ÕÒ»ØÃÜÂë
 Á¢¼´×¢²á
QQ怬
Ö»ÐèÒ»²½£¬¿ìËÙ¿ªÊ¼
ËÑË÷
Â¥Ö÷: a13758777532
´òÓ¡ ÉÏÒ»Ö÷Ìâ ÏÂÒ»Ö÷Ìâ
ÊÕÆð×ó²à
mp3
[¸´ÖÆÁ´½Ó]
Ìø×ªµ½Ö¸¶¨Â¥²ã
Â¥Ö÷
//2008.9.1
//m8
//a13758777532±àд
 //ѧϰÈÕ±¾µÄ¿Æ¼¼£¬Ìá¸ßÖйúˮƽ
#include <avr/io.h>
#include <avr/signal.h>
#include <avr/interrupt.h>
#include <avr/pgmspace.h>//Í·Îļþ£»
#define  LF 10
#define  ON 1
#define  OFF 0
#define  TRUE 1
#define  FALSE 0
#define  NOP  asm volatile("nop\n"::)
#define  WDR  asm volatile("wdr\n"::)
#define  SLEEP asm volatile("sleep\n"::)
typedef unsigned char uchar;
typedef unsigned int uint;
typedef unsigned long ulong;
//#define  VS1001_CLOCK 14318180
#define  VS1001_CLOCK 12000000
#define  SPI_CS  2
#define  SPI_DIN  3
#define  SPI_CLK  5
#define  SPI_DOUT 4
//#define  MP3_SO  1
#define  MP3_SI  7
#define  MP3_SCLK 6
#define  MP3_CS  5
#define  MP3_BSYNC 4
#define  MP3_DCLK 3
#define  MP3_DREQ 2
#define  SW_START 0
#define  SW_STOP  0
#define  SW_REW  1
#define  SW_FF  2
#define  SW_VOLDOWN 3
#define  SW_VOLUP 4
#define  SW_PORT_START 3 // PINC
#define  SW_PORT_STOP 3 // == SW_PORT_START
#define  SW_PORT_REW  2 // PINC
#define  SW_PORT_FF  1 // PINC
#define  SW_PORT_VOLDOWN 0 // PINC
#define  SW_PORT_VOLUP 0 // PINB
#define  POWER  4 //
#define  VOLTAGE  5 //
#define  MUTE  1 //
#define  LED   1 // PORTD == TxD POWER LED
#define  BEEP_HIGH 0
#define  BEEP_LOW 1
// EEPROM ¥¢¥É¥ì¥¹
#define  EEPROM_MUSIC  1 // ºÆÀ¸Ãæ¤Î¶ÊÈÖ¹æ
#define  EEPROM_CLUSTER_L 2 // ºÆÀ¸Ãæ¤Î¥¯¥é¥¹¥¿(LOW)
#define  EEPROM_CLUSTER_H 3 //      ¡·         (HIGH)
#define  EEPROM_REMAIN1  4 // ºÆÀ¸Ãæ¤Î¶Ê¤Î»Ä¤ê¥»¥¯¥¿¿ô
#define  EEPROM_REMAIN2  5
#define  EEPROM_REMAIN3  6
#define  EEPROM_SIZE1  8 // ºÆÀ¸Ãæ¤Î¶Ê¥Ç¡¼¥¿¤ÎŤµ
#define  EEPROM_SIZE2  9 // SD¥«¡¼¥É¤¬¸ò´¹¤µ¤ì¤¿¤«¤É¤¦¤«
#define  EEPROM_SIZE3  10 // ȽÊ̤¹¤ë¤Î¤Ë»È¤¦
#define  EEPROM_SIZE4  11
#define  EEPROM_VOLUME  12 // ¥Ü¥ê¥å¡¼¥à
