查看: 2020|回复: 0
51单片机控制舵机 总框
ID:148905 发表于 2016-11-19 20:43 | 显示全部楼层 |阅读模式
大概写了一下控制程序  希望对你们有帮助
  1. tpyedef i8 signed char
  2. tpyedef u8 unsigned char
  3. tpyedef i16 signed short int
  4. tpyedef u16 unsigned short int
  5. tpyedef i32 signed long int
  6. tpyedef u32 unsigned long int
  7. #define ELEVEL_LOW                        0                        //低电平
  8. #define ELEVEL_HIGH                        1                        //高电平
  9. #define TIMER_INIT                        10                        //定时器初始时间  单位US
  10. #define STRENG_MINTIME                500                        //舵机最小角度时间 0.5MS
  11. #define STRENG_MAXTIME                2500                //舵机最大角度时间 2.5MS
  12. #define STRENG_TIMERPRO                20000                //舵机周期 20MS
  13. #define STRENG_MINANGLE                0                        //最小角度
  14. #define STRENG_MAXANGLE                185                        //最大角度
  15. #define IO_STRENG10                                                // PORT引脚
  16. #define IO_STRENG20
  17. #define IO_STRENG30
  18. #define IO_STRENG40
  19. #define IO_STRENG50
  20. #define IO_STRENG60
  21. #define IO_STRENG11
  22. #define IO_STRENG21
  23. #define IO_STRENG31
  24. #define IO_STRENG41
  25. #define IO_STRENG51
  26. #define IO_STRENG61
  27. u16 TimerCount = 0;                                                //计数值
  28. float StrEngAccu = 0;                                        //舵机精度
  29. u16 StrEngZeroAngle = 0;                                //零度对应的时间
  30. void StrEngTimer0_Init(void)                        //定时器初始化
  31. {
  32.
  33.         StrEngAccu = STRENG_MAXANGLE/((STRENG_MAXTIME - STRENG_MINTIME)/TIMER_INIT);
  34.         StrEngZeroAngle = STRENG_TIMEUS/TimerInitValue;
  35.
  36.         TH0 = (65535 - TIMER_INIT)/256;
  37.         TL0 = (65535 - TIMER_INIT);
  38.         EA = 1;
  39.         ET0 = 1;
  40.         TR0 = 1;
  41. }
  42. void STRENG_AngleControl(u8 angle,sbit *io)// 0-185角度控制
  43. {
  44.         float regdat = 0;
  45.         u16 angletime = 0;
  46.
  47.         regdat = (float)angle;
  48.         angletime = (u16)(regdat/StrEngAccu) + (STRENG_MINTIME/TIMER_INIT);
  49.
  50.         if(angletime > TimerCount)
  51.         {
  52.                 *io = ELEVEL_HIGH;
  53.         }
  54.         else
  55.         {
  56.                 *io = ELEVEL_LOW;
  57.         }
  58. }
  59. void timer0(void) interrupt 0
  60. {
  61.         TimerCount ++;
  62.         TH0 = (65535 - TIMER_INIT)/256;;
  63.         TL0 = (65535 - TIMER_INIT);
  64.         if(TimerCount > (STRENG_TIMERPRO/TIMER_INIT))
  65.         {
  66.                 TimerCount = 0;
  67.         }
  68. }
