查看: 3310|回复: 0
有关ADXL345自动休眠设置的问题,大神帮我看看程序有什么问题
ID:122633 发表于 2016-7-14 10:54 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
ADXL345怎么才能进入自动休眠 下面是我的程序,一直进不了休眠,大神帮我看看:
Single_Write_ADXL345(POWER_CTL,0x00);
Single_Write_ADXL345(INT_ENABLE,0x00);
Single_Write_ADXL345(BW_RATE,0x08);      //0000 0110速率设定为6.25 参考pdf13页
Single_Write_ADXL345(DATA_FORMAT,0x2F);   //测量范围,正负16g,13位模式  0X2b D5=1,中断设置为低电平有效
Single_Write_ADXL345(THRESH_ACT,0x01);    //活动阀值(xy)1000MG 62.5mg/L
Single_Write_ADXL345(THRESH_INACT,0x03);    // 静止阀值(xyz?)(根据实际调整) 时阈
Single_Write_ADXL345(TIME_INACT,0x03);     //时阈 5s
// Single_Write_ADXL345(DUR,0xF0);       //敲击检测时阈
Single_Write_ADXL345(ACT_INACT_CTL,0xEE);    //0110 0110 直(交)流耦合 活动检测使能xy 静止检测使能XY
Single_Write_ADXL345(0x2F,0x10);    //中断引脚映射INT_MAP , 活动中断配置到INT2,静止中断到INT1
Single_Write_ADXL345(0x2E,0x18);    //中断使能 INT_ENABLLE
      Single_Read_ADXL345(INT_SOURCE);               //清零中断
Single_Write_ADXL345(POWER_CTL,0x34);    //电源设置 休眠使能 0x38  0x08 0x34
    Single_Write_ADXL345(0x1E,0x00);   //X 偏移量 根据测试传感器的状态写入pdf29页
    Single_Write_ADXL345(0x1F,0x00);   //Y 偏移量 根据测试传感器的状态写入pdf29页
    Single_Write_ADXL345(0x20,0x05);   //Z 偏移量 根据测试传感器的状态写入pdf29页
中断发生后清除:
Single_Read_ADXL345(ACT_TAP_STATUS);
