查看: 15919|回复: 6
压力传感器stc15w408as单片机程序和电路原理图
ID:262 发表于 2016-8-12 16:21 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
1,优化后的程序:
#include"reg51.h"
#define U16 unsigned int
#define U8  unsigned char
U16 temp=550,temp1;
U8 nn;
bit flag;
unsigned char dd0[]=" machine ON";
unsigned char dd1[]="machine OFF";
sbit rs=P1^1;
sbit en=P1^0;    //Use really  P5.4,test P2.4
sbit D0=ACC^0;
sbit D1=ACC^1;
sbit D2=ACC^2;
sbit D3=ACC^3;
sbit D4=ACC^4;
sbit D5=ACC^5;
sbit D6=ACC^6;
sbit D7=ACC^7;
void delay(U16 us)
U8 m;
while(us--)
for(m=0;m<30;m++);
void w1602c(U8 dat)
rs=0;
  en=0;
ACC=dat;
P30=D0;
P31=D1;
P32=D2;
P33=D3;
P14=D4;
P15=D5;
P36=D6;
P37=D7;
delay(3);
en=1;
delay(3);
en=0;
void w1602d(U8 dat)
ACC=dat;
P30=D0;
P31=D1;
P32=D2;
P33=D3;
P14=D4;
P15=D5;
P36=D6;
P37=D7;
rs=1;
en=0;
delay(3);
en=1;
delay(3);
en=0;
void init1602()
 w1602c(0x38);
 w1602c(0x06);
 w1602c(0x0c);
 w1602c(0x01);
void InitADC()
  P1ASF =0x04;  //P1.2 ADC_IN - +
  ADC_RES=0;
  ADC_RESL=0;
  ADC_CONTR =0xe2;//ON_POWER
  delay(2);
void disp(U16 dd)
w1602d(dd/1000+0x30);
w1602d((dd%1000)/100+0x30);
w1602d(((dd%1000)%100)/10+0x30);
w1602d(dd%10+0x30);
U16 ADC10()
//  bit r;           //test use
 InitADC();
    ADC_CONTR |=0x0a;
    delay(2);
////*******Use really************//
while(!(ADC_CONTR & 0x10));  //
ADC_CONTR &=~0x10;           //
temp=ADC_RES;                //
temp=temp<<2;                //
temp |=ADC_RESL;             //
////*********end Use really******//
////////**test**************//
// if(r==0)              //
// temp++;             //
// if(temp>620)r=1;    //
// if(r==1)              //
// temp--;             //
// if(temp<490)r=0;    //
//////*****test end ******//
 return temp;
  U8 k;
init1602();
  P1M1=0x40;     //P1.2 DAC_in
  P1M0=0x00;
CLK_DIV &=~0x20;
temp1=ADC10();
if(temp<500)flag=1;
while(flag)
temp1=ADC10();
        if(temp1>602)flag=0;
 P13=1;
w1602c(0x80);
for(k=0;k<11;k++)
w1602d(dd0[k]);
 w1602c(0xc0);
 disp(temp1);
 delay(2000);
while(!flag)
temp1=ADC10();
        if(temp1<500)flag=1;
 P13=0;
w1602c(0x80);
for(k=0;k<11;k++)
w1602d(dd1[k]);
 w1602c(0xc0);
 disp(temp1);
 delay(2000);
#include"reg51.h"
U16 temp=600,temp1;
U8 nn;
bit flag;
unsigned char dd0[]=" SHANXI Dianzi";
unsigned char dd1[]=" VOIT_H:";
sbit rs=P3^7;
sbit en=P5^4;
sbit D0=ACC^0;
sbit D1=ACC^1;
sbit D2=ACC^2;
sbit D3=ACC^3;
sbit D4=ACC^4;
sbit D5=ACC^5;
sbit D6=ACC^6;
sbit D7=ACC^7;
void delay(U16 ms)
U8 m;
while(ms--)
for(m=0;m<30;m++);
void w1602c(unsigned char dat)
ACC=dat;
P11=D0;
P12=D1;
P13=D2;
P14=D3;
P15=D4;
P32=D5;
P33=D6;
P36=D7;
rs=0;
en=0;
delay(2);
en=1;
delay(2);
en=0;
void w1602d(unsigned char dat)
ACC=dat;
P11=D0;
P12=D1;
P13=D2;
P14=D3;
P15=D4;
P32=D5;
P33=D6;
P36=D7;
rs=1;
en=0;
delay(2);
en=1;
delay(2);
en=0;
void init1602()
 w1602c(0x38);
 w1602c(0x06);
 w1602c(0x0c);
 w1602c(0x01);
void InitADC()
  P1ASF =0x01;  //P1.2 ADC_IN
  ADC_RES=0;
  ADC_RESL=0;
  ADC_CONTR =0xE2;//ON_POWER
  delay(2);
void disp(unsigned int dd)
  char i;
  for(i=0;i<8;i++)
w1602d(dd1[i]);
w1602d(dd%10+0x30);
unsigned int ADC10()
    char nn;
 InitADC();
    ADC_CONTR=0xea;
    nn=10;
while(nn--);
ADC_CONTR &=~0x10;
temp=ADC_RES;
temp=temp<<2;
temp |=ADC_RESL;
 return temp;
  unsigned char k;
init1602();
P1M1=0x01;
P1M0=0x00;
CLK_DIV &=~0x20;
temp1=ADC10();
if(temp1<503)  //for water
delay(30);
temp1=ADC10();
if(temp1<503) //yes or no
flag=1;   //  yes! start up water
else          // no!
