查看: 2798|回复: 1
pwm直流电机调速
ID:154408 发表于 2016-12-13 13:48 | 显示全部楼层 |阅读模式
最近做了一个pwm直流电机调速
下面是程序
#include<reg52.h>
uchar num;
uint speed,count,gao_num=50,gao_count;
sbit lcdrs=P3^5;
sbit lcden=P3^4;
sbit jia_key=P3^0;
sbit jian_key=P3^1;
sbit kaiguan=P3^2;
sbit dianji=P1^0;
uchar code table[]={"0123456789"};
uchar code digit2[]={"speed:    r/min"};
uchar code digit3[]={"Gao_count:     "};
void delay(uint z)
uint x;
        for(x=z;x>0;x--) ;
        //        for(y=110;y>0;y--);
void write_com(uchar com)
        lcdrs=0;
        P0=com;
        delay(5);
        lcden=1;
        delay(5);
        lcden=0;
void write_date(uchar date)
        lcdrs=1;
        P0=date;
        delay(5);
        lcden=1;
        delay(5);
        lcden=0;
  void display()
                 write_com(0x80+7);
                 write_date(table[speed/100]);
                 write_com(0x80+8);
                 write_date(table[speed%100/10]);
                 write_com(0x80+9);
                 write_date(table[speed%10]);
                 write_com(0x80+0x40+12);
                 write_date(table[gao_num/10]);
                 write_com(0x80+0x40+13);
                 write_date(table[gao_num%10]);
void init()
        lcden=0;
        write_com(0x38);
        write_com(0x0c);
        write_com(0x06);
        write_com(0x00);
        write_com(0x80);
        for(num=0;num<15;num++)
                write_date(digit2[num]);
                delay(5);
           write_com(0x80+0x40);
                write_date(digit3[num]);
                delay(5);
        TMOD=0x51;
        TH0=(65536-10000)/256;
        TL0=(65536-10000)%256; //12HZ  10ms 中断一次
        EA=1;
        ET0=1;
        TR0=1;
        TR1=1;
        TH1=0;
        TL1=0;
void timer0() interrupt 1
        count++;
        gao_count++;//统计高电平的时间
void key()
{   /*启动和关闭电机*/
    if(kaiguan==0)
           dianji=1;
                 dianji=0;
   /**按键加**/
          if(jia_key==0)//加速
            delay(5);
                if(jia_key==0)
                gao_num+=5;        //按键每按下一次,加5已达到让风扇转的更快
                 if(gao_num>99) //当gao_num加到100时,时间正好达到1s
                gao_num=99;
                while(!jia_key);
        /**按键减**/
     if(jian_key==0)//减速
                    delay(5);
                        if(jian_key==0)
                          if(gao_num!=0)
                            gao_num-=5;
                            gao_num=50;
                                while(!jian_key);
void qudong()
{ if(gao_count>99)
     gao_count=0;
  if(gao_count<gao_num)
    dianji=1;//加速
    dianji=0;//减速
        init();
        dianji=0;
                  key();
                  qudong();
                  if(count>99)  //1s
                    {  count=0;
                           speed=(TH1*256+TL1)*60/7;
                           TH1=0;
                   TL1=0;
                   display();
ID:222031 发表于 2017-8-3 08:55 | 显示全部楼层
感谢分享