#define  EEPROM_RUNNING_TIME_H 13 // ¸½ºß¤ÎÅÅÃÓ¤Î²ÔÆ¯»þ´Ö(»þ)
#define  EEPROM_RUNNING_TIME_M 14 // ¡¡¡¡¡¡¡¡¡¡¡·        (ʬ)
#define  EEPROM_RUNNING_TIME_OLD_H 15 // Á°¤ÎÅÅÃÓ¤Î²ÔÆ¯»þ´Ö(»þ)
#define  EEPROM_RUNNING_TIME_OLD_M 16 //        ¡·         (ʬ)
#define  EEPROM_BATTLOG 17 // Å۵¥í¥°³«»Ï
// ¥Ð¥Ã¥Æ¥ê¡¼Å۵  V * 200 - 12 (¼Â¬¤Ë¤è¤ë)
#define  BATT_START  410  // µ¯Æ°Å۵ Ìó2.1V
#define  BATT_SHUTDOWN 380  // ¥·¥ã¥Ã¥È¥À¥¦¥óÅ۵ Ìó2.0V
#define  BATT_LOW  428  // ¥í¡¼¥Ð¥Ã¥Æ¥ê¡¼¸¡½Ð Ìó2.2V
#define  BATT_26   508  // 2.6V
#define  BATT_25   488  // 2.5V
#define  BATT_24   468  // 2.4V
#define  BATT_23   448  // 2.3V
#define  BATT_22   428  // 2.2V
uchar InitCard(void);
uchar SPI_read_open(ulong adrs);
void SPI_read_close(void);
uchar SPI_command(uchar com, ulong arg);
uchar SPI_in(void);
void SPI_out(uchar data);
void SPI_dummy_clock(void);
void SPI_wait(void);
void InitWait(void);
void read_32(ulong addr);
uchar read_VFAT_info(void);
uint search_MP3(uint num);
char play_music(uint n, uint clst, long remainbyte);
uint next_cluster(uint c, ulong sec, uint remain);
uint read_word(ulong addr);
void beep(uchar n, char err);
void MP3_sin(PGM_VOID_P data);
void MP3_init(void);
void MP3_command(uchar addr, uint arg);
void MP3_com_write(uchar data);
uint MP3_command_read(uchar addr);
void shutdown(char flag);
int  check_batt(void);
void write_eeprom(uchar adrs, uchar data);
uchar read_eeprom(uchar adrs);
void switch_wait(void);
uchar ReadCom(void);
void WriteCom(uchar data);
void WriteComMsg(PGM_VOID_P msg);
void WriteComStr(uchar *msg);
void WriteHex(uchar data);
void print_sector(ulong sec);
// ¥Æ¥¹¥ÈÍÑϢ³Àµ¸¹ÇȽÐÎϥǡ¼¥¿  Beep¤È¤·¤Æ»È¤¦
PROGMEM uchar BeepData[] = { 0x53, 0xEF, 0x6E, 0x31, 0, 0, 0, 0 }; // 1500Hz
PROGMEM uchar ErrorBeep[] = { 0x53, 0xEF, 0x6E, 0x35, 0, 0, 0, 0 }; // 500Hz
