查看: 4861|回复: 0
LED双灯闪烁实验 寄存器版程序分享 51单片机到STM32过渡
51单片机到STM32单片机的过渡,寄存器版程序分享!
本例程使用MDK4.12版本编译好,进入MDK文件夹点击project.uvproj即可打开例程
1.MDK文件夹
     --- MDK启动软件
2.obj文件夹
     --- 包含编译产生的中间文件
     --- 最终可执行的HEX文件程序
3.src文件夹(包含所有的源代码)
     ---包含main.c文件
  1. /*  本实验使得GPIOD8和GPIOD9管脚控制STM32VCT6的LED1和LED2两个灯进行闪烁 */
  2. #define     __IO    volatile
  3. typedef unsigned           int uint32_t;
  4. typedef __IO uint32_t  vu32;
  5. typedef unsigned short     int uint16_t;
  6. #define GPIO_Pin_0                 ((uint16_t)0x0001)  /*!< Pin 0 selected */
  7. #define GPIO_Pin_1                 ((uint16_t)0x0002)  /*!< Pin 1 selected */
  8. #define GPIO_Pin_2                 ((uint16_t)0x0004)  /*!< Pin 2 selected */
  9. #define GPIO_Pin_3                 ((uint16_t)0x0008)  /*!< Pin 3 selected */
  10. #define GPIO_Pin_4                 ((uint16_t)0x0010)  /*!< Pin 4 selected */
  11. #define GPIO_Pin_5                 ((uint16_t)0x0020)  /*!< Pin 5 selected */
  12. #define GPIO_Pin_6                 ((uint16_t)0x0040)  /*!< Pin 6 selected */
  13. #define GPIO_Pin_7                 ((uint16_t)0x0080)  /*!< Pin 7 selected */
  14. #define GPIO_Pin_8                 ((uint16_t)0x0100)  /*!< Pin 8 selected */
  15. #define GPIO_Pin_9                 ((uint16_t)0x0200)  /*!< Pin 9 selected */
  16. #define GPIO_Pin_10                ((uint16_t)0x0400)  /*!< Pin 10 selected */
  17. #define GPIO_Pin_11                ((uint16_t)0x0800)  /*!< Pin 11 selected */
  18. #define GPIO_Pin_12                ((uint16_t)0x1000)  /*!< Pin 12 selected */
  19. #define GPIO_Pin_13                ((uint16_t)0x2000)  /*!< Pin 13 selected */
  20. #define GPIO_Pin_14                ((uint16_t)0x4000)  /*!< Pin 14 selected */
  21. #define GPIO_Pin_15                ((uint16_t)0x8000)  /*!< Pin 15 selected */
  22. #define GPIO_Pin_All               ((uint16_t)0xFFFF)  /*!< All pins selected */
  23. #define RCC_APB2Periph_AFIO              ((uint32_t)0x00000001)
  24. #define RCC_APB2Periph_GPIOA             ((uint32_t)0x00000004)
  25. #define RCC_APB2Periph_GPIOB             ((uint32_t)0x00000008)
  26. #define RCC_APB2Periph_GPIOC             ((uint32_t)0x00000010)
  27. #define RCC_APB2Periph_GPIOD             ((uint32_t)0x00000020)
  28. /************ GPIOD <*************/
  29. typedef struct
  30. {
  31.   __IO uint32_t CRL;
  32.   __IO uint32_t CRH;
  33.   __IO uint32_t IDR;
  34.   __IO uint32_t ODR;
  35.   __IO uint32_t BSRR;
  36.   __IO uint32_t BRR;
  37.   __IO uint32_t LCKR;
  38. } GPIO_TypeDef;
  39. typedef struct
  40. {
  41.   __IO uint32_t CR;
  42.   __IO uint32_t CFGR;
  43.   __IO uint32_t CIR;
  44.   __IO uint32_t APB2RSTR;
  45.   __IO uint32_t APB1RSTR;
  46.   __IO uint32_t AHBENR;
  47.   __IO uint32_t APB2ENR;
  48.   __IO uint32_t APB1ENR;
  49.   __IO uint32_t BDCR;
  50.   __IO uint32_t CSR;
  51. } RCC_TypeDef;
  52. /********* GPIOD管脚的内存对应地址 *******/
  53. #define PERIPH_BASE           ((uint32_t)0x40000000)
  54. #define APB2PERIPH_BASE       (PERIPH_BASE + 0x10000)
  55. #define GPIOD_BASE            (APB2PERIPH_BASE + 0x1400)
  56. #define GPIOD               ((GPIO_TypeDef *) GPIOD_BASE)
  57. /************ RCC时钟 <*************/
  58. #define AHBPERIPH_BASE        (PERIPH_BASE + 0x20000)
  59. #define RCC_BASE              (AHBPERIPH_BASE + 0x1000)
  60. #define RCC                 ((RCC_TypeDef *) RCC_BASE)
  61. void Delay(vu32 nCount);
  62. int main(void)         //main是程序入口
  63. {
  64.           /* 使能APB2总线的时钟,对GPIO的端口D时钟使能 */
  65.           RCC->APB2ENR |= RCC_APB2Periph_GPIOD;
  66.         /*-- GPIO Mode Configuration速度,输入或输出 -----------------------*/
  67.         /*-- GPIO CRL Configuration 设置IO端口低8位的模式(输入还是输出)---*/
  68.         /*-- GPIO CRH Configuration 设置IO端口高8位的模式(输入还是输出)---*/
  69.         GPIOD->CRH &=  0xFFFFFF00;    //清除对位8位9的配置
  70.         GPIOD->CRH |=  0x00000033;         /* 设置GPIOD的PD8和PD9配置为通用推挽模式输出50MHZ(PD.8和PD.9的推挽输出)*/
  71.           while (1)
  72.           {
  73.                         /* 对BSRR设置为1,则GPIO输出为1 */
  74.                 GPIOD->BSRR = GPIO_Pin_8;
  75.             GPIOD->BSRR = GPIO_Pin_9;
  76.                 Delay(0x2FFFFF);
  77.
  78.
  79.           /* 对BRR设置为1,则GPIO输出为0 */
  80.                   GPIOD->BRR = GPIO_Pin_8;
  81.                 GPIOD->BRR = GPIO_Pin_9;
  82.                 Delay(0x2FFFFF);
  83.
  84.           }
  85. }
  86. void Delay(vu32 nCount)                 //通过不断for循环nCount次,达到延时的目的口
  87. {
  88.   for(; nCount != 0; nCount--);
  89. }
完整代码下载:
LED双灯闪烁实验(STM32-寄存器版).7z (12.36 KB, 下载次数: 9)
