查看: 3786|回复: 2
求助:lcd1602星期显示问题
ID:160658 发表于 2017-1-19 17:25 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
程序如下,上电能够显示SUN,依次显示到STA后,轮到SUN时,还是STA,跳过SUN,可以显示其它星期。但到了一定时间,显示到某个星期后再也不动了,不知是哪里原因,高手指点,谢谢(图片怎么不能传?)
#include<reg51.h>
#include<intrins.h>
sbit EP = P3^2; //使能端
sbit RW = P3^1; //数据/命令选择端
sbit RS = P3^0; //读写选择端
sbit KEY_1 = P3^4;          //设置模式选择
sbit KEY_2 = P3^5;          //调整时间
uint code table1[] = {0, 31, 59, 90, 120, 151,181, 212, 242, 273, 303, 334};
uchar code *Week[7] = {"Sun", "Mon", "Tue", "Wed", "Thu", "Fri", "Sat"};
uchar sec = 0, hour = 12, minu = 0;
uchar count = 0, month = 1, day = 1;
void T0_Init()
        ET0 = 1;
        TMOD = 0x01;
        TH0 = (65536 - 46071)/256;
        TL0 = (65536 - 46071)%256;
        TR0 = 1;
void delay(uint ms)
        uint i, j;
        for(i=ms; i>0; i--)
                for(j=110; j>0; j--);
void Lcd_Ready() //测忙函数
        uchar sta;
        RS = 0;
        RW = 1;
        do {
                EP = 1;
                sta = P1;
                EP = 0;
        }while(sta & 0x80);         //检测P1最高位是否为1,若为1,则1602忙,为0则可以读写操作
void Write_Cmd(uchar cmd) //写入命令
        Lcd_Ready();
        RS = 0;
        RW = 0;
        P1 = cmd;
        delay(5);
        EP = 1;
        delay(5);
        EP = 0;
void Write_Dat(uchar dat) //写入数据
        Lcd_Ready();  //LCD1602 不忙则跳出
        RS = 1;
        RW = 0;
        P1 = dat;
        delay(5);
        EP = 1;
        delay(5);
        EP = 0;
void Write_Week()                        //星期与日期同步
        static uchar week = 0;
        week = ((table1[month - 1]) + day - 1) % 7;
        Write_Cmd(0x80 + 12);
        while(*Week[week] != '\0')
                Write_Dat(*Week[week]++);
void Write_Num(uchar x, uchar y, uchar num) //将时分秒和日期写入1602
        uchar unit, decad;
        unit = num % 10;
        decad = num /10;
        if(y == 1)
                Write_Cmd(0x80 + 0x40 + x);
                Write_Dat(0x30 + decad);         //即加48,将数字转换为ASC||字符数字
                Write_Dat(0x30 + unit);
                Write_Cmd(0x80 + x);
uchar Get_Day(uchar m)
        if(m == 1||m == 3||m == 5||m == 7||m == 8||m == 10||m == 12)
                return 31;
        if(m == 4||m == 6||m == 9||m == 11)
                return 30;
        if(m == 2)
                return 28;
        return 0;
void Lcd_Init()          //LCD初始化设定
        Write_Cmd(0x38); // 16*2显示,5*7点阵,8位数据
        Write_Cmd(0x0c); // 显示开,关光标
        Write_Cmd(0x06); // 读写地址自动加1,光标加1
        Write_Cmd(0x01); //清除屏幕
void Display()
        Write_Week();
        Write_Num(9, 0, day);
        Write_Num(6, 0, month);
        Write_Num(4, 1, hour);
        Write_Num(7, 1, minu);
        Write_Num(10, 1, sec);
void TimerCount()
        if(count == 20)
                count = 0;
                sec++;
                if(sec == 60)
                        sec = 0;
                        minu++;
                         if(minu == 60)
                                minu = 0;
                                hour++;
                                 if(hour == 24)
                                        hour = 0;
                                        day++;
                                        if(day > Get_Day(month))
                                                day = 1;
                                                month++;
                                                if(month >12)
                                                        month = 1;
                Display();
void KeyScan()
        static uchar key1cnt = 0;                //KEY_1按下的次数
        if(KEY_1 == 0)
                delay(10);
                if(KEY_1 == 0)
                        key1cnt++;
                        while(!KEY_1);
                        switch(key1cnt)
                                case 1:
                                        TR0 = 0;
                                        Write_Cmd(0x80 + 0x40 + 5);
                                        Write_Cmd(0x0F);            //显示光标且光标闪烁
                                        break;
                                case 2:
                                        Write_Cmd(0x80 + 0x40 + 8);
                                        break;
                                case 3:
                                        Write_Cmd(0x80 + 0x40 + 11);
                                        break;
                                case 4:
                                        Write_Cmd(0x80 + 7);
                                        break;
                                case 5:
                                        Write_Cmd(0x80 + 10);
                                        break;
                                case 6:
                                        TR0 = 1;
                                        Write_Cmd(0x0C);           //不显示光标
                                        key1cnt = 0;
                                        break;
        if(key1cnt != 0)
                if(KEY_2 == 0)
                        delay(10);
                        if(KEY_2 == 0)
                                while(!KEY_2);
                                switch(key1cnt)
                                        case 1:
                                                hour++;
                                                if(hour == 24)
                                                        hour = 0;
                                                break;
                                        case 2:
                                                minu++;
                                                if(minu == 60)
                                                        minu = 0;
                                                break;
                                        case 3:
                                                sec++;
                                                if(sec == 60)
                                                        sec = 0;
                                                break;
                                        case 4:
                                                month++;
                                                if(month > 12)
                                                        month = 1;
                                                Write_Week();
                                                break;
                                        case 5:
                                                day++;
                                                        day = 1;
                                                Write_Week();
                                                break;
        uchar i = 0;
        uchar code table[] = {"2017-01-01"};
        EA = 1;
        Lcd_Init();                        //1602初始化
        T0_Init();          //定时器0初始化
        Write_Cmd(0x80 + 0x40 + 6);
        Write_Dat(':');
        Write_Cmd(0x80 + 0x40 + 9);
        Write_Dat(':');
        Write_Cmd(0x80 + 1);
        while(table[i] != '\0')
                Write_Dat(table[i]);
                i++;
                KeyScan();
void Timer0() interrupt 1
        count++;
        TimerCount();
ID:149451 发表于 2017-1-20 08:21 | 只看该作者
这句有问题,
ID:162841 发表于 2017-1-25 21:04 来自触屏版 | 只看该作者
多看看别人已有的设计
