查看: 3704|回复: 0
51单片机定时器及数码管显示
ID:169931 发表于 2017-3-11 20:13 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include<reg52.h>
sbit dula=P2^6;
sbit wela=P2^7;
sbit d1=P1^0;
uchar num,num1;tt;
uchar code table[]={
0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71};
void delay(uint z);
        num=0;
        tt=0;
        TMOD=0x11;//设置定时器0为工作方式1
        TH0=(65536-10000)/256;
        TL0=(65536-10000)%256;
        TH1=(65536-20000)/256;
        TL1=(65536-20000)%256;
//        EA=1;//开总中断
        ET0=1;//开定时器0中断
        ET1=1;
        TR0=1;//启动定时器0
        TR1=1;
        wela=1;//11101010
        P0=0xea;
        wela=0;
        dula=1;
        P0=0x3f;
        dula=0;
                if(num1==25)
                                num1=0;
                                P1=~P1;
                if(tt==100)
                                tt=0;
                                num++;
                                if(num==16)
                                num=0;
                                dula=1;
                                P0=table[num];
                                dula=0;
void delay(uint z)
        uint x,y;
        for(x=z;x>0;x--)
                for(y=110;y>0;y--);
void time0() interrupt 1
        tt++;
void time1() interrupt 3
        num1++;
