查看: 11916|回复: 5
单片机H桥驱动直流电机正反转原理图 程序 PROTEUS仿真 带使能按钮 光电编码测速
PROTEUS仿真文件及原代码,亲手制作,下面是原理图
51单片机H桥驱动直流电机正反转程序:
  1. #include <reg51.h>
  2. #include <math.h>
  4. #define uint unsigned int
  5. #define ON 0
  6. #define OFF 1
  7. sbit PWM=P3^5;
  8. sbit MP=P3^4;
  9. bit FLAG=0;
  10. uchar code dispbit[6]={0x20,0x10,0x08,0x04,0x02,0x01};
  11. uchar code seg[]={0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90};
  12.                                         //0,1,2,3,4,5,6,7,8,9
  13. uchar disbuf[6]={0,0,0,0,10,10};
  14. uint temp[6];
  15. uint discount=0;
  16. uint timecount=0;//定时的次数
  17. uint T0count=0;
  18. uint hus=0;
  19. uint k=60;
  20. uint Vc;
  21. uint Vs;
  22. uint tm=3000;
  23. uint x;
  24. void t0_serv() interrupt 1
  25. { T0count++;
  26. }
  27. void t1_serv() interrupt 3
  28. {
  29.   PWM=1;
  30.   TH1=(65536-tm)/256;
  31.   TL1=(65536-tm)%256;
  32.   hus++;
  33.   if(hus==tm)
  34.    { PWM=0;
  35.      TH1=(25536+tm)/256;
  36.      TL1=(25536+tm)%256;
  37.
  38.    }
  39.   timecount++;
  40.     if(timecount==250)
  41.     {
  42.            //FLAG=1;
  43.            TR0=0;
  44.            hus=0;
  45.            timecount=0;
  46.            Vc=T0count*65536+TH0*256+TL0;
  47.            Vs=144;
  48.            if(abs(Vc-Vs)>5)
  49.             { tm=abs(k*(Vc-Vs));
  50.                   T0count=0;
  51.                   TR0=1;
  52.                   TR1=1;
  53.                   ET0=1;
  54.                   ET1=1;
  55.                   EA=1;
  56.                 }
  57.           FLAG=1;
  58.           TR0=0;
  59.           timecount=0;
  60.           }
  61.         P0=dispbit[discount];
  62.         P1=seg[disbuf[discount]];
  63.         discount++;
  64.           if(discount==6)
  65.            { discount=0;
  66.            }
  67. }
  68. void main()
  69. {  uint i;
  70.    TMOD=0x15;
  71.    TH0=0;
  72.    TL0=0;
  73.    TH1=(65536-tm)/256;
  74.    TL1=(65536-tm)%256;
  75.    TR0=1;
  76.    TR1=1;
  77.    ET0=1;
  78.    ET1=1;
  79.    EA=1;
  80.    while(1)
  81.   { if(FLAG==1)
  82.    { FLAG=0;
  83.          x=T0count*65536+TH0*256+TL0;
  84.           for(i=0;i<6;i++)
  85.           {temp[i]=0;
  86.           }
  87.         i=0;
  88.         while(x/10)
  89.          {
  90.               temp[i]=x%10;
  91.            x=x/10;
  92.            i++;
  93.           }
  94.         temp[i]=x;
  95.             for(i=0;i<6;i++)
  96.           {
  97.             disbuf[i]=temp[i];
  98.            }
  99.
  100.            timecount=0;
  101.            T0count=0;
  102.            TH0=0;
  103.        TL0=0;
  104.            T0count=0;
  105.            TR0=1;
  106.
  107.      }
  108.    }
  109.
  110. }
仿真文件及原代码.zip
73.85 KB, 下载次数: 122, 下载积分: 黑币 -5
ID:262 发表于 2016-8-15 14:54 | 只看该作者
一、H桥驱动电路
    图4.12中所示为一个典型的直流电机控制电路。电路得名于“H桥驱动电路”是因为它的形状酷似字母H。4个三极管组成H的4条垂直腿,而电机就是H中的横杠(注意:图4.12及随后的两个图都只是示意图,而不是完整的电路图,其中三极管的驱动电路没有画出来)。
如图所示,H桥式电机驱动电路包括4个三极管和一个电机。要使电机运转,必须导通对角线上的一对三极管。根据不同三极管对的导通情况,电流可能会从左至右或从右至左流过电机,从而控制电机的转向。
图4.12 H桥驱动电路
    要使电机运转,必须使对角线上的一对三极管导通。例如,如图4.13所示,当Q1管和Q4管导通时,电流就从电源正极经Q1从左至右穿过电机,然后再经Q4回到电源负极。按图中电流箭头所示,该流向的电流将驱动电机顺时针转动。当三极管Q1和Q4导通时,电流将从左至右流过电机,从而驱动电机按特定方向转动(电机周围的箭头指示为顺时针方向)。
图4.13 H桥电路驱动电机顺时针转动
图4.14所示为另一对三极管Q2和Q3导通的情况,电流将从右至左流过电机。当三极管Q2和Q3导通时,电流将从右至左流过电机,从而驱动电机沿另一方向转动(电机周围的箭头表示为逆时针方向)。
图4.14 H桥驱动电机逆时针转动
二、使能控制和方向逻辑
    驱动电机时,保证H桥上两个同侧的三极管不会同时导通非常重要。如果三极管Q1和Q2同时导通,那么电流就会从正极穿过两个三极管直接回到负极。此时,电路中除了三极管外没有其他任何负载,因此电路上的电流就可能达到最大值(该电流仅受电源性能限制),甚至烧坏三极管。基于上述原因,在实际驱动电路中通常要用硬件电路方便地控制三极管的开关。
    图4.155 所示就是基于这种考虑的改进电路,它在基本H桥电路的基础上增加了4个与门和2个非门。4个与门同一个“使能”导通信号相接,这样,用这一个信号就能控制整个电路的开关。而2个非门通过提供一种方向输人,可以保证任何时候在H桥的同侧腿上都只有一个三极管能导通。(与本节前面的示意图一样,图4.15所示也不是一个完整的电路图,特别是图中与门和三极管直接连接是不能正常工作的。)
图4.15 具有使能控制和方向逻辑的H桥电路
    采用以上方法,电机的运转就只需要用三个信号控制:两个方向信号和一个使能信号。如果DIR-L信号为0,DIR-R信号为1,并且使能信号是1,那么三极管Q1和Q4导通,电流从左至右流经电机(如图4.16所示);如果DIR-L信号变为1,而DIR-R信号变为0,那么Q2和Q3将导通,电流则反向流过电机。
图4.16 使能信号与方向信号的使用
    实际使用的时候,用分立元件制作H桥是很麻烦的,好在现在市面上有很多封装好的H桥集成电路,接上电源、电机和控制信号就可以使用了,在额定的电压和电流内使用非常方便可靠。比如常用的L293D、L298N、TA7257P、SN754410等。
附两张分立元件的H桥驱动电路:
ID:96326 发表于 2017-4-17 16:32 | 只看该作者
感谢分享!
ID:192048 发表于 2018-12-7 11:05 | 只看该作者
赞,感谢分享!
ID:388477 发表于 2018-12-7 13:00 | 只看该作者
谢谢楼主的分享,学习了。
ID:368071 发表于 2020-3-19 15:42 | 只看该作者
无法作为压缩文件打开
