查看: 1997|回复: 1
数码管遥控解码
ID:146918 发表于 2016-11-8 22:02 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include<reg51.h>
#include <intrins.h>
#define ulong unsigned long
#define                Nop()                {_nop_(); _nop_(); _nop_(); _nop_(); _nop_();}
volatile ulong IRcode=0x00000000;  //32位的键代码
volatile ulong Irdcode=0x00000000;
volatile uint customcode=0x0000;      //16位用户码
volatile uint time_us=0x0000;      //两个下降沿之间的时间
volatile uchar timeH,timeL;  //保存TH1 TL的值
uchar Lcustomcode;      //低8用户码
uchar Hcustomcode;     //高8
uchar datacode;    //8位键数据码
uchar mycode;
uchar Rdatacode;      //8位键数据反码
uchar uc1ms;
uchar uc10ms;
uchar uc3ms;
uchar  ucDispTime;
uchar  ucDispOrder;
uchar  ucDispCon;
uchar ucSpeakerTime;
unsigned char code LedData[16] = { 0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e};
unsigned char code LedCon[2] = {0x8f,0x4f};
unsigned char ucDispData[2];        // 存放显示数据
sbit led1 = P2^7;
sbit led2 = P2^6;
sbit power=P1^4;  //电源开关
sbit BEEP= P3^6;
bit NewIRcode=0;  //指示当处理完了32位码后,就有了新的遥控码
bit DataRight=0;   //为1时读取数据正确
bit bSampleOk;
bit bSampling;
bit b10msInt;
bit  b1msInt;
bit bKeySound;
bit b1msMain;
bit IR_E;           //表示有新的遥控键控下就更新扫描数据
bit b3msint;
void SendDataToDispDevice();
void Ir_process();
void display();
void beeping();
/****** 晶振为12 MHZ*******/
/**定时器1,12 MHZ最大定时为65.53ms***/
void init()
  IP=0x09;   //定时器1,外部中断0优先级高
  TMOD=0x11; //定时器0,工作方式1 ;  定时器1,工作方式1
  TCON=0x01; //外中断0下降沿触发,(包括TR1=0,TR0=0)
  TH0=0xff;  //初始化定时器0,定时0.2ms
  TL0=0x47;
  TH1=0x00;  //初始化定时器1
  TL1=0x00;
  EA=1;    //开全中断
  ET0=1;   //开放T0中断
  ET1=1;      //开放T1中断
  EX0=1;   //开放INT0
  TR1=0;
  TR0=1;
void TimeProg(void)
        b1msMain = b1msInt;
           b1msMain=0;
        b10msInt = 0;
        if(b1msInt == 1)
         b1msMain=1;
           if(++uc10ms == 10)
                        uc10ms = 0;
                        b10msInt = 1;
                        if(bKeySound==1)
                  {        beeping();
                        bKeySound=0;
}//void TimeProg(void)
//-------------------------------------interrupt0-------------------------------------
void IR_ISR() interrupt 0 using 1 //遥控器中断处理函数
  static uchar cn;
  TR1=0;
  timeH=TH1;
  timeL=TL1;
  TH1=0;
  TL1=0;
  TR1=1;                     //开定时器中断1
  time_us=(unsigned int)timeH;
  time_us=time_us<<8;
  time_us=time_us|timeL;
  if(time_us>12200&&time_us<13000) {cn=1;IRcode=0;}  //遇到引导码,就把cn清0,IRcode清0
        //引导码的时间长度为9ms+4.5ms
  if(cn<34)
          if(time_us>950&&time_us<1120)                   //0
             IRcode=IRcode|0x00000000;
             if(cn<33) IRcode=IRcode>>1;
      else if(time_us>1920&&time_us<2120)        //1t > 1950 && t < 2150
             IRcode=IRcode|0x80000000;
  //else if(time_us>10000&&time_us<11000) {Irdcode=IRcode;cn=34; }   //遇到重复码
                                               //cn用于记录接收到的数据位
        cn++;
  if(cn==34)
   { NewIRcode=1;
     TR1=0;
     Irdcode= IRcode;  cn=0;
        }  //读完32位码,则有新码产生
//--------------------------------------timer_ISR------------------------------
void Timer0_ISR() interrupt 1 using 2  //定时器0中断函数
  TR0=0;
  TH0=0xff;  //初始化定时器0,定时0.2ms  晶振为11.0592 MHZ
  TL0=0x47;
  TR0=1;
  if(++uc1ms == 5)
                uc1ms = 0;
        b1msInt=1;
                 if(++uc3ms==8)
                   uc3ms=0;
                   b3msint=1;
                   SendDataToDispDevice();     //n* ms送一次显示
}//void Timer0IntProg() interrupt 1 using 1
void Timer1_ISR() interrupt 3 using 3  //定时器1中断函数
  TR1=0;
  TH1=0x00;  //初始化定时器1
  TL1=0x00;
  TR1=1;
//--------------------SendDataToDispDevice----------
unsigned char n;
    //watchdog();
        if(++ucDispOrder >= 2)  ucDispOrder = 0; // 下一显示巡回
        // 下面为发送控制数据          位控
         if(ucDispOrder==0)
              {led1=0;
           led2=1;
               Nop();
            Nop();
         if(b3msint==1)
       {if(ucDispOrder==1)
               {led2=0;
            led1=1;
                    Nop();
            Nop();
        // 下面为发送显示数据
      n = LedData[ucDispData[ucDispOrder]];
      P0=n;
} //void SendDataToDispDevice()
//------------------------------------main()----------------------------------------------
    init();
  beeping();
     TimeProg();
     Ir_process();
     display();
void Ir_process()
  if(NewIRcode==1)    //如果有新的遥控码就读
    NewIRcode=0; //读完之后清零,表示新码已读
    customcode=(Irdcode>>16);    //取红外码中的按码键
                    //取低8位用户码
      Lcustomcode=customcode>>8;//取低8位按码键
    datacode=(unsigned char)(customcode&0x00ff);  //取高8位按码键
       Rdatacode=Lcustomcode;   //取低8位按码键的反码
      if(~Rdatacode!=datacode)
          {  DataRight=0;
             Irdcode=0;
             datacode=Rdatacode=0;
          } //校验用户码,反码
         { DataRight=1;
           IR_E=1;
           mycode=datacode;}
     if(DataRight==1)  { bKeySound = 1;DataRight=0;  }
void display()
  /*  unsigned char a[2];
        a[0] = mycode & 0x0f;
        mycode = mycode >> 4;
        a[1] = mycode & 0x0f;
        ET0 = 0;
        ucDispData[0] = a[0];
        ucDispData[1] = a[1];
        ET0 = 1;*/
        if(IR_E==1)
        ET0 = 0;
        ucDispData[0] = mycode & 0x0f;
        ucDispData[1] = mycode & 0x0f;
    IR_E=0;
        ET0 = 1;
void delay(unsigned char x)    //x*0.14MS
unsigned char a;
  while(x--)
  for (a = 0; a<13; a++) {;}
void beeping()
  unsigned char i;
  for (i=0;i<100;i++)
     delay(4);
     BEEP=!BEEP;                 //BEEP取反
  BEEP=1;
                    //关闭蜂鸣器
ID:138282 发表于 2016-11-8 22:08 | 只看该作者
帮顶,有电路图吗?
