查看: 6815|回复: 0
processing从串口读数据
ID:140343 发表于 2016-9-24 22:58 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
float px = 0.0;import processing.serial.*;
Serial port;
float val;
void setup(){
size(440,220);
fill(255,20,50);
println(Serial.list());
String arduinoPort = Serial.list()[1];
port = new Serial(this,arduinoPort,9600);
void draw(){
  background(0);
  stroke(255);
  if(port.available()>0){
    val = port.read();
    val= map(val,0,255,0,height);
  rect(40,val-10,360,20);
int sensorPin = A0;
int val = 0;
void setup(){
  Serial.begin(9600);
void loop(){
   val = analogRead(sensorPin);
   val = map(val,0,1023,0,255);
   Serial.write(val);
   //Serial.println();
   //Serial.println(val);
   delay(100);
Serial port;
float val;
int x;
float easing = 0.05;
float easedVal;
void setup(){
size(440,440);
frameRate(30);
smooth();
fill(255,20,50);
background(0);
void draw(){
    val = port.read();
  float targetVal = val;easedVal += (targetVal-easedVal) * easing;
  stroke(0);
  line(x,0,x,height);
  stroke(255);
  line(x+1,0,x+1,height);
  line(x,220,x,val);
  line(x,440,x,easedVal+220);
  x++;
  if(x>width){
    x =0;
int sensorPin = A0;
int val = 0;
void setup(){
  Serial.begin(9600);
void loop(){
   Serial.write(val);
   //Serial.println();
   delay(100);
Serial port;
float val;
float angle;
float radius;
void setup(){
size(440,440);
frameRate(30);
smooth();
strokeWeight(2);
fill(255,20,50);
background(0);
void draw(){
    val = port.read();
    radius = map(val,0,255,0,height*0.45);
    int middleX = width/2;
    int middleY = height/2;
    float x = middleX +cos(angle)*height/2;
    float y = middleY + sin(angle)*height/2;
    stroke(0);
    line(middleX,middleY,x,y);
    x = middleX +cos(angle)*radius;
    y = middleY + sin(angle)*radius;
    stroke(255);
    angle += 0.01;
int sensorPin = A0;
int val = 0;
void setup(){
  Serial.begin(9600);
void loop(){
   Serial.write(val);
   //Serial.println();
   delay(100);
