查看: 3943|回复: 1
串口設置求助stc 15w4k56
ID:140371 发表于 2017-1-13 06:11 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
單片機用stc15w4k56s4 內部振盪  下載 STC 公司範例 自己加串口送出 A 字符ˊ 結果是可以下載程式,沒ˊ有收到串口的字符ˊ, 求ˊˊ助先進們.應如何ˊ設置還是我的蕊片壞了 #define MAIN_Fosc                22118400L        //隅砱翋奀笘#define        RX1_Lenth                32                        //揹諳諉彶遣喳酗僅
#define        BaudRate1                115200UL        //恁寁疏杻薹
#define        Timer1_Reload        (65536UL -(MAIN_Fosc / 4 / BaudRate1))                //Timer 1 笭蚾硉ㄛ 勤茼300KHZ
#define        Timer2_Reload        (65536UL -(MAIN_Fosc / 4 / BaudRate1))                //Timer 2 笭蚾硉ㄛ 勤茼300KHZ
#include        "STC15Fxxxx.H"
/*************        掛華曹講汒隴        **************/
u8        idata RX1_Buffer[RX1_Lenth];        //諉彶遣喳
u8        TX1_Cnt;        //楷冞數杅
u8        RX1_Cnt;        //諉彶數杅
bit        B_TX1_Busy;        //楷冞疆梓祩
/*************        掛華滲杅汒隴        **************/
void main(void)
        B_TX1_Busy = 0;
        RX1_Cnt = 0;
        TX1_Cnt = 0;
        S1_8bit();                                //8弇杅擂
        S1_USE_P30P31();                //UART1 妏蚚P30 P31諳        蘇
//          S1_USE_P36P37();                //UART1 妏蚚P36 P37諳
//          S1_USE_P16P17();                //UART1 妏蚚P16 P17諳
        TR1 = 0;                        //疏杻薹妏蚚Timer1莉汜
        AUXR &= ~0x01;                //S1 BRT Use Timer1;
        AUXR |=  (1<<6);        //Timer1 set as 1T mode
        TH1 = (u8)(Timer1_Reload >> 8);
        TL1 = (u8)Timer1_Reload;
        TR1  = 1;
        AUXR &= ~(1<<4);        //Timer stop                疏杻薹妏蚚Timer2莉汜
        AUXR |= 0x01;                //S1 BRT Use Timer2;
        AUXR |=  (1<<2);        //Timer2 set as 1T mode
        TH2 = (u8)(Timer2_Reload >> 8);
        TL2 = (u8)Timer2_Reload;
        AUXR |=  (1<<4);        //Timer run enable
        REN = 1;        //埰勍諉彶
        ES  = 1;        //埰勍笢剿
        EA = 1;                //埰勍擁笢剿
B_TX1_Busy=1;
  SBUF =0x41;
while(B_TX1_Busy);
        while (1)
                if(TX1_Cnt != RX1_Cnt)                //彶善徹杅擂
                        if(!B_TX1_Busy)                //楷冞諾玿
                                B_TX1_Busy = 1;                //梓祩楷冞疆
                                SBUF = RX1_Buffer[TX1_Cnt];        //楷珨跺趼誹
                                if(++TX1_Cnt >= RX1_Lenth)        TX1_Cnt = 0;        //旌轎祛堤揭燴
/********************* UART1笢剿滲杅************************/
void UART1_int (void) interrupt UART1_VECTOR
        if(RI)
                RI = 0;
                RX1_Buffer[RX1_Cnt] = SBUF;                //悵湔珨跺趼誹
                if(++RX1_Cnt >= RX1_Lenth)        RX1_Cnt = 0;        //旌轎祛堤揭燴
        if(TI)
                TI = 0;
                B_TX1_Busy = 0;                //壺楷冞疆梓祩
ID:7485 发表于 2017-1-13 18:50 | 只看该作者
注释都乱码了。