flag=0;
P30=0;     //close water
    else         //no water
flag=0;
while(flag)  //up water
P30=1;      //start machine
delay(30);
      temp1=ADC10();
w1602c(0x80);
for(nn=0;nn<14;nn++)
w1602d(dd0[nn]);
delay(100);
w1602c(0xc0);
disp(temp1);
if(temp1>550)  //full? No go on!
        P30=0;       //Yes close machine
flag=0;      //end
delay(10);
w1602c(0x80);
for(k=0;k<14;k++)
w1602d(dd0[k]);
 delay(20);
w1602c(0xc0);
disp(temp1);
delay(10);
#include"reg51.h"
U16 temp=450,temp1,temp2;
U8 nn;
bit flag;
sbit rs=P3^7;
sbit en=P5^4;    //Use really  P5.4,test P2.4
sbit D0=ACC^0;
sbit D1=ACC^1;
sbit D2=ACC^2;
sbit D3=ACC^3;
sbit D4=ACC^4;
sbit D5=ACC^5;
sbit D6=ACC^6;
sbit D7=ACC^7;
void delay(U16 ms)
U8 m;
while(ms--)
for(m=0;m<20;m++);
void w1602c(U8 dat)
ACC=dat;
P11=D0;
P12=D1;
P13=D2;
P14=D3;
P15=D4;
P32=D5;
P33=D6;
P36=D7;
rs=0;
en=0;
delay(2);
en=1;
delay(2);
en=0;
void w1602d(U8 dat)
ACC=dat;
P11=D0;
P12=D1;
P13=D2;
P14=D3;
P15=D4;
P32=D5;
P33=D6;
P36=D7;
rs=1;
en=0;
delay(2);
en=1;
delay(2);
en=0;
void init1602()
 w1602c(0x38);
 w1602c(0x06);
 w1602c(0x0c);
 w1602c(0x01);
void InitADC()
  P1ASF =0x01;  //P1.0 ADC_IN - +
  ADC_RES=0;
  ADC_RESL=0;
  ADC_CONTR =0xe0;//ON_POWER
  delay(2);
void disp(U16 dd)
  char i;
  for(i=0;i<8;i++)
w1602d(dd1[i]);
w1602d(dd%10+0x30);
 //bit r;           //test use
 InitADC();
    ADC_CONTR |=0x08;
    delay(2);
ADC_CONTR &=~0x10;
temp=ADC_RES;
temp=temp<<2;
temp |=ADC_RESL;
////*********end Use really********//
//if(r==0)              //
//temp++;             //
//if(temp>551)r=1;    //
//if(r==1)              //
//temp--;             //
//if(temp<500)r=0;    //
////////*****test end ******//
 return temp;
  unsigned char k;
init1602();
P1M1=0x01;
P1M0=0x00;
CLK_DIV &=~0x20;
temp1=ADC10();
delay(30);
temp1=ADC10();
else          // no!
flag=0;
    else         //no water
flag=0;
delay(30);
      temp2=ADC10();
temp1=temp2;
w1602c(0x80);
w1602d(dd0[nn]);
delay(100);
w1602c(0xc0);
disp(temp1);
delay(1000);
flag=0;      //end
delay(10);
w1602c(0x80);
for(k=0;k<14;k++)
w1602d(dd0[k]);
 delay(20);
w1602c(0xc0);
disp(temp1);
delay(1000);
收藏收藏5 分享淘帖 顶顶 踩踩
ID:192284 发表于 2017-4-27 16:32 | 只看该作者
学习了,刚好可以参考一下,谢谢
ID:194417 发表于 2017-4-27 23:35 | 只看该作者
谢谢分享,收藏
谢谢分享,收藏中!
ID:247667 发表于 2017-12-28 12:36 | 只看该作者
会编程序真好,电脑敲打几下就让人羡慕不已!!
ID:344322 发表于 2018-6-5 20:31 | 只看该作者
这个可以直接用吗
ID:53978 发表于 2018-6-12 21:48 | 只看该作者
慢慢学习