PROGMEM uchar BeepStop[] = { 0x45, 0x78, 0x69, 0x74, 0, 0, 0, 0 }; // »ß¤á¤ë
uint Cluster;  // ¸½ºßºÆÀ¸Ãæ¤Î¥¯¥é¥¹¥¿
uint NextCluster; // ¼¡²óºÆÀ¸¤¹¤ë¥¯¥é¥¹¥¿
uint PlayMusic;  // ºÆÀ¸Ãæ¤Î¶ÊÈÖ¹æ
uint MusicCount;  // ¸½ºß¤Î¥«¡¼¥É¤ËÆþ¤Ã¤Æ¤¤¤ë¶Ê¿ô
ulong MusicSize;  // ºÆÀ¸Ãæ¤Î¶Ê¤Î¥µ¥¤¥º
long RemainSec;  // ºÆÀ¸Ãæ¤Î¶Ê¤Î»Ä¤ê¥»¥¯¥¿¿ô
char NoBusyRetry; // BUSY¤Ë¤Ê¤é¤Ê¤¤¤Î¤Ç¥ê¥È¥é¥¤¤·¤¿¤³¤È¤ò¼¨¤¹¥Õ¥é¥°
uchar FATtype;  // 0:FAT12  1:FAT16
uchar SectorsPerCluster;  // 1¥¯¥é¥¹¥¿¤Î¥»¥¯¥¿¿ô
uint RootDirEntriesCount; // ¥ë¡¼¥È¥Ç¥£¥ì¥¯¥È¥ê¥¨¥ó¥È¥ê¡¼¿ô
uint FATstart;  // FAT³«»Ï¥»¥¯¥¿
uint DIRstart;  // ¥ë¡¼¥È¥Ç¥£¥ì¥¯¥È¥ê³«»Ï¥»¥¯¥¿
ulong DataStart;  // ¥Ç¡¼¥¿Îΰ賫»Ï¥»¥¯¥¿
volatile uchar Volume;   // ²»ÎÌ
volatile int BattVolt;  // ¥¿¥¤¥Þ¡¼³ä¤ê¹þ¤ß¤Ç¼èÆÀ¤·¤¿ÅŸ»Å۵
volatile uchar SwitchFlag;  // ¥¿¥¤¥Þ¡¼³ä¤ê¹þ¤ß¤Ç¼èÆÀ¤·¤¿¥¹¥¤¥Ã¥Á¤Î¾ðÊó
volatile uchar StopSw;  // START/STOP¥¹¥¤¥Ã¥ÁÆþÎϥե饰
volatile uchar RewSw;  // REW¥¹¥¤¥Ã¥ÁÆþÎϥե饰
volatile uchar FfSw;  // FF¥¹¥¤¥Ã¥ÁÆþÎϥե饰
volatile uchar VolUpSw; // Vol up¥¹¥¤¥Ã¥ÁÆþÎϥե饰
volatile uchar VolDownSw; // Vol down¥¹¥¤¥Ã¥ÁÆþÎϥե饰
volatile uchar FlushTimer; // LEDÅÀÌÇ¥¿¥¤¥Þ
volatile uchar RunningTimeDS; // ²ÔƯ»þ´Ö(1/100ÉÃ)
volatile uchar RunningTimeS; //     ¡·  (ÉÃ)
volatile uchar RunningTimeM; //     ¡·  (ʬ)
volatile uchar RunningTimeH; //     ¡·  (»þ)
volatile uchar Timer;  // ÈÆÍÑ¥¿¥¤¥Þ
uchar DataBuff[32]; // ¥Ç¡¼¥¿¥Ð¥Ã¥Õ¥¡
uchar FatCache[512]; // FAT¥­¥ã¥Ã¥·¥å
ulong FatCacheAddr; // ¥­¥ã¥Ã¥·¥å¤·¤Æ¤¤¤ë¥¢¥É¥ì¥¹
char Debug;   // ¥Ç¥Ð¥Ã¥°¥Õ¥é¥°
// ¥¿¥¤¥Þ¡¼£°¥ª¡¼¥Ð¡¼¥Õ¥í¡¼³ä¤ê¹þ¤ß
// 8MHz/1024/78=100.16 Ìó100Hz
SIGNAL(SIG_OVERFLOW0) {
 uchar old_sw;
 // ¼¡¤Î³ä¤ê¹þ¤ßÀßÄê
 outp((uchar)(256-(78-1)), TCNT0);
 // ÈÆÍÑ¥¿¥¤¥Þ
 if (Timer){
  --Timer;
 // ¥í¡¼¥Ð¥Ã¥Æ¥ê¡¼¸¡½Ð¤Ë¤è¤ëÅÀÌÇ
 if (!Debug){
  if (++FlushTimer >= 100){
   if (BattVolt < BATT_LOW){
    cbi(PORTD, LED); // LED OFF
   FlushTimer = 0;
