查看: 2501|回复: 1
谁有有关竞赛自动往返电动小汽车的质料
ID:152839 发表于 2017-1-6 20:39 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
谁有有关竞赛自动往返电动小汽车的质料  分享一下 谢谢
ID:155507 发表于 2017-1-7 15:13 | 只看该作者
  1. #include "STC15W201S.h"
  2. #include "intrins.h"
  3. typedef unsigned char BYTE;
  4. typedef unsigned int WORD;
  5. sbit D1 = P1^4;  //用于控制左边发光二极管
  6. sbit D2 = P3^7;   //用于控制右边发光二极管
  7. bit busy;
  8. bit l9110s_1 ;
  9. bit l9110s_2 ;
  10. bit R9110s_1 ;
  11. bit R9110s_2 ;
  12. unsigned char func;
  13. void Delay500ms()                //@11.0592MHz
  14. {
  15.   unsigned char i, j, k;
  16.   _nop_();
  17.   _nop_();
  18.   i = 2;
  19.   j = 2;
  20.   k = 2;
  21.   do
  22.   {
  23.     do
  24.     {
  25.       while (--k);
  26.     } while (--j);
  27.   } while (--i);
  28. }
  29. BYTE usart_recv;
  30. /*----------------------------
  31. UART 中断处理函数
  32. -----------------------------*/
  33. void Uart() interrupt 4 using 1
  34. {
  35.   if (RI)
  36.   {
  37.     RI = 0;                 //??RI?
  38.     usart_recv = SBUF;
  39.   }
  40.   if (TI)
  41.   {
  42.     TI = 0;                 //??TI?
  43.     busy = 0;               //????
  44.   }
  45. }
  46. //串口初始化为9600波特率
  47. void Usart_init(void)
  48. {
  49.   SCON = 0x50;
  50.   T2L = 0xE0;
  51.   T2H = 0xFE;
  52.   AUXR |= 0x01;
  53.   AUXR |= 0x4;
  54.   AUXR |= 0x10;
  55.   ES = 1;
  56.   EA = 1;
  57. }
  58. //电机PWM方式驱动
  59. void PWM_Init(void)                //100??@11.0592MHz
  60. {
  61.   AUXR |= 0x80;
  62.   TMOD = 0x02;
  63.   TL0 = 0x00;
  64.   TH0 = 0x00;
  65.   TF0 = 0;
  66.   TR0 = 1;
  67.   ET0 = 1;
  68.   EA  = 1;
  69. }
  70. unsigned char R_PWM,L_PWM;
  71. unsigned char count;
  72. void timer0_int (void) interrupt 1
  73. {
  74.   count++;
  75.   if(count > 100)
  76.   {
  77.     P32 = l9110s_1;
  78.     P33 = l9110s_2;
  79.     P54 = R9110s_1;
  80.     P55 = R9110s_2;
  81.     count = 0;
  82.   }
  83.
  84.   if(count == L_PWM)
  85.   {
  86.     P54 = 0;
  87.     P55 = 0;
  88.   }
  89.
  90.   if(count == R_PWM)
  91.   {
  92.     P32 = 0;
  93.     P33 = 0;
  94.   }
  95.
  96. }
  97. void SendData(BYTE dat)
  98. {
  99.   while (busy);               //???????????
  100.   busy = 1;
  101.   SBUF = dat;                 //????UART?????
  102. }
  103. //电机控制,注意电机驱动芯片9110两个控制端只能有一个为高电平,
  104. //若同时为高电平则芯片内部短路,危险,极易损坏芯片。
  105. void stop(void);
  106. void front(void);
  107. void back(void);
  108. void right(void);
  109. void left(void);
  110. //停止
  111. void stop(void)
  112. {
  113.   l9110s_1 = 0;
  114.   l9110s_2 = 0;
  115.   R9110s_1 = 0;
  116.   R9110s_2 = 0;
  117. }
  118. //前进
  119. void front(void)
  120. {
  121.   l9110s_1 = 0;
  122.   l9110s_2 = 1;
  123.   R9110s_1 = 0;
  124.   R9110s_2 = 1;
  125. }
  126. //倒退
  127. void back(void)
  128. {
  129.   l9110s_1 = 1;
  130.   l9110s_2 = 0;
  131.   R9110s_1 = 1;
  132.   R9110s_2 = 0;
  133. }
  134. //右转
  135. void right(void)
  136. {
  137.   l9110s_1 = 1;
  138.   l9110s_2 = 0;
  139.   R9110s_1 = 0;
  140.   R9110s_2 = 1;
  141. }
  142. //左转
  143. void left(void)
  144. {
  145.   l9110s_1 = 0;
  146.   l9110s_2 = 1;
  147.   R9110s_1 = 1;
  148.   R9110s_2 = 0;
  149. }
  150. //循迹避障 蓝牙控制功能选择
  151. unsigned char func_sel(void)
  152. {
  153.   unsigned long c;
  154.   unsigned char i;
  155.   i = 0;
  156.   c = 0;
  157.   D1 = D2 = 1;
  158.   stop();
  159.   Delay500ms();Delay500ms();Delay500ms();Delay500ms();
  160.   while((P15 == 0)&& (c <0x3ffff))
  161.   {
  162.     c++;
  163.     if((c > 0xffff) && (c < 0x1ffff))
  164.     {
  165.       D1 = 0;
  166.       i = 1;
  167.     }
  168.
