查看: 2174|回复: 0
LED灯流水显示c语言程序
ID:156878 发表于 2016-12-22 16:31 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include"reg52.h"
typedef unsigned char uchar;
typedef unsigned int uint;
#define led P2
sbit key=P3^0;
void delay (uint i)
uint k;
for(k=0;k<i;k++);
uchar i,w;
led=0xff;
w=0x01;
  if(key==0)
   delay(1200);
   if(key==0)
    while(!key);
    for(i=0;i<8;i++)
     led=~w;
     delay(10000);
     w<<=1;
    w=0x01;
   led=0xff;