  } else if (FlushTimer == 50){
   sbi(PORTD, LED); // LED ON
 // ²ÔƯ»þ´Öµ­Ï¿
 if (++RunningTimeDS >= 100){
  RunningTimeDS = 0;
  if (++RunningTimeS >= 60){
   RunningTimeS = 0;
   if (++RunningTimeM >= 60){
    RunningTimeM = 0;
    ++RunningTimeH;
 // ¥¹¥¤¥Ã¥Á¥Á¥§¥Ã¥¯
 old_sw = SwitchFlag;
 SwitchFlag = 0;
 if (!(inp(PINC) & (1<<SW_PORT_STOP))){
  if (old_sw & (1<<SW_STOP)){
   if (++StopSw == 0) StopSw = 255;
  } else {
   StopSw = 1;
  SwitchFlag = (1<<SW_STOP);
 if (!(inp(PINC) & (1<<SW_PORT_REW))){
  if (old_sw & (1<<SW_REW)){
   if (++RewSw == 0) RewSw = 255;
  } else {
   RewSw = 1;
  SwitchFlag |= (1<<SW_REW);
 if (!(inp(PINC) & (1<<SW_PORT_FF))){
  if (old_sw & (1<<SW_FF)){
   if (++FfSw == 0) FfSw = 255;
  } else {
   FfSw = 1;
  SwitchFlag |= (1<<SW_FF);
 if (!(inp(PINC) & (1<<SW_PORT_VOLDOWN))){
  if (++VolDownSw == 0) VolDownSw = 255;
  if (VolDownSw >= 20){
   Volume += 8;
   if (Volume > 0xCF) Volume = 0xCF;
   MP3_command(11, ((uint)Volume << 8)|((uint)Volume)); // ²»ÎÌÀßÄê
   VolDownSw = 1;
  SwitchFlag |= (1<<SW_VOLDOWN);
 } else {
  VolDownSw = 0;
 if (!(inp(PINB) & (1<<SW_PORT_VOLUP))){
  if (++VolUpSw == 0) VolUpSw = 255;
  if (VolUpSw >= 20){
   Volume -= 8;
   if (Volume == 0xFF) Volume = 0x07;
   VolUpSw = 1;
  SwitchFlag |= (1<<SW_VOLUP);
 } else {
  VolUpSw = 0;
 // A/DÊÑ´¹³«»Ï ¥×¥ê¥¹¥±¡¼¥é 8MHz/64 = 125kHz
 outp((1<<ADEN)|(1<<ADSC)|(1<<ADIE)|6, ADCSRA);
// A/DÊÑ´¹¤Î³ä¤ê¹þ¤ß¥ë¡¼¥Á¥ó
SIGNAL(SIG_ADC) {
 int  volt;
 // A/DÊÑ´¹·ë²Ì³ÊǼ
 // ADCL ¢ª ADCH ¤Î½ç¤Ë¥¢¥¯¥»¥¹¤¹¤ëɬÍפ¢¤ê
 volt = (int)inp(ADCL);
 BattVolt = (((int)inp(ADCH) & 3) << 8);
 BattVolt |= volt;
 cbi(ADCSRA, ADEN); // A/D ÅŸ»OFF
// INT0(EasyMP3 DREQ)³ä¤ê¹þ¤ß¥ë¡¼¥Á¥ó
SIGNAL(SIG_INTERRUPT0) {
 // CPU¤òµ¯¤³¤¹¤À¤±
// ¥á¥¤¥ó¥ë¡¼¥Á¥ó
int main (void) {
 char r;
 outp((1<<SW_PORT_VOLUP)|(1<<SPI_CS)|(1<<SPI_DIN), PORTB); // PB0 pull up