  169.     if((c > 0x1ffff) && (c < 0x2ffff))
  170.     {
  171.       D1 = 1; D2 = 0;
  172.       i = 2;
  173.     }
  174.
  175.     if((c > 0x2ffff) && (c < 0x3ffff))
  176.     {
  177.       D1 = 0; D2 = 0;
  178.       i = 3;
  179.     }
  180.   }
  181.
  182.   if(c < 0xffff)
  183.   {
  184.     return func;
  185.   }
  186.   return i;
  187. }
  188. void main(void)
  189. {
  190.   BYTE last_recv;
  191.
  192.   P32 = P33 = P54 = P55 = 0;
  193.   l9110s_1 = l9110s_2 = R9110s_1 = R9110s_2 = 0;
  194.
  195.   R_PWM = 99;
  196.   L_PWM = 99;
  197.   P3M1 = 0;
  198.   P3M0 = 0x0C;
  199.   P5M1 = 0;
  200.   P5M0 = 0x30;
  201.   P1M1 = 0xf;
  202.   P1M0 = 0;
  203.   IP =0x10;
  204.   PWM_Init();
  205.   Usart_init();
  206.   D1 = D2 = 1;
  207.   P15 = 1;
  208.   func = 1;
  209.
  210.   while(func == 1)   //功能1:循迹
  211.   {
  212.     while((P11 == 1)&& (P13 == 0))
  213.     {
  214.       right(); D2 = 0;D1 = 1;
  215.     }
  216.     while((P13 == 1)&&(P11 == 0))
  217.     {
  218.       left();D1 = 0;D2 =1;
  219.     }
  220.
  221.     while((P13 == 0)&&(P11 == 0))
  222.     {
  223.       front();D1 = 0;D2 =0;
  224.     }
  225.     front();Delay500ms();
  226.     if(P15 == 0)
  227.     {
  228.       func = func_sel();
  229.     }
  230.   }
  231.   while(func == 2)  //功能2:避障
  232.   {
  233.     if(P15 == 0)
  234.     {
  235.       func = func_sel();
  236.     }
  237.
  238.     while((P12 == 1)&& (P10 == 0))
  239.     {
  240.       left(); D2 = 0;D1 = 1;
  241.     }
  242.
  243.     while((P12 == 0)&& (P10 == 1))
  244.     {
  245.       right(); D2 = 1;D1 = 0;
  246.     }
  247.
  248.     while((P12 == 1)&& (P10 == 1))
  249.     {
  250.       front(); D2 = 0;D1 = 0;
  251.     }
  252.
  253.     while((P12 == 0)&& (P10 == 0))
  254.     {
  255.       back(); D2 = 1;D1 = 1;
  256.     }
  257.   }
  258.
  259.   while(func == 3)    //功能3:蓝牙遥控
  260.   {
  261.     if(P15 == 0)
  262.     {
  263.       func = func_sel();
  264.     }
  265.
  266.     if(last_recv != usart_recv)
  267.     {
  268.       last_recv = usart_recv;
  269.       switch(usart_recv)
  270.       {
  271.       case 0x14:
  272.       case 0x15:
  273.       case 0x16:
  274.       case 0x17:
  275.       case 0x18:
  276.       case 0x19:
  277.       case 0x1a:
  278.       case 0x1b:
  279.       case 0x1c:
  280.       case 0x1d:
  281.       case 0x1e:
  282.       case 0x1f:
  283.         front();
  284.         R_PWM = 69+(usart_recv-0x10)*2;
  285.         L_PWM = 69+(usart_recv-0x10)*2;
  286.         D1 = D2 = 0;
  287.         break;
  288.
