查看: 2255|回复: 0
关于avr单片机驱动NRF24L01的问题 这个程序有错吗?
ID:161910 发表于 2017-1-21 21:05 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
这个程序有错吗?
#include<iom16v.h>
#include<macros.h>
#define NULL 0
#define DDR DDRB
#define PORT PORTB
#define CE 3
#define SS 4
#define MOSI 5
#define MISO 6
#define SCK 7
#define CE_1 PORT|=(1<<CE)
#define CE_0 PORT&=~(1<<CE)
#define SS_1 PORT|=(1<<SS)
#define SS_0 PORT&=~(1<<SS)
#define R_REG 0x00
#define W_REG 0x20
#define R_DATA 0x61
#define W_DATA 0xA0
#define FLUSH_TX 0xE1
#define FLUSH_RX 0xE2
#define CONFIG 0x00
#define EN_AA 0x01
#define EN_RXADDR 0x02
#define RF_CH 0x05
#define RF_SETUP 0x06
#define STATUS 0x07
#define RX_ADDR_P0 0x0A
#define TX_ADDR 0x10
#define RX_PW_P0 0x11
void delay_us(unsigned int Xus)
if(Xus==0)
  return;
while(--Xus);
void delay_ms(unsigned int Xms)
unsigned int j;
while(Xms--)
for(j=0;j<1140;j++);
int PORT_init()
DDRA=0xFF;
DDR=(1<<CE)|(1<<SS)|(1<<MOSI)|(1<<SCK);      //Output:CE,SS,MOSI,SCK;input:MISO;
PORT=(1<<SS);                                //Stop tranmission;
void SPI_init()
SPSR=0x01;                                   //Double speed;
SPCR=0x51;                                   //Enable SPI,master;
unsigned char SPI_rw(unsigned char DATA)
SPDR=DATA;
while(!(SPSR&0x80));
delay_us(10);
return SPDR;
void SPI_regW(unsigned char REG,unsigned char DATA)
SS_0;
SPI_rw(REG|W_REG);
SPI_rw(DATA);
SS_1;
unsigned char SPI_regR(unsigned char REG)
unsigned char temp;
SS_0;
SPI_rw(REG|R_REG);
temp=SPI_rw(NULL);
SS_1;
return temp;
void SPI_bufW(unsigned char REG,unsigned char *BUF,unsigned char LONG)
SS_0;
SPI_rw(REG|W_REG);
while(LONG--)
  SPI_rw(*BUF++);
SS_1;
void SPI_bufR(unsigned char REG,unsigned char *BUF,unsigned char LONG)
SS_0;
SPI_rw(REG|R_REG);
while(LONG--)
  BUF[LONG]=SPI_rw(NULL);
SS_1;
void NRF24L01master_init(unsigned char *BUF)
CE_0;
SPI_bufW(RX_ADDR_P0,BUF,5);            //Data channel 0 receive address;
SPI_bufW(TX_ADDR,BUF,5);               //Send address;
SPI_regW(EN_AA,0x01);                  //Enable channel 0 ack;
SPI_regW(EN_RXADDR,0x01);              //Enable channel 0;
SPI_regW(RF_CH,0x00);                  //working frequency,Must be consistent with the slave;
SPI_regW(RX_PW_P0,0x01);               //One byte data width;
SPI_regW(CONFIG,0x7A);                 //Mask all interrupts,Power-on,Transmission mode;
CE_1;
void NRF24L01slave_init(unsigned char *BUF)
CE_0;
SPI_regW(RF_CH,0x00);                  //working frequency,Must be consistent with the master;
SPI_regW(CONFIG,0x7B);                 //Mask all interrupts,Power-on,Receive mode;
CE_1;
void NRF24L01_send(unsigned char DATA)
CE_0;
SPI_regW(W_DATA,DATA);
CE_1;
delay_us(300);
unsigned char NRF24L01_receive()
unsigned char temp=NULL;
if((SPI_regR(STATUS)&0x40))
   temp=SPI_regR(R_DATA);
   SPI_regW(STATUS,(SPI_regR(STATUS)&(~(0x40))));
return temp;
unsigned char address[5]={0x34,0x43,0x10,0x10,0x01};
PORT_init();
SPI_init();
NRF24L01master_init(address);
  unsigned char i=0;
  for(i=0;i<0xFF;i++)
    NRF24L01_send(i);
        delay_ms(300);