 outp((1<<SPI_CS)|(1<<SPI_DIN)|(1<<SPI_CLK)|(1<<MUTE), DDRB);
 outp((1<<SW_PORT_STOP)|(1<<SW_PORT_REW)|(1<<SW_PORT_FF)
   |(1<<SW_PORT_VOLDOWN), PORTC); // PC3¡Á0 pull up
 outp((1<<POWER), DDRC);  // PC4 out
 outp(1, PORTD);    // RxD pull up
 outp((1<<MP3_SI)|(1<<MP3_SCLK)|(1<<MP3_CS)|(1<<MP3_BSYNC)|(1<<MP3_DCLK),
   DDRD);
 if (inp(MCUCSR) & (1<<WDRF)){
  // ¥¦¥©¥Ã¥Á¥É¥Ã¥°¥ê¥»¥Ã¥È
  shutdown(1); // ¥·¥ã¥Ã¥È¥À¥¦¥ó
 outp(0, MCUCSR);
 if (inp(PINC)&(1<<SW_PORT_START)){
  Debug = 1;
  outp(0, UBRRH);   // DEBUGÍÑ USART½é´ü²½
  outp(24, UBRRL);  // 19200bps/8MHz
  outp(0x20, UCSRA);
  outp(0x18, UCSRB);  // Á÷¼õ¿®µö²Ä
 } else {
  Debug = 0;   // START¥¹¥¤¥Ã¥Á¤Çµ¯Æ°¤·¤¿
  sbi(DDRD, LED);  // LED½ÐÎÏ
 WDR;
 outp(0x18, WDTCR); // WDCE¤ÈWDE¤ò1¤Ë¤·¤Æ¥¿¥¤¥Þ¡¼Êѹ¹¤ò¤¹¤ë
 outp(0x1F, WDTCR); // ¥¦¥©¥Ã¥Á¥É¥Ã¥°¥¿¥¤¥Þ¡¼¥»¥Ã¥È Ìó£²ÉÃ/3V
 outp(((1<<REFS1)|(1<<REFS0))|5, ADMUX);  // ÆâÉô´ð½àÅ۵ 2.56V, A/D ch5
 outp((uchar)(256-(78-1)), TCNT0); // ¥¿¥¤¥Þ¡¼ÀßÄêÃÍ -78
 outp(0x05, TCCR0);  // ¥¿¥¤¥Þ¡¼¥×¥ê¥¹¥±¡¼¥é 1/1024
 sbi(TIMSK, TOIE0);  // ¥¿¥¤¥Þ³ä¤ê¹þ¤ßµö²Ä
 outp(0x83, MCUCR);  // INT0(EasyMP3 DREQ)Ω¤Á¾å¤¬¤ê³ä¤ê¹þ¤ß,¥¹¥ê¡¼¥×µö²Ä sbi(GICR, INT0);  // µö²Ä
 SwitchFlag = 0;
 BattVolt = 0;
 NoBusyRetry = 0;
 sei();  // ³ä¤ê¹þ¤ßµö²Ä
 while(BattVolt < BATT_START){
  SLEEP; // Å۵¤¬µ¬ÄêÃͤË㤹¤ë¤Þ¤ÇÂÔ¤Ä
 sbi(PORTC, POWER);  // ÅŸ»¥í¥Ã¥¯ & EasyMP3 ¥ê¥»¥Ã¥È²ò½ü
 // EasyMP3¤Î¥Ý¥Ã¥×¥Î¥¤¥º¤ò¤ä¤ê²á¤´¤¹°Ù¤Î¥¿¥¤¥Þ¡¼¥»¥Ã¥È
 Timer = 40; // Ìó400mS
 Volume = read_eeprom(EEPROM_VOLUME);
 if (Volume == 0xFF) Volume = 0x47;
 // EEPROM¤«¤éÁ°²óºÆÀ¸¤·¤Æ¤¤¤¿¶Ê¾ðÊó¤ò¼èÆÀ
 PlayMusic = read_eeprom(EEPROM_MUSIC);
 Cluster = (uint)read_eeprom(EEPROM_CLUSTER_H)<<8;
 Cluster |= (uint)read_eeprom(EEPROM_CLUSTER_L);
 RemainSec = (long)read_eeprom(EEPROM_REMAIN3)<<16;
 RemainSec |= (long)read_eeprom(EEPROM_REMAIN2)<<8;