  289.       case 0x24:
  290.       case 0x25:
  291.       case 0x26:
  292.       case 0x27:
  293.       case 0x28:
  294.       case 0x29:
  295.       case 0x2a:
  296.       case 0x2b:
  297.       case 0x2c:
  298.       case 0x2d:
  299.       case 0x2e:
  300.       case 0x2f:
  301.         back();
  302.         R_PWM = 69+(usart_recv-0x20)*2;
  303.         L_PWM = 69+(usart_recv-0x20)*2;
  304.         D1 = D2 = 1;
  305.         break;
  306.
  307.       case 0x34:
  308.       case 0x35:
  309.       case 0x36:
  310.       case 0x37:
  311.       case 0x38:
  312.       case 0x39:
  313.       case 0x3a:
  314.       case 0x3b:
  315.       case 0x3c:
  316.       case 0x3d:
  317.       case 0x3e:
  318.       case 0x3f:
  319.         left();
  320.         R_PWM = 69+(usart_recv-0x30)*2;
  321.         L_PWM = 69+(usart_recv-0x30)*2;
  322.         D1 = 0; D2 = 1;
  323.         break;
  324.
  325.
  326.       case 0x44:
  327.       case 0x45:
  328.       case 0x46:
  329.       case 0x47:
  330.       case 0x48:
  331.       case 0x49:
  332.       case 0x4a:
  333.       case 0x4b:
  334.       case 0x4c:
  335.       case 0x4d:
  336.       case 0x4e:
  337.       case 0x4f:
  338.         right();
  339.         R_PWM = 69+(usart_recv-0x40)*2;
  340.         L_PWM = 69+(usart_recv-0x40)*2;
  341.         D1 = 1; D2 = 0;
  342.         break;
  343.
  344.       case 0x54:
  345.       case 0x55:
  346.       case 0x56:
  347.       case 0x57:
  348.       case 0x58:
  349.       case 0x59:
  350.       case 0x5a:
  351.       case 0x5b:
  352.       case 0x5c:
  353.       case 0x5d:
  354.       case 0x5e:
  355.       case 0x5f:
  356.         front();
  357.         R_PWM = 99;
  358.         L_PWM = 100-(usart_recv-0x50)*2;
  359.         D1 = 1; D2 = 0;
  360.         break;
  361.
  362.       case 0x64:
  363.       case 0x65:
  364.       case 0x66:
  365.       case 0x67:
  366.       case 0x68:
  367.       case 0x69:
  368.       case 0x6a:
  369.       case 0x6b:
  370.       case 0x6c:
  371.       case 0x6d:
  372.       case 0x6e:
  373.       case 0x6f:
  374.         front();
  375.         R_PWM = 100-(usart_recv-0x60)*2;
  376.         L_PWM = 99;
  377.         D1 = 0; D2 = 1;
  378.         break;
  379.
  380.
  381.       case 0x74:
  382.       case 0x75:
  383.       case 0x76:
  384.       case 0x77:
  385.       case 0x78:
  386.       case 0x79:
  387.       case 0x7a:
  388.       case 0x7b:
  389.       case 0x7c:
  390.       case 0x7d:
  391.       case 0x7e:
  392.       case 0x7f:
  393.         back();
  394.         R_PWM = 99;
  395.         L_PWM = 100-(usart_recv-0x70)*2;
  396.         D1 = 1; D2 = 1;
  397.         break;
  398.
  399.       case 0x84:
  400.       case 0x85:
  401.       case 0x86:
  402.       case 0x87:
  403.       case 0x88:
  404.       case 0x89:
  405.       case 0x8a:
  406.       case 0x8b:
  407.       case 0x8c:
  408.       case 0x8d:
  409.       case 0x8e:
  410.       case 0x8f:
  411.         back();
  412.         R_PWM = 100-(usart_recv-0x80)*2;
  413.         L_PWM = 99;
  414.         D1 = 1; D2 = 1;
  415.         break;
  416.
  417.       case 0:
  418.         stop();
  419.         D1 = 1; D2 = 1;
  420.         break;
  421.       }
  422.     }
  423.   }
  424. }
