查看: 2666|回复: 2
谁帮我看看独立按键程序,不知道哪里出问题
ID:122090 发表于 2016-7-5 16:02 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include<reg52.h>
sbit dula  = P2^6;
sbit wela  = P2^7;
sbit KEY_1 = P3^7;
unsigned char leddata[]={
                0x3F,  //"0"
                0x06,  //"1"
                0x5B,  //"2"
                0x4F,  //"3"
                0x66,  //"4"
                0x6D,  //"5"
                0x7D,  //"6"
                0x07,  //"7"
                0x7F,  //"8"
                0x6F,  //"9"
void delay_xms(uint xms) //延时函数
        uint i,j;
        for(i=xms;i>0;i--)
                for(j=110;j>0;j--);
void display(uchar shi,uchar ge) //显示函数
        wela = 1;
        P0 = 0xfe;
        wela = 0;
        P0 = 0xff;
        dula = 1;
        P0 = leddata[shi];
        dula = 0;
        delay_xms(5);
        wela = 1;
        P0 = 0xfd;
        wela = 0;
        P0 = 0xff;
        dula = 1;
        P0 = leddata[ge];
        dula = 0;
        delay_xms(5);
void keyscan() //按键扫描
        uchar num,shi,ge;
        if(KEY_1==0)
                delay_xms(10);
                if(KEY_1==0)
                        num++;
                        if(num==20)
                                num=0;
                        shi=num/10;
                        ge=num%10;
                        while(!KEY_1);
                display(shi,ge);
                keyscan();
实现功能:用独立按键 按下数码管加1
我这样写的函数,实现不了,求解哪里的问题 谢谢大神。小白一枚
ID:79544 发表于 2016-7-6 09:13 | 只看该作者
你的程序写到有问题,我改了一下现在正常啦
  1. #include<reg52.h>
  2. #define uint unsigned int
  4. sbit dula  = P2^6;
  5. sbit wela  = P2^7;
  6. sbit KEY_1 = P3^7;//加
  7. sbit KEY_2 = P3^6;//减
  8. uchar num,shi,ge,i;
  9. uchar leddata[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,
  10.                                 0x82,0xf8,0x80,0x90,0x88,0x83,0xc6,
  11.                                 0xa1,0x86,0x8e,0x89};
  12. /*uchar leddata[]={
  13.                 0x3F,  //"0"
  14.                 0x06,  //"1"
  15.                 0x5B,  //"2"
  16.                 0x4F,  //"3"
  17.                 0x66,  //"4"
  18.                 0x6D,  //"5"
  19.                 0x7D,  //"6"
  20.                 0x07,  //"7"
  21.                 0x7F,  //"8"
  22.                 0x6F,  //"9"
  23.                          };*/
  24. void delay_xms(uint xms) //延时函数
  25. {
  26.     uint i,j;
  27.     for(i=xms;i>0;i--)
  28.      for(j=110;j>0;j--);
  29. }
  30. void display(uchar num) //显示函数
  31. {
  32.         shi=num/10;
  33.     ge=num%10;
  34.         for(i=0;i<10;i++)//显示10次增加亮度
  35.         {
  36.     wela = 1;
  37.     P0 = 0xfe;
  38.     wela = 0;
  39.            dula = 1;
  40.     P0 = leddata[shi];
  41.     dula = 0;
  42.     delay_xms(5);
  43.         P0 = 0xff;
  44.
  45.     wela = 1;
  46.     P0 = 0xfd;
  47.     wela = 0;
  48.      dula = 1;
  49.     P0 = leddata[ge];
  50.     dula = 0;
  51.     delay_xms(5);
  52.         P0 = 0xff;
  53.         }
  54. }
  55. void keyscan() //按键扫描
  56. {
  57.     if(KEY_1==0)
  58.     {
  59.         delay_xms(10);
  60.         if(KEY_1==0)
  61.         {
  62.             num++;
  63.             if(num==99)
  64.                num=0;
  65.
  66.         }
  67.                 while(!KEY_1);
  68.     }
  69.         if(KEY_2==0)
  70.     {
  71.         delay_xms(10);
  72.         if(KEY_2==0)
  73.         {
  74.             num--;
  75.             if(num==0)
  76.                num=0;
  77.
  78.         }
  79.                 while(!KEY_2);
  80.     }
  81. }
  82. void main()
  83. {
  84.         num=0;
  85.     while(1)
  86.     {
  87.         keyscan();
  88.                 display(num);
  89.     }
  90. }
ID:127936 发表于 2016-7-6 12:07 | 只看该作者
把  display(shi,ge);  放在主函数里面,num,ge,shi 定义为全局变量
#include<reg52.h>
sbit dula  = P2^6;
sbit wela  = P2^7;
sbit KEY_1 = P3^7;
uchar num,shi,ge;
                0x3F,  //"0"
                0x06,  //"1"
                0x5B,  //"2"
                0x4F,  //"3"
                0x66,  //"4"
                0x6D,  //"5"
                0x7D,  //"6"
                0x07,  //"7"
                0x7F,  //"8"
                0x6F,  //"9"
        uint i,j;
        for(i=xms;i>0;i--)
                for(j=110;j>0;j--);
        wela = 1;
        P0 = 0xfe;
        wela = 0;
        P0 = 0xff;
        dula = 1;
        P0 = leddata[shi];
        dula = 0;
        delay_xms(5);
        wela = 1;
        P0 = 0xfd;
        wela = 0;
        P0 = 0xff;
        dula = 1;
        P0 = leddata[ge];
        dula = 0;
        delay_xms(5);
        if(KEY_1==0)
                delay_xms(10);
                if(KEY_1==0)
                        num++;
                        if(num==20)
                                num=0;
                        shi=num/10;
                        ge=num%10;
                        while(!KEY_1);
                keyscan();
                                display(shi,ge);