 RemainSec |= (long)read_eeprom(EEPROM_REMAIN1);
 MusicSize = (ulong)read_eeprom(EEPROM_SIZE4)<<24;
 MusicSize |= (ulong)read_eeprom(EEPROM_SIZE3)<<16;
 MusicSize |= (ulong)read_eeprom(EEPROM_SIZE2)<<8;
 MusicSize |= (ulong)read_eeprom(EEPROM_SIZE1);
 // ²ÔƯ»þ´Öµ­Ï¿³«»Ï
 RunningTimeDS = 0;
 RunningTimeS = 0;
 RunningTimeM = read_eeprom(EEPROM_RUNNING_TIME_M);
 RunningTimeH = read_eeprom(EEPROM_RUNNING_TIME_H);
 if (RunningTimeM == 0xFF){
  RunningTimeM = 0;
  RunningTimeH = 0;
 if (Debug){
  // Debug»þ¤Ë²ÔƯ»þ´Ö¤òɽ¼¨
  WriteComMsg(PSTR(" \nRunning Time:\n"));
  WriteHex(RunningTimeH);
  WriteComMsg(PSTR("h(Hour) "));
  WriteHex(RunningTimeM);
  WriteComMsg(PSTR("h(Min)\n"));
  WriteHex(read_eeprom(EEPROM_RUNNING_TIME_OLD_H));
  WriteHex(read_eeprom(EEPROM_RUNNING_TIME_OLD_M));
 // REW¤ò²¡¤·¤Ê¤¬¤éµ¯Æ°¤·¤¿¤é¶¯À©Åª¤Ë¤½¤Î¶Ê¤ÎºÇ½é¤«¤éºÆÀ¸¤¹¤ë
 if (SwitchFlag & (1<<SW_REW)){
  Cluster = 0;
 // MMC/SD SPI½é´ü²½
 if (InitCard() == 0xFF){
  // MMC/SD¥«¡¼¥É¤¬Ìµ¤¤
  while(Timer) SLEEP; // EasyMP3¤Î¥Ý¥Ã¥×¥Î¥¤¥º¤Î»þ´ÖÂÔ¤Á
  sbi(PORTB, MUTE); // ²»À¼¥ß¥å¡¼¥È²ò½ü
  beep(3, BEEP_LOW);
 WDR;
 beep(1, BEEP_HIGH);  // BEEP²»
 // VFAT¾ðÊóÆÉ¤ß¼è¤ê
 if (read_VFAT_info()){
  beep(2, BEEP_LOW); // VFAT¾ðÊó¤Î°Û¾ï
  shutdown(1);
 // ¥«¡¼¥ÉÆâ¤Î¶Ê¿ô³Îǧ
 MusicCount = search_MP3(0xFFFF);
 if (MusicCount == 0){
  // MP3¥Õ¥¡¥¤¥ë¤¬Ìµ¤¤
  beep(1, BEEP_LOW);
 if (PlayMusic == 0) PlayMusic = 1;
 // MMC/SD¥«¡¼¥É¤¬¸ò´¹¤µ¤ì¤¿¤«¤É¤¦¤«Ä´¤Ù¤ë
 search_MP3(PlayMusic);
 if (MusicSize !=
  ((ulong)DataBuff[28] + ((ulong)DataBuff[29] << 8)
   + ((ulong)DataBuff[30] << 16) + ((ulong)DataBuff[31] << 24))){
  // ±éÁÕ¤¹¤ë¶Ê¤Î¥µ¥¤¥º¤¬°Û¤Ê¤Ã¤Æ¤¤¤ì¤Ð¸ò´¹¤µ¤ì¤¿¤È¤ß¤Ê¤¹
  PlayMusic = 1;
  Cluster = 0;
 for(;;){
  if (PlayMusic > MusicCount) PlayMusic = 1;
  switch_wait();  // ¥¹¥¤¥Ã¥Á¤¬Êü¤µ¤ì¤ë¤Þ¤ÇÂÔ¤Ä
  // ºÆÀ¸
  r = play_music(PlayMusic, Cluster, RemainSec);
