyScan() )
                 //第一行键值码
                case 0xee: P0 = leddata[0];                break;
                case 0xde: P0 = leddata[1];                break;
                case 0xbe: P0 = leddata[2];                break;
                case 0x7e: P0 = leddata[3];                break;
                //第二行键值码
                case 0xed: P0 = leddata[4];                break;
                case 0xdd: P0 = leddata[5];                break;
                case 0xbd: P0 = leddata[6];                break;
                case 0x7d: P0 = leddata[7];                break;
                //第三行键值码
                case 0xeb: P0 = leddata[8];                break;
                case 0xdb: P0 = leddata[9];                break;
                case 0xbb: P0 = leddata[10];        break;
                case 0x7b: P0 = leddata[11];        break;
                //第四行键值码
                case 0xe7: P0 = leddata[12];        break;
                case 0xd7: P0 = leddata[13];        break;
                case 0xb7: P0 = leddata[14];        break;
                case 0x77: P0 = leddata[15];        break;
                //独立键盘
                case 0xfe: P0 = leddata[16];        break;
                case 0xfd: P0 = leddata[17];        break;
                case 0xfb: P0 = leddata[18];        break;
                case 0xf7: P0 = leddata[19];        break;
        we = 1;//打开位选
        P0 = 0;//八位数码管全显示
        we = 0;//锁存位选
        du = 1;//打开段选端
        P0 = leddata[22];
                 KeyPro();//提取键值码并且送不同数值给数码管显示