  if (r < 0){
   beep(-r, BEEP_LOW);  // ¥¨¥é¡¼È¯À¸
   shutdown(0);
  } else if (r == 1){  // ÅÓÃæ¤ÇSTOP¤¬²¡¤µ¤ì¤¿
   if (StopSw > 100){ // 1Éðʾå¤ÎĹ²¡¤·¤Ï¥Ð¥Ã¥Æ¥ê¡¼Å۵¥Á¥§¥Ã¥¯
    if (BattVolt > BATT_26){
     beep(3, BEEP_HIGH);   // 2.6V°Ê¾å ¹â²»£³²ó
    } else if (BattVolt > BATT_25){
     beep(2, BEEP_HIGH);   // 2.5V°Ê¾å ¹â²»£²²ó
    } else if (BattVolt > BATT_24){
     beep(1, BEEP_HIGH);   // 2.4V°Ê¾å ¹â²»£±²ó
    } else if (BattVolt > BATT_23){
     beep(1, BEEP_LOW);   // 2.3V°Ê¾å Äã²»£±²ó
    } else if (BattVolt > BATT_22){
     beep(2, BEEP_LOW);   // 2.2V°Ê¾å Äã²»£²²ó
    } else {
     beep(3, BEEP_LOW);   // ¤½¤ì°Ê²¼ Äã²»£³²ó
    continue; // ³¤­¤«¤é±éÁÕ
   } else {
    shutdown(0); // ÅŸ»¤òÀÚ¤ë
  } else if (r == 3){  // REW
   if (RewSw > 100){ // 1Éðʾå¤ÎĹ²¡¤·¤ÏºÇ½é¤Î¶Ê
    PlayMusic = 1;
   } else if (RewSw > 25){ // 250ms°Ê¾å¤ÎĹ²¡¤·¤ÏÁ°¤Î¶Ê
    if (--PlayMusic == 0){
     PlayMusic = MusicCount;
   Cluster = 0; // ¶Ê¤ÎºÇ½é¤«¤é
  } else { // FF or ¤½¤Î¶Ê¤ÎºÆÀ¸½ªÎ»
   PlayMusic++; // ¼¡¤Î¶Ê
   Cluster = 0;
  if (BattVolt < BATT_START){
   beep(1, BEEP_LOW); // µ¯Æ°Å۵°Ê²¼¤Ë¤Ê¤Ã¤¿¤é¶Ê´Ö¤Ë·Ù¹ð²»
// ¥¹¥¤¥Ã¥Á¤¬³Î¼Â¤ËÊü¤µ¤ì¤ë¤Þ¤ÇÂÔ¤Ä
void switch_wait(void){
 sei();
 for (;;) {
  WDR;
  SLEEP;
  SLEEP;
  if (!(SwitchFlag & ((1<<SW_FF)|(1<<SW_REW)|(1<<SW_STOP)))){
   SLEEP;
   SLEEP;
    break;
// MMC/SD¥«¡¼¥É¤Î½é´ü²½
uchar InitCard(void){
 uchar c;
 outp(0x52, SPCR); // SPI¥Þ¥¹¥¿, CPOL=0, ¥¯¥í¥Ã¥¯ 8MHz/64=125kHz
 sbi(PORTB, SPI_CS); // CS=H
 // MMC/SD SPI¥â¡¼¥É°Ü¹ÔÁ°¤Î¥¯¥í¥Ã¥¯Á÷¿®
 for (c=0; c < 10; c++){
  SPI_in();
 // SPI¥â¡¼¥É°Ü¹Ô¥³¥Þ¥ó¥É
 cbi(PORTB, SPI_CS);  // CS=L
 c = SPI_command(0, 0);
 while ((c != 1)&&(c != 0xFF)){
  SLEEP;
 while (c == 1){
  c = SPI_command(1, 0);
 outp(0x50, SPCR); // SPI¥Þ¥¹¥¿, CPOL=0, ¥¯¥í¥Ã¥¯ 8MHz/4=2MHz
 sbi(SPSR, SPI2X); // ¥¯¥í¥Ã¥¯¤ò£²ÇÜ 4MHz
 return c;
// VFAT¾ðÊóÆÉ¤ß¼è¤ê
uchar read_VFAT_info(void){
 ulong sec;
 uint bpb;
 uint n;
 // VFAT¾ðÊóÆÉ¤ß¼è¤ê¡£¥»¥¯¥¿Ä¹¤Ï 512bytes¤Ç·è¤áÂǤÁ¤·¤Æ¤¤¤ë
 read_32(446);          // MBRÆÉ¤ß¹þ¤ß
 bpb = (uint)DataBuff[8] + ((uint)DataBuff[9]<<8); // BPBÀèÆ¬¥»¥¯¥¿
 read_32((ulong)bpb * 512);       // ÆÉ¤ß¹þ¤ß
 n = (uint)DataBuff[11] + ((uint)DataBuff[12] << 8); // ¥»¥¯¥¿Ä¹
 if (n != 512){
  return 2; // 1¥»¥¯¥¿¤¬ 512bytes¤Ç¤Ê¤¤
 SectorsPerCluster = DataBuff[13];  // ¥¯¥é¥¹¥¿¤¢¤¿¤ê¤Î¥»¥¯¥¿¿ô
 FATstart = bpb + (uint)DataBuff[14]
  + ((uint)DataBuff[15] << 8);  // ͽÌ󥻥¯¥¿¿ô
 RootDirEntriesCount = (uint)DataBuff[17]
  + ((uint)DataBuff[18] << 8);  // ¥ë¡¼¥È¥Ç¥£¥ì¥¯¥È¥ê¥¨¥ó¥È¥ê¿ô
 n = (uint)DataBuff[22] + ((uint)DataBuff[23] << 8); // FAT¤Î¥»¥¯¥¿¿ô
 if (n == 0){
  return 1; // FAT32¤é¤·¤¤
 DIRstart = (uint)FATstart + (uint)DataBuff[16] * n; // FAT¤Î¿ô¡ß¥»¥¯¥¿¿ô
 n = RootDirEntriesCount / 16; // ¥ë¡¼¥È¥Ç¥£¥ì¥¯¥È¥ê¤ËɬÍפʥ»¥¯¥¿¿ô
 if (RootDirEntriesCount % 16){
  n++; // ǰ¤Î¤¿¤á¡¢Í¾¤ê¤¬½Ð¤¿¤éÀÚ¤ê¾å¤²¡£Ä̾ï¤ÏÉÔÍפÀ¤È»×¤¦¤¬
 DataStart = (ulong)DIRstart + (ulong)n;  // ¥Ç¡¼¥¿³ÊǼÎΰè
 sec = (ulong)DataBuff[19] + ((ulong)DataBuff[20] << 8); // Áí¥»¥¯¥¿¿ô
 if (sec == 0){
  read_32((ulong)bpb * 512 + 32);  // ÆÉ¤ß¹þ¤ß
  sec = (ulong)DataBuff[0] + ((ulong)DataBuff[1] << 8)
   + ((ulong)DataBuff[2] << 16) + ((ulong)DataBuff[3] << 24);
 sec -= FATstart;
 sec /= SectorsPerCluster;
 if (sec >= 0x1000){
  FATtype = 1; // FAT16
 } else {
  FATtype = 0; // FAT12
 return 0;
·ÖÏíµ½:  QQºÃÓѺÍȺQQºÃÓѺÍȺ QQ¿Õ¼äQQ¿Õ¼ä ÌÚѶ΢²©ÌÚѶ΢²© ÌÚѶÅóÓÑÌÚѶÅóÓÑ
ÊÕ²ØÊÕ²Ø ·ÖÏíÌÔÌû ¶¥¶¥ ²È²È
»Ø¸´
ʹÓõÀ¾ß ¾Ù±¨
ɳ·¢
ID:31840 ·¢±íÓÚ 2011-9-28 12:56 | Ö»¿´¸Ã×÷Õß
ûÓÐÓ²¼þÔ­ÀíÍ¼ÄØ£¿
»Ø¸´
ʹÓõÀ¾ß ¾Ù±¨
ÄúÐèÒªµÇ¼ºó²Å¿ÉÒÔ»ØÌû µÇ¼ | Á¢¼´×¢²á
±¾°æ»ý·Ö¹æÔò
СºÚÎÝ|51ºÚµç×ÓÂÛ̳ |51ºÚµç×ÓÂÛ̳6Ⱥ QQ ¹ÜÀíÔ±QQ:125739409;¼¼Êõ½»Á÷QQȺ281945664
Powered by µ¥Æ¬»ú½Ì³ÌÍø
¿ìËٻظ´ ·µ»Ø¶¥²¿ ·µ»ØÁбí
